Question about E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply
Computer will not turn on
I have an Emachine T5026. I shut it down last night but I cannot turn it back on. When I try to push (or push and hold) the power button absolutely nothing happens. Is this my power supply?
  • 2 more comments
  • rkbritton Dec 21, 2008
    I looked and looked and saw nothing that would resemble an led light...I assume I would be able to see the unlit led light if there was one.
  • karah_harris Jan 22, 2009
    My computer won't turn on,so i looked inside near the power supply to the motherboard and seen a green light was on.what other problem could this be if not the power supply?
  • vah215 Mar 25, 2009
    I have the same problem. No power but the led light is green. Now what?
  • vivbarnett Apr 30, 2009
    Count me in. Turned off one night, not available the next day. I also have the green light. Of course, warranty has expired and from other sites, the pre-pay support is of no help.
    Does anyone know if I can salvage the files in memory to a different computer?
    President:
  • 1,179 Answers
Best way to check is to open your case. Near the power supply plug to the motherboard should be a little led light. If it is getting power to the board this light should be green. If it's unlit then most likely your power supply has gone bad. Hope this helps.
Posted on Dec 21, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 21, 2008
    Yes you should be able to see it if lit. Usually it is near the main plug that runs from the power supply to the motherboard. It should be lit green if power is flowing between power supply & motherboard. Hope this helps.
Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply: my cpu fan is running but at a low speed. When i t...
In my opinion you have a faulty power supply, replacing only the fan may not solve your problem. Try replacing the power supply.
May 16, 2010 | E-Machines Emachine T5026 power supply **...
I have an emachine t5026 that won't turn on. It
There can be two problems with your PC. either the power supply is faulty which is highly probable, and the other is that your Motherboard maybe faulty or both things are faulty. Try replacing the Power supply first. It should solve your problem.
May 15, 2010 | E-Machines Emachine T5026 power supply **...
Emachine wont start
I just had the same problem. Try replacing the battery on the motherboard, that seems to have fixed mine. The number on the battery is CR 2032.
May 11, 2010 | E-Machines Emachine T5026 power supply **...
When I turn on my machine, I get 3 beeps and my monitor tell me no signal, the model is a T5026 emachine, please email me any suggestions
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 12, 2010 | E-Machines Emachine T5026 power supply **...
EMachine T5026 no boot
This just happened to my t5026. I had to replace the power supply to fix.
Mar 08, 2009 | E-Machines Emachine T5026 power supply **...
Lg pilot amd athlon system
How long are the beeps? If they are shortish then it suggests that the ram on your motherboard isnt working properly. Try removing it and reseating it. Make sure all the power is turned off before doing this.
Also there is a jumper located near the bios battery for resetting the bios. Move that to the clear position then back again after a minuter or so. That will put it back to default setting.
How did the problem start? Had you been adjusting anything in the bios at all?
Dec 29, 2007 | E-Machines Emachine T5026 power supply **...
E-Machines Emachine T5026 power supply ** FREE SHIPPNG ** (EM12EB324PIN) Power Supply Logo
569 people viewed this question
Top E-Machines Computers & Internet Experts
Steve Allison
Steve Allison
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
