Question about Bose Wave music system Multi-CD Changer 3-Disc
Bose 123 system will not eject cd
Keeps spinning can i remove cover to get to cd area, i thinks its just not sitting properly
SOURCE: CD stuck in BOSE 3 disk stack player
I had the same problem and went to the Bose Tech Support site and found this solution. It allowed me to eject the stuck CD. The same problem happened again when I tried to enter another CD but after repeating the process below the CD ejected again and after that it worked fine.
Hope it works for you.
  • Try performing a reset with your Wave® music system upside down:
    1. Unplug the system, flip it upside down, place it on a firm, level surface, then plug it back in again
    2. If the CD ejects when you do this, the system may need to be serviced. Contact Bose® Technical Support or call 1-800-278-1281
  • Posted on Nov 02, 2008
    SOURCE: CD stuck in disk tray of (original) BOSE 321
    NO NEED TO TEAR APART OR REPLACE THE UNIT! JUST TURN OFF THE UNIT, LEAN IT FORWARD AND A LITTLE DOWNWARD AND HIT THE LOAD BUTTON AND IT WILL OPEN. THAT'S THE TRICK!
    Posted on Dec 30, 2008
    VOTIT
    • 2071 Answers
    SOURCE: Bose Wave System CD does not eject
    Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
    Hope it may helps;
    Posted on Jun 12, 2009
    • 667 Answers
    SOURCE: CD will not eject disc error comes up
    May have to open the unit up and manually remove the disk be very careful to put all parts back together the way it was do not force the disk out. Try it a few times before you put it back together, be careful not to touch anything and shock your self when plugged in. Only Qualified Tech should attempt this.
    Posted on Apr 08, 2010
    futurework
    • 70 Answers
    SOURCE: Bose 321 won't eject DVD
    the dvd system is built around a pc style dvd rom drive. You can remove the top cover by prying the back center up and sliding the cover back then off. Remove the metal bracket that holds the drive in place and then remove the drive. the front tray cover should pop off as you remove the drive. There is a eject hole in the front that if you put a paper clip into it will release the tray. That way you can get your dvd back. I refurbish these drives and I may have one for sale. Contact me if you would like to send the unit in to me i can complete the repair for 85.00 Bose does offer a repair service if you call them at 1-800-999 2673
    Posted on May 04, 2010
    I cant insert a CD into my Bose Wave Music System. I think there is a CD stuck there. How do I get it out?
    It is very difficult to remove a stuck disc and may require removal of the cabinet to get inside the works. Best to take it to a qualified service shop where they can do it for you.
    Oct 09, 2014 | Bose & Wave& Music System
    A CD is stuck in my bose system How do I get it out?
    From an other web site
    If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
    PART I
    1. First unplug the power, wait a minute, and then replug power, watching the front display.
    2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
    PART II
    1. Unplug the power cord.
    2. Turn the radio upside down with the front facing you.
    3. Remove the 5 screws from the bottom plate.
    4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
    5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
    6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
    7. Reverse these steps to reassemble your radio.
    Enjoy your cd player again!
    Need to know how can I open the 123 Bose system when the cheap CD is stuck inside it says it's open but it's not thank you
      • Turn off the device.
      • Disconnect the Acoustimass module power cord from the electrical source. Wait 60 seconds. Plug the cord back into to its power supply.
      • Hold down the "Eject" button.
    Feb 01, 2013 | Televison & Video
    Eject disk
    If your cd is stuck in the Bose you may have to open up the cover any manually remove this disk, make sure not to put it back in. If you are unable to remove this yourself you will need to get some one qualified to do this procedure for you. Be careful not to break anything take your time and put everything back as you took it apart.
    Apr 05, 2010 | Bose Lifestyle 28 System
    Open/close tray disc stuck bose Lifestyle 48
    Problem:
    I also have a bose Lifestyle 48, and the same problem has happen to me where the DVD player would not open,
    Solution:
    Unplug the unit, Wait a few seconds, after plugging the power back in, immediately hit eject so that the player does not have time to spin up and try to read the disc again
    Feb 17, 2009 | Bose Lifestyle 48 System
    Bose 123 Disk Stuck
    I obviously have placed a CD upside down in the the DVD player-which I have never had a problem with-ever-but now it will not eject the CD- Help please-Steve
    Jul 16, 2008 | Bose 3 2 1 GSX System
  • Jun 06, 2008 | Bose Wave music system Multi-CD Changer...
    Multi cd bose player will not eject 4th cd.
    OK, this problem is everywhere with the bose cd changer addon. Many people can still play a cd with the top one fine, but cannot get cds to eject and/or read in 3 disc changer. My friends mom had one and after finally hearing back from bose, they said send it in with $100 to get fixed. If you have to send in and you value your cds, you may want to open it up and get them out. Use this at your own risk, there are no warranty stickers I saw and there will be exposed voltage, shock hazards, etc.; so if any of this worries you, stop here. By proceeding, you are admitting that you are capable of minor repairs and therefore I'm not responsible for any damage or harm caused. OK, here it is:
    Unplug everything. On the bottom of the cd changer unit are 4 screws (silver ones recessed about 3/4" or so, use phillips screwdriver) to remove. Turn unit upright again and lift cover slowly straight up. In the front of the unit is a ribbon cable you will want to disconnect that goes to the cd 2-4 lights. Take note which side the dark blue tab is on and gently pull out by dark blue tab, rocking side to side if needed) You can then pull cover all the way off and set aside. Plug power into back of cd changer (careful not to touch anything inside) and see if the cds want to eject now. If not let the initializing process finish and repeat. This time see if you can gently help the cd out. The problem may also be the spindle not lowering, you can look for this movement during the last step of init. process. Work your way fom the top tray down removing the cds gently, remember we open it up because they were valuable to us, don't destroy them now, and don't ever use anything that could possibly scratch either top or bottom of the cd, use edges instead. Start to replace cover making sure to reattach ribbon cable back into socket the same way it came out. do not force too hard or you may crease and break ribbon. Gently replace cover and grab both top and bottom to turn over. Replace 4 phillips screws making sure not to overtighten or cross-thread. Now you may return to bose or just find an independent repair shop in your area, they are usually quicker, more polite, usually cheaper, and best of all, local!
    Dec 15, 2007 | Bose Wave music system Multi-CD Changer...
    Cd changer
    Could be some dirt on mechanism. Try to open cover, remove disc and clean it. Unplug it from power first, of course!
    Oct 03, 2007 | Bose Lifestyle 25 System
    Bose Wave music system Multi-CD Changer 3-Disc Logo
    553 people viewed this question
    Top Bose Audio Players & Recorders Experts
    Invebo
    Level 1 Expert
    Steve Allison
    Steve Allison
    Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
