Question about Rangemaster 110 (Gas) Kitchen Range
Problem with clock and Auto setting
Can't seem to get rid of Auto setting without losing oven function. Therefore when resetting the only way to make the oven work is to set oven clock at say 23.59 and let it count down. Once this time is used up the oven then cuts out. Because of this also can't use the oven timer! Please can you help?
  • 2 more comments
  • lucy p Feb 21, 2008
    moved house, and can't set ,the rangemaster cooker timer after the power has been off, its just flashing, there are no instructions and can't find the serial number to ring the helpline, anyone out there help me, thanks
  • vorsh Apr 15, 2008
    My oven turns itself off after a few hours of it not being opened. I was wondering how to reset the oven so it won't turn off when I'm doing my holiday cooking. My oven model no: 362.75575691- gas oven
    Thanks
  • amphlett Aug 19, 2008
    how do I set the time on my Toledo XT cooker. It is flashing auto and 0.00
  • EmilyyBabee Nov 04, 2008
    Our rangemaster 110, is constantly on auto with the clock on 0:00
    no matter what we do it won't change.
    Help please x
PLEASE HELP US OLDIES BUT GOODIES WE HAVE HAD NEW CLOCK INSTALLED INTO OUR 110 RANGEMASTER BUT THE SOUND IS VERY QUIET HOW CAN WE GET IT LOUDER????
HELP US PLEASE
Posted on Oct 28, 2008
Hi, we've sorted it now, we just pressed the buttons very hard....
Posted on Feb 21, 2008
Set the cooking time to 0.00 and then press 4th button from the left (should have a little hand above it) This should return you back to manual cooking
Posted on Aug 08, 2007
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
Burners work on top of stove, but oven and clock not working
Make sure the clock is not set to "auto" function or on "timer" mode. The oven will not start until the correct time has come up. If the clock is not working , this is likely to be the problem. See if there is a manual operation control or switch. You may have to get a new clock or arrange for the clock to be bypassed so the oven can work without it. Most electronic clocks can stop an oven from working if they fail.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Set clock on Omega 00652XN oven it has 3 buttons
Turn the oven off at the wall. When you turn it back on the clock will flash. Use the + or - to adjust the clock then use the middle button to scroll through the duration, start and end times of the auto cook function until you end up back at the clock. The oven symbol will always be displayed in clock mode unless the auto cook function is set.
Hope this helps.
Craig.
Aug 15, 2011 | Microwave Ovens
I purchased a microwave/convect oven combo last week. Installed today, everything works fine except that the lower oven won't heat. I tried turning the breakers off waiting a few minutes and back on. ...
Ensure that the clock is set and that is not in auto mode, the clock is only linked to the main oven and therefore it will not opearte if the clock is not set correctly, all the best
Sep 04, 2010 | Bosch HBN 9722 GB Electric Double Oven
I had a power cut and it only lasted 8 mins my cooker works top oven works but the main oven doesnt how do i work it as the fan and light works but oven do not thank you
If you have had a power failure, you may find that the clock has reset. If the clock has an auto setting this will be linked to the main oven only and therefore the clock will need to set to manual for the oven to work. The alternative is that the oven element has blown and this is what tripped your power, in which case you will need to replace the element. Hopefully, the first scenario is correct and will be a lot cheaper.
All the best, pls leave feedback or reply for further assistance with make and model number.
Aug 20, 2010 | Ovens
Tecnick tck 8522/2 oven
power to the main oven has to go through the oven clock if time is not set main oven will not work also if clock set on auto time rather than manual oven will not work conversley if clock is faulty it will not work top oven is unaffected as oven clock auto timer cannot be used on top oven.try resetting power of and on again reset time on clock if clock not faulty oven will now work.
Jun 05, 2010 | Tecnik TKC8522 Electric Double Oven
The clock on my Cambridge oven wont work, I cannot set. Therefore the oven wont light unless the clock is set. How do I fix this problem? All the buttons have stopped working so therefore unable to set the...
bad digital control board if tis just a clock and all the settings can be done with a knob and not the board then the replacement wont be too expensive but if that board controls eveything which i suspect it does then its going to be at least 150 more to repair than if it was just a clock display
Mar 30, 2010 | Ovens
WILL NOT ALLOW LCD CLOCK TO RESET
Turn it on and while its on completely unplug it wait then replug it, this should reset it, if this does not work, and it should, you will probally have to replace timer, but I hate to recommend this, they do not go bad ofen, but on acasion they do, let me know i hope this does it without replacing the timer
Feb 17, 2010 | Kitchen Ranges
Oven will not ignite
Rangemaster 110. Ovens not lighting due to faulty auto/clock. FIXED!
Someone, somewhere on the internet had the solution to my problem but I can't find the link again to thank them! If you don't mind losing the clock/timer auto function this is for you and it's free! Just takes a bit of time.
Basically you need to lift/open up the LH &RH hobs to get at the wires behind the clock. You should see 2 blue(neutral) wires coming directly from the back of the clock. Pull them out and connect together - should be easy to click them together. Then the ovens will light - but you will lose the auto/clock/timer functions. We only used the timer so not a big issue. We didn't take the control panel off but we did take ages to unscrew the hobs etc Probably took us about 2 hours going back to instruction manual we found on internet and trying to work it out but I think we've saved a lot in not replacing the unit with the usual call out charges. We made sure electrical supply was switched off and just took our time. Really chuffed!
Comment by tinling, posted on Nov 06, 2008 http://www.rangemaster.co.uk/Siteimages/Site_311/BigMedia/RM110Gas_04_06.pdf
This should allow you to see the instruction manual for the 110. There was another one somewhere showing a diagram of how to link the 2 blue wires at the back of the clock but I can't find it again! By the way our cooker is 10 years old so maybe different from newer models. We didn't have to take of the front control panel we accessed everything by lifting up the hobs to get behind the clock/timer.
Hope this helps! Ovens still working just got to go and buy a wee timer.
Jul 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Rangemaster 110 (Gas) Kitchen Range Logo
1,760 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Archie Ferrarini
Archie Ferrarini
Paul Carew
Norman Worley
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
