Question about Hobart N50 Stand Mixer
Year manufactored can you tell me what year my n50 was manufactured 1560143. I used to work for Hobart and had the serial number list, but can't find it. CUTBACKS! I do have the listing from ''1903-1945'' but doesn't help me here.
  • wadexdj Dec 31, 2008
    Thanks. I did contact Hobart and it's a 1965. Tring to refurbish. Now my problem is tring to find the old emblem for this mixer. Can any one help?
  • 135 Answers
If you call your nearest Hobart Parts place they can tell you. If they refuse this simple request, log on to www.hobartservice.com and look in the discontinued products menu, select Food Machines then Mixers and sift through the files until you find the documentation for serial numbers/dates. The lists are not complete and stop in the late 1980's. If you're lucky, you can find out which plant manufactured it, as the first two digits of the serial number indicate where it was built. The serial numbers are not in code, so it's relatively easy to get a date if you do the math. While you're there, download the manuals for parts and operation. You won't find the service manuals..."Top Secret"! Good Luck! Ricardok45.
Posted on Dec 30, 2008
  • Rick Belanger
    Rick Belanger Dec 31, 2008
    I'm going to assume that you asked Hobart Parts about the availability of the old logo. If they don't have it, ask bigg t, the Hobart Tech on this website. He would have the definitive answer for you. Good Luck! Ricardok45.
Trying to find the age of a Hobart Mixer serial number 1569386
Contact hobart directly, they tend to keep a record of machines, and would probably be able to as sit you
Feb 15, 2018 | Hobart Food Mixers
We need to buy some parts for Mixer N50, Please provide us part list easy to order from you.
www.hobartservice.com click on locate an office, enter your zip and it will show the office closest to you. They will be happy to sell you parts for any Hobart product.
Jul 01, 2010 | Hobart N50 Stand Mixer
Hobart N50 Service Manual
Ebay sometimes has used hobart manuals. maybe check Amazon.com?
There is no other source for hobart manuals other than the internet.
Sep 09, 2009 | Hobart N50 Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
Hobart N50 repair books
parts books are available at hobartservice.com for free and you might be able to find service manuals on ebay
Oct 22, 2008 | Hobart N50 Stand Mixer
Mystery part to a 1950 Hobart N50 Mixer; serial number 997185
Go to www.hobartservice.com, register, then go to select "food machines" in the Product Group, then "mixers"and look for the Discontinued Products, then find the N-50 mixer drawings, they are all there, even the old ones. Look through the "exploded" drawings for your extra parts. It seems to me that the tech who put this together should know if they belong to this mixer or not. Does he work for Hobart? Or is he a repair person who states that he knows how to repair Hobart products. If he does'n't work for Hobart, these parts may have been on his bench BEFORE he looked at your mixer. A true Hobart Tech has access to specs on ALL models and the ability to access the Service Manuals. If you find this solution helpfull, please rate it. ricardok45
Aug 20, 2008 | Hobart N50 Stand Mixer
How to find the age of a Hobart N50
Hi Anne. Call your nearest Hobart parts place. The parts guys will be able to tell you the age and which plant it was manufactured in in the USA. Another source is the hobartservice.com website, look for discontinued products under the food machines group, then select mixers and browse until you find the file that dates machines. One thing to watch for when buying is oil leakage that appears to come from the bottom of the stand. This indicates that the transmission grease is partially separating the oil out of it and it's leaking out of the rear bearing and dripping down. If the leak seems excessive, pass on the purchase. This drip could also indicate excessive wear on the bearings. Also run the mixer in all speeds, if is sounds like a tank approaching, it probably needs a rebuild.
Aug 17, 2008 | Food Mixers
Hobart N50
Some of the N50's were packed with a white grease. It tends to seperate. So the oil portion finds it's way out. It sounds like it is getting into the motor case, and is running down the inside of the column. Hobart now uses a brown clay based grease --- Darina 2.
If the amounts are small, and the mixer is not excessively noisy, I wouldn't be concerned. If you wanted to fix it, the transmission would need to be removed, cleaned, and repacked. For a Hobart tech, 3 hours labor, $45 grease, plus parts.
Jun 19, 2008 | Hobart N50 Stand Mixer
Hobart n50
I need the serial #,ml or spec # and the exact model #.Ill help you out.I can tell you right now from your description is the tumbler assembly is worn.
Mar 29, 2008 | Hobart N50 Stand Mixer
Hobart N50 Stand Mixer Logo
1,055 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
