Question about Roper RAS6233KQ Top Load Washer
My roper washer won't spin
The washer started making a humming/grinding noise, it filled with water but wouln't spin.
  • Roper Master
  • 5,569 Answers
You should probably remove the water by hand if it will not pump and then pull the unit out far enough to get behind it. Have a bucket handy to drop your water supply hoses into since they will drain.
Back panels are mostly held on by a handful of screws (no more than a dozen) and once removed, you can peer inside with a flashlight.
If you see leftovers from a shredded belt, cheer!  The transmission would be far more costly to replace.
The belt can be had many places but I suggest you go to Sears website, then the parts department with your machine model number handy. They have a huge collection of parts illustrations for thousands of machines and Roper (now a Whirlpool company) is a common name. You should be able to get the mfrs. part number there and then search further or buy it from Sears.
Posted on Dec 21, 2008
    Problem Solver:
  • 11 Answers
Sounds like transmission went out. Very costly to have repaired. Best buy a new one, like I did.
What will the washing machine do if the timer is bad. My Roper fills up with water and won't do anything else at all, doesn't even make a humming sound. Had to drain with cup. The knob for
From the closed position lift the lid of the washer about 2'' and listen for a distinct click. Then set lid back down and should hear another click just before it closes. The wire form hinge on left side of lid actuates the lid switch. Is it broken? Let me know.
Jan 26, 2013 | Washing Machines
Roper washer RAX4232PQO doesn't agitate or spin
It sounds like you may have a broken motor coupling. This is a common problem that usually occurs through normal wear and tear. Replacement couplers are more resilient and resist breaking much better. If the washer will fill, will not agitate or spin, but will still drain, these are the symptoms of a broken motor coupling. The accompanying noise of the motor engaging and a rattling/grinding sound is also a common symptom. This is a very simple and inexpensive repair. The following link explains step-by-step how to replace one:
http://www.fixya.com/support/r385252-replacing_motor_coupling_whirlpool_top
The part number is included in the link I provided. You can purchase a replacement on line at appliancepartspros.com for about $11.
If you have any questions, please let me know. I hope this helps you.
NOTE: Roper is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
Oct 04, 2009 | Roper RAX7244KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Mar 04, 2009 | Roper RAS8244KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Roper model #RAS7133pqo
I'm having the same problem. The noise we hear is the water pump, does your washer have a belt?
Please forward to me any tips you may get, I'll do same
Lew
Feb 03, 2009 | Roper RAS8445KQ Top Load Washer
Model RAS7133pqo
If it agitates, you probably need a new gearcase. If not, check the coupling between the gearcase and motor. Hope this helps!
Roper wash machine ras7133kq1
no theres something in your pump,,it up against the impeller in your pump.....onthejob
Jan 31, 2009 | Roper RAS6233KQ Top Load Washer
Washer makes noise, will not fill
turn it on and just makes a hummins noise??? not filling with water??? at very least the machine if powered correcly will fill with water, the humming if happening is hte washer trying to fill check your incoming water supply. try alo changing water temp select from cold/warm/hot.
Dec 03, 2008 | Roper RAS8244KQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
165 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
