Question about Viking Stove/Oven/Range Timer Knob - PB010185BK
Old Eaton Viking Stove - broil won't turn off.
Three timer knobs. One with clock and buzzer timer. One with running man underneath that pops out when time hits clock time and third has stop sign underneath and pops out as well. The third says push for manual. A guest pushed one of these and now every combination of turning and pushing these timers causes the broil and bottom burner to work. Or just the broil. There seems to be no way to turn of the broil.
  • 2 more comments
  • Anonymous Jan 06, 2009
    i am having the exact same problem, someone please help
  • Anonymous Mar 02, 2009
    same prob
  • jeffpowell41 Mar 10, 2009
    the timers are set up so the oven can cook and then keep things warm until you get home. My problem is the bottom heater in the oven won't turn on enough to heat the oven, its limited to keeping things warm. This has happened several times over the years and I've never been able to fix it without the instructions which are now in a file cabinet in a storage locker.
  • Anonymous Apr 09, 2009
    The 3 buzzers you describe are the same on my oven. Someone tried to use the timer and now the stove won't heat up and no amount of twisting and turning will get the oven to heat up. I was planning Easter dinner. Any help would be appreciated.
I have the same stove, and just had the same problem. I looked all over the internet to try to find an answer, and then went back to my stove to check the serial number and where the fuses are was the instructions printed on the stove itself.
SO HERE'S THE SOLUTION
1. The timer start knob (the one with little running guy picture) must NOT be pushed in. If it is, turn it slowly until it snaps out.
2. The timer stop knob (the one with the picture of the stop sign) must be completely pushed in.
I hope that helps everyone out!
Posted on Nov 10, 2009
Has anyone figured out how to fix this? experiencing same problem
Posted on Jun 28, 2009
Thats fantastic! thank you so much!
Posted on Jan 31, 2010
I had a similar problem. The solution was simple and had to do with the knobs as well. You have to make sure that "cooking" know is set to MANual otherwise the oven will not work.
Thanks for helping!
Posted on Sep 14, 2010
  • Tim McCoy Feb 18, 2013
    What is the "cooking" knob?
My clock does not work on my stove
Hi Jason. Have you performed the following actions?
Electronic Timing Center (Analog Clock w/Digital Display)
Synchronizing the analog and digital clocks
1. Press the "timer" and "start time" buttons simultaneously.
2. Turn the set knob to move the hands on the analog clock to any time setting.
3. After five seconds the display will go blank. Press the timer button and using the set knob, set the digital time to the exact time on the analog clock. This will synchronize the two clocks. You can now set the time of day.
Setting the Time-of-Day
The time-of-day must be set before any other program can be used. When your oven is first connected to the power in your home, the digital display will show 00:00. To program the time-of-day:
1. Push and hold the "timer" and "bake hours" button at the same time.
2. Turn the "Set" knob until correct time is displayed on the digital clock.
3. Release "timer" and "bake hours" button
The analog clock will automatically set after the digital time is set
Let me know so that I may follow up if need be.
Jul 14, 2014 | Viking DEDO205 Stainless Steel Electric...
Turn off the alarm eaton viking stove
This did not work for me. The alarm won't go off at all. The dial for the clock seems very loose - it stuck many times when I was turning the dial to change the time, and then it just got loose, and now the alarm won't go off. Please help!
Jun 14, 2014 | Viking Stove/Oven/Range Timer Knob -...
Eaton viking stove
You can date most of your major home appliances from the US and Canada at the following link.
Appliance411 Service How old is my appliance Age finder date of...
Jan 25, 2014 | Hardware & Accessories
I have a problem with my old stove VIKING EATON. i can't use it (i have no user manual). when i select Bake , only Broil works the bake the bottom element just warm (the element has no defects)but...
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Jan 19, 2010 | Kitchen Ranges
Replacing PB010036 Bake / Broil Thermostat Viking
you do not need to take apart any switches, all you need - unplug it from power, open front panel (2 screw on each side) remove all knobs, there is 3 more screws behind them). unscrew thermostat 2 screws behind knob. open top part of stove, remove grates and cover. you will see wires to thermostat unplug them and plug one by one to new thermostat. remove old thermostat from inside the oven (it has bracket inside). put the new one. close everything back.
appliancesrepairla.com - viking repair LA
Dec 12, 2009 | Viking VGIC485-6G Gas Kitchen Range
How do you set the analog clock?
My eaton viking imperial stove came with the house and no manuals. The timers are digial, how do i set them
Oct 20, 2009 | Viking 27" Professional Select Built-in...
Replaced the old element in the stove now the stove wont turn on
Check the wires going to the broiler and see if your getting power there.
Oct 03, 2009 | General Electric Stove/Oven/Range Chrome...
Stove oven wont work..
Yes, you can use the Eaton Viking element in place of the Gibson element as long as all mountings are the same.
You should use ceramic washers between the element and the casing to prevent it from grounding out...which is what probably happened to the element in the first place.
Be sure to look for chapped or burnt wiring BEFORE replacing the element. Also look for burnt connectors.
Hope this help you! :)
Apr 11, 2009 | Viking Stove/Oven/Range Timer Knob -...
Viking Stove/Oven/Range Timer Knob - PB010185BK Logo
2,972 people viewed this question
Top Viking Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Viking Hardware and Accessory Expert? Answer questions, earn points and help others
