Question about Panasonic Home Theater System System
Turns off immediatly, flashing code F61 - Panasonic Home Theater System System
  • smithll Dec 25, 2008
    Yea, I have the same problem... I saw a possible solution on another website.
    It said bad ic power chip replacement part # is rsn311w64b-d. I haven't tried this so I don't know if it will work. Let me know if this works and I'll let you know if it works for me.
    smithll@whitman.edu
  • 9 Answers
Check the main set fan is turning or not once you press power button on main set.
If it is turn then is Digital amplifier IC (as above mentioned) damaged.
If not then is the fan malfunction.
Posted on Jan 06, 2009
I have a SA-HT730. i get the F61 error code and then turns off. Please help
Check this site. It has details about the error codes to Panasonic HTs. http://electronicshelponline.blogspot.com/
Pull up previous posts, either by type in the Brand name to your set in its search box, or view it in Mosaic / Timeslide / Flipcard option. Select view option by the drop-down view box, at the top left or the display window.
Aug 15, 2013 | Panasonic DVD-F61 Multi-disc DVD Player
Error f61 on my panasonic sa-ak330
The f61 code is believed to be an amplifier circuit fault, but in reality it more often than not turns out to be a problem with a jammed up motor elsewhere(fan, cd changer motor, cassette motor). For me it was a jammed up cd changer. I simply disconnected the control for the changer and operation resumed as normal.
Mar 30, 2013 | Audio Players & Recorders
When i try to turn on the power it says F61 It turns off immediatly following that. Please help
F61 usually means the amp has detected a short or a severe microprocessor error.
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Mar 18, 2011 | Panasonic Home Theater System System
98 K1500 starts then turns off immediatly
Per your description, it sounds like you change the lock cylinder. That cylinder has a specific code associated with it. When you insert the key, the code is sent to the security system to verify it is the correct key and cylinder.
You will have to relearn the system to accept the new cylinder.
Insert the key and turn it to the run position. Leave the key on for 10 minutes, turn off the ignition and repeat 2 more cycles of 10 minutes each. This will relearn the new security code and you should be OK at that point.
Good luck and let me know.
Regards,
Mar 08, 2009 | 1996 Buick Regal Olympic Gold
HT900
I kept hitting the disc exhange/eject button to turn the unit on and after a couple of tries it finally opened about half way. The whole reason i wanted to open it was to get the last dvd that i watch out of it. Well in doing so i noticed that there were some discs rattling around up underneath the cd tray (from my 1 1/2 year old). After shaking the unit a couple of times i was able to get the discs out of the underside of the disc tray. When i hit the disc exchange to close the try the unit powered up, closed the tray, and operated fine and i am back to using it like i used to with out any other problems.
Oct 15, 2008 | Panasonic SC-HT940 System
Remove casing for Panasonic SA-DT310
Figured it out. quite simple really.
1. Unscrew the 3 screws at the back that hold the plastic casing on (NOT the one that only go through the metal but the 3 that go through the plastic).
2. you can now slide the side plastic sections of the casing off.
3. underneath these side sections you will see that there is a small section of plastic on each side that can be pushed in which will then enable you to slide off the top part of the casing.
4. underneath the top plastic casing is further metal casing. unscrew the two screws toward the front that will then enable you to lift this inner metal casing off.
Oct 09, 2008 | Audio Players & Recorders
My panasonic turns on but shows the letter f61 what does that mean?
F61 just means 'power fault'
Generally a fault with either audio power amp ic (IC 501) or power supply ic (IC 502).
May also be the fan if it has one make sure it is clean and can spin freely.
Hope this helps. Thanks
Sep 13, 2008 | Panasonic Televison & Video
F61 code on SA HT540 system
i think it means that the cooling fan is faulty.
cheers Mark
Jan 06, 2008 | Lands Phones
Panasonic Home Theater System System Logo
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
