It's leaving about a quarter of the milk/hot chocolate in the t-disk.
I cleaned it thoroughly and also used the cleaning t-disk a few times.
Help!
I have problem with chocolate pods on new machine. Always quite a lot of powder let in pod. I have to use a knife, open top of pod and Sharpe the powder out and still it into drink. Every time! Coffee pods are ok.
Alternatively, if that doesn't help and you're using a Braun machine it could indicate the heater block has started to scale (as this reduces the water flow through the machine).
Try descaling the machine (full descale cycle) and see if that helps!
I do not have experience with milk or chocolate, but for coffee and tea, at the end of a brew cycle, the green light should flip to the MANUAL light. For the next 30 seconds you have the option to press and hold the start button, to force more hot water through the pod into your cup. Give this a try to purge the pod of it's goodies!
Good luck.
Gazzer.
You can
basically substitute any non dairy products for milk and then follow the
regular recipe for hot chocolate i.e. heat the 'milk' and add chocolate till it
melts and stir in sugar to taste.
Be careful
with the sugar amounts as some of the non dairy milks ie soya are quite sweet
already.
You can try using almond or rice milk as well or just buy a non-dairy creamer.
Although the
two names of drinks are used interchangeably, hot chocolate is a drink that's
either made from real chocolate melted into milk or with packet hot chocolate
powder. Cocoa powder is unsweetened and needs to be combined with sugar to
create a sweeter drink.
In general
hot chocolate is richer and sweeter than hot cocoa.
To make a
yummy cup of cold 'hot chocolate', take a cup of milk and add in double the
recommended amount of chocolate powder (or cocoa and sugar). Stir well and add
ice cubes.
If you have
time and want a drink that's even more special, you can use chocolate ice cubes
in the drink.
To make
chocolate ice cubes; Mix the recommended amount of hot chocolate with a cup of
milk and freeze in an ice cube tray. When they are solid you can add to the hot
chocolate.
I am having the same problem with any milk disc. It seems like the last part of the milk process is missing (injecting steam to create the froth). I cleaned my machine with coffee cleaner and ran the cleaning disk several times.
t-disks and milk disks are still half filled when the machine is done. have cleaned and descaled machine. doesn' appear to have the air at the end of cycle.
I have the same problem and was hoping to find a solution here. No luck.. I will contact their customer service, and will get back to you all if I manage to get a solution
i have found this problem to, and i dont have a cleaning disc so going to have to buy one of those know too
