Arcam AVR-200 5.1 Channels Receiver
Problem for Arcam AVR-200 5.1 Channels Receiver
When I switch to DVD input, the display reads VCR3/optical. How can I use the DVD input with analog ....
By Brad - usenet poster
When I switch to DVD input, the display reads VCR3/optical. How can I use the DVD input with analog audio?
Best Solution
posted on Aug 08, 2005
Helpful)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
On Page 21 in your owners manual for your reciever Paragraph 7. it says set the the signal type to match your Audio connection: ANALOG, OPTI1,OPTI2, OR COAXIAL. Choose the source by pressing the MODE button and the SELECTOR +/- keys on the reciever, or the DIGITAL button on the remote control. If this fails to work make sure you connections from the DVD unit is installed correctly. You have three choices to hook up your sound from the DVD player. In some cases you are limited it all depends on what DVD unit you own. The three are: 1. your left and right audio cable which is marked Red for right speaker and White for left speaker. 2. Is the Optical connection, and 3. your Coaxial connection. Chances that it say VCR/3 optical because the connection is not connected right. Hey we all make that mistake. From your DVD, connect the left and right audio wire from the output of your DVD player to the DVD input audio on your reciever. This will allow you to play the analog mode. NOTE: this will not give you the Surround Sound effect. Nor, will it give you the DTS, or Dolby Digital Surround Sound. Only sounds from your left and right speaker. If you don't have the correct audio wire you can buy it at your local electronic stores. Ask your sale rep. for the left and right audio wire. But most older DVD's are recorded in the 2.0 format which is the analog format. I hope this helps you out. Enjoy your movies
Was this helpful?
Yes
No
Popular Solutions for Arcam AVR-200 5.1 Channels
Questions and Unsolved Problems for Arcam AVR-200 5.1 Channels
Do you recommend Arcam AVR-200 5.1 Channels Receiver?
Answer
Answer
why does my fuse keep blowing in my arcam avr200
Answer
Computer connection lead mislaid are you able to replace.Speaker number PID SE523
Answer
why doe my Denon home receiver keep turning off when the volume goes to a certain volume level?
Answer
I have a similar problem where the receiver turns off after about 3 minutes of turning it on. It... (More)
Describe your Receivers problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receiver Experts
Top Audio & Video Equipment Repairmen
in , TX
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
