Printing quality poor
I have small lines where there is a break in the ink running through everything I print. I have not used it for few months and have recently changed ink cartridges, so would it be something to do with this? It has alwasy worked fine in the past.
    Genius:
  • 2,120 Answers
Dried up ink cartridge, I have seen many new, dried up cartridges.
Posted on Dec 21, 2008
Hp officejet 6500 e709n print quality poor even after replacing print head
For severe print quality/missing color issues there could be an air bubble/air gaps in the printer ink lines or a portion of the PRINTHEAD is dry, so you should first perform a Clean PrintHead procedure from your printer control panel.
NOTE: If one or more the colors were previously dry fired during printing (i.e. if you continued printing using only a few colors to one, air may have been accidently ingested into the ink lines between the cartridge(s) and PRINTHEAD. To recover from this problem, you may have to run the Clean Printhead procedure 2-3 times.
If a problem persists then it is suggested to review the steps outlined on the following HP 920 support pages, including printhead removal/printer cleaning and service station cleaning. It is suggested you refer to printer manufacturer instructions first as the Inkjet411 procedures are provided for general guidance purposes only. A dirty service station can cause poor image quality and/or ink cross-contamination between different colors:
http://inkjet411.retailinkjet.com/?page_id=1495
If the problem still cannot be corrected, then the PRINTHEAD may be dry and may need to be flushed (i.e. with warm water as it could have dried out, but this is a function of how much you print). Remove and soak in hot water for 5 minutes...thoroughly dry printhead prior to re-installing. Retest.
For more information please visit:
http://inkjet411.retailinkjet.com/?page_id=856
Worst case scenario the PRINTHEAD may simply be electrically damaged or at end-of-life (typically fails between 3,000 and 5,000 printed pages) and may require replacement, usually accompanied by error messages like Incompatible Printhead or Ink Delivery/System Failure. NOTE: The PRINTHEAD will eventually fail in time. For more information on the how the PRINTHEAD works, watch the video here: http://inkjet411.retailinkjet.com/?page_id=1983
To verify Printhead performance, run the Tap 41 diagnostic test, (Pen Status: Pen OK).....for printer model instructions please visit:
http://www.Inkjet411.com
Sep 25, 2012 | HP Officejet 6500 Wireless All-in-One...
I have been told my printhead is malfunctioning. Can I clean it myself?
You can look in thr user guide or printer help for Troubleshooting and Routine Manteinance.Make sure that the Printer Driver or Paper Type setting in the menu matches the
type of paper you are using. (See Printing in the Software User's Guide on the CDROM.Make sure that your ink cartridges are fresh. The following may cause ink to clog The expiration date written on the cartridge package has passed. (Cartridges
stay usable for up to two years if kept in their original packaging.) The ink cartridge was in your machine over six months.The ink cartridge may not have been stored properly before use.
Try using the recommended types of paper.
CLEANING:
Press Ink.
Press a or b to choose Cleaning.
Press OK.
Press a or b to choose Black, Color
or All.
Press OK.
The machine cleans the print head.
When cleaning is finished, the machine
will go back to standby mode
automatically.
Checking the print quality
If faded or streaked colors and text appear on
your output, some of the nozzles may be
clogged. You can check this by printing the
Print Quality Check Sheet and looking at the
nozzle check pattern.
Press Ink.
Press a or b to choose Test Print.
Press OK.
Print Quality.
Press OK.
Press Color Start.
The machine begins printing the Print
Quality Check Sheet.
Check the quality of the four color blocks
on the sheet.
Is Quality OK?
1.Yes 2.No
Do one of the following:
If all lines are clear and visible, press
1 to choose Yes, and go to step j.
If you can see missing short lines as
shown below, press 2 to choose No.
The LCD asks you if the print quality is
OK for black and three colors.
Black OK?
1.Yes 2.No
Press 1 (Yes) or 2 (No).
The LCD asks you if you want to start
cleaning.
Start Cleaning?
1.Yes 2.No
Press 1 (Yes).
The machine starts cleaning the print
head.
After cleaning is finished, press Color
Start.
The machine starts printing the Print
Quality Check Sheet again and then
return to step e.
Press Stop/Exit.
If you repeat this procedure at least five
times and the print quality is still poor,
replace the ink cartridge for the clogged
color.
After replacing the ink cartridge, check
the print quality. If the problem still
exists, repeat the cleaning and test print
procedures at least five times for the
new ink cartridge. If ink is still missing,
call Brother Customer Service
Nov 03, 2010 | Brother Multi-Function Center MFC-240C...
I have a Brother MFC-210. It was working well. When I moved and hooked it back up. It was printing some pages fine and then it started printing double like 3d. Started with a few words. Now the whole page...
Check the alignment. Press the key for Ink or Ink Management on the Control Panel. Select Test Print (the up/down arrows) and hit Menu/Set or Set. Select Alignment and press Menu/Set or Set. Next hit Mono (Black) Start. Look at the Alignment Sheet that prints out. Press 1 if the number 5 sample matches line 0 for both 600 and 1200 DPI samples. Press 2 and then the number for the line that matches that matches the 0 sample.
Then press Stop/Exit. Repeat this for color printing by using the Color button.
You should also check the Print Quality. (Very similar menu choices - just choose Print Quality after choosing Test Print but you only need to hit the Color button to print the test sheet.) This will initiate a cleaning cycle for any poor quality ink test pattern. You will need to respond Yes or No for the print quality and each ink (if you answered No). If you do the cleaning 5 times with problems, replace the cartridges in question.
Finally try cleaning the printhead (Press Ink or Ink Management and then 1 for cleaning) If 5 repeats do not help, contact Brother support, the print head may need to be replaced. (Unfortunately, this isn't the only reason for the problem. Once you put in a print head, it isn't returnable. It could be that the entire printer is ready for recycling.)
I hope this helps.
Jun 24, 2010 | Brother HL-2040 Laser Printer
Why the epson stylus C86 dont print nothing?it makes noise like its print but on the paper nothing
***hi there,il be willing to help you on that. ****
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
Running a Printer Check
You can run a printer check to determine whether a problem comes from the printer itself or some other source.
1. Make sure both the printer and computer are turned off. Then disconnect the interface cable from the printer.
2. Make sure letter-size plain paper is loaded in the printer.
3. Hold down the paper button, then press and release the power button. Continue holding down the paper button until the green power light starts to flash, then release it.
If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the ink button on the printer for three seconds. (This only works when the red ink light is off.)
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality.
***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Feb 17, 2010 | Epson Stylus C86 InkJet Printer
Poor printing quality
Dear friend,
Just few tipe.
1. Try to use glossy photo quality paper for photo print out. which is look good and not so expence of ink.
2 Use good quality glossy type normal paper for text print out. that can not **** much ink from the cartriges.
3. try to cover your printer always.
4. clean the head via tst print oftenly.
Thnks & waiting for your feedback.
Jan 30, 2010 | Canon Office Equipment & Supplies
Does not print
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX100 Series. 3. Hold down the nx100_tx100_ug.1.96.1.jpg Stop button as you press the nx100_tx100_ug.1.96.2.jpg On button to turn the Epson Stylus NX100 Series back on. Hold down both buttons until the nx100_tx100_ug.1.96.3.jpg On light begins to flash, then release the buttons. 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx100_tx100_ug.1.96.5.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. If your printouts are unexpectedly light, or dots or lines are missing, you may need to clean the print head. This unclogs the nozzles so they can deliver ink properly. Print head cleaning uses ink, so clean it only if quality declines.
You can also clean the print head by holding down the stop button on the printer for three seconds. (This only works when the red ink light is off.) Run a nozzle check to confirm that the print head is clean.
Caution: When you don’t turn on your printer for a long time, print quality can decline, so turn it on and print a few pages at least once a month to maintain good print quality. ***if my troubleshooting steps are helpful, pls vote for me, i will appreciate it, so that I can be a part of fixya, thanks, Godbless****
Jan 10, 2010 | Epson Stylus NX100 InkJet Printer
Was printing in colour and suddenly the Magenta disappeared - there is still lots in the cartridge (both visually and according to the auto monitor
This sounds like your print head has clogged up on you. What you can do is simply run a few print head cleaning cycles and you should get your magenta again. It may take 5-10 cycles or more before it is printing again. You should find the clean cycle option in your monitor software. Run it a few times before you do any test pages. It will save a small amount of ink as it won't print properly at first.
The cause can be from either the printer not being used enough, or a ink that isn't compatible with other inks or even the print head picking up clay from poor quality paper. If you don't use the printer enough the ink can dry or gel. Incompatible inks can form a gel when they touch. If the print head takes up particles off of the paper it can form an sludge that also blocks the print head.
Sep 11, 2009 | Brother Office Equipment & Supplies
Poor color printing quality
do you have the canon print management software installed? it's located in the maintenance tab on that software.
www.canon.com has that by model number
Jun 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Blue lines running through my image
Did u use the original ink cartridges or compatible ones or refilled?
Jan 18, 2008 | Epson Stylus CX6000 All-In-One InkJet...
117 people viewed this question
jasbo
jasbo
