Question about Mitsubishi VS-50609 50" Rear Projection Television
Mitsubishi VS-50609 The red convergence is messing up
For a while we were able to fix it by making the convergence go all the way to the left and then bringing it back to the center but now its stuck and is bowed to the right across the middle of the tv. Im not sure how to fix it help?
    Sergeant:
  • 233 Answers
The convergence has gone crazy on you because your convergence IC's have gone bad.
These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.
Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.
If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!
If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you sont have one you can download it at servicemanuals.net
Hope that helps!
Posted on Dec 21, 2008
Is it a difficult to replace the convergence amplifier modules on a Mitsubishi VS 50609 TV?
Your convergence has failed. This is a very common problem on most projection tv sets. You can read about it here on fixya using this link
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 20, 2013 | Mitsubishi VS-50609 50" Rear Projection...
Vs-50609
Either a bad solder connection in the Convergence circuit or the chip/s used need to be replaced.
Jun 26, 2012 | Mitsubishi VS-50609 50" Rear Projection...
The top left corner of the picture has started to have a "saggy" and distorted issue. I have no idea what caused it.
looks like a bad convergence ic , try to adjusted if dont do snything , u have a problem with the convergence ic
Aug 26, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50609 - Red convergence is way off, suddenly
You have a bad ground on a convergence IC. You will have to carefully pull this board out and resolder the pins. If this does not solve the problem you will have to replace the ICs. I have saved a few of these TVs with just a resolder job. Thanks for asking!
Jul 11, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Blue shadow will not go away on Mitsubishi vs-50609
make sure there are no speakers sitting near yor tv the magnet in them will make the color change
Nov 16, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Red convergence is all messed up, won't let me adjust it up and down, but will adjust left to right.
Ur convergence is dead,U know how to solder right?Buy the convergence kit,replace what in that kit.This website have the kit.Tv Repair World.com.
Sep 30, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Distortion in top left corner
Ur convergence is dead,U know how to solder right?Buy the convergence kit,use what in that kit.Tries these websites.Tv Repair World.com,or Ebay.com.
Sep 21, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi Model # VS-50609
try to resolder the convergence amp ICs that may help if not the ICs may need to be replaced. Let me know if you need further assistance.
Jun 22, 2008 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS-50609 50" Rear Projection Television Logo
250 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
