I have a tecnik dw2677 dishwasher which isn't washing dishes properly and keeps beeping once cycle is finished. We can only stop the beeping by switching the machine off. When we open the door the start buttin flashes 4 times in sequence repeatedly, what does this error signify please? Any suggestions much appreciated.
SOURCE: Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
SOURCE: The Tecniks dishwasher seems
Hi.
Try running a cleaning product to clear the rear pipes of any grease deposits.
If this does not work, check rear pipesare not kinked.
Hope this helps.
SOURCE: tecnik dw2677/2 how do i reset dishwasher it won't
Unplug and let it sit for an hour. Replug and then try turning it on. If that doesn't work press and hold the power button and then unplug and retry. If that doesn't work press and hold the power and cycle buttons together to reset.
