Question about Whirlpool Duet GHW9150P Front Load Washer
My Whirlpool Duet Dryer is not heating up. Unit is only Two year
Dryer just started drying with cold air today.
  • tony_herbst Dec 21, 2008
    Sorry it's a electric dryer. Thanks for trying
Dyer event is pluged, pipe out from dyer to outside
Posted on Dec 22, 2008
    Problem Solver:
  • 11 Answers
If it is a gas dryer. Sounds like thermal fuse. It costs about $12.95. Most appliance part stores carry it all the time. Very easy to replace. Also can be ignition switch (also cheap). If you know someone who is mechancally inclined, after removing fuse,they can run an electrical jumper cord to the two open ends. If the dryer begins drying, then it is definitely the fuse.
Go to Whirpool site and get part number and diagram to fix. Maytag repair can help at a costly figure after they order part since Whirpool bought Maytag.
Posted on Dec 21, 2008
  • jmjarmon Dec 21, 2008
    Then, it's probably the heating element. An easy fix and under $50.00 to fix yourself. It's very similar to pulling out the electrical element on an electric range.
Clothes dryer overheating?
use your dryer on air dry only (not heat dry) run about 2 min. check if your dryer is hot, that is heating element is short to ground and if your dryer is cold, check your dryer air venting system. (open the door if you see lint on door panel, it is a sing of bad air flow, it is dangerous to fire) hope its help.
Jul 10, 2014 | Whirlpool Dryers
Whirlpool Duet Steam is not heating to dry any clothes
Don't have your model so I couldn't bring up the schematic some will run with an open thermal fuse I suspect thermal fuse which is non resettable I've only run across a bad thermistor once based on the age check the exhaust exiting the house and at the dryer this a safety fuse designed to open due to excessive heat if the dryer cannot breath restricted exhaust.
Jan 21, 2014 | Washing Machines
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
My whirlpool duet dryer works but it appears that the air is not evacuating from the baril. The heat and humidity built up and the clothes don't dry. Do I need to replace the fan and if so, how
YOU NEED TO CLEAN THE VENT ON YOUR HOUSE IF THE BLOWER WHEEL IS BAD ON THE DRYER YOU WOULD HERE THE NOISE AFTER THE DRY STOPS THE BLOWER WHEEL WILL STILL TURN AND MAKE A NOISE
Oct 29, 2012 | Whirlpool Duet Steam WFW9700V Front Load...
Dryer stop heating
Try vacuuming out the intake and exhaust vents for the burner. Lint collected there can block the burner operation. Hope this helps!
Jun 28, 2010 | Whirlpool LGB6300 Gas Dryer
My Whirlpool Duet shrinks my clothes.
If you did not have good success with the unit - I would advise against getting another one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet electric dryer taking too long to dry
A1 Pull the dryer out away from the wall. Unhook the vent from the dryer completely. Do not put anything over the dryer exhaust on the back of the dryer. Do a normal load with the vent unhooked. If it dries better or ok like this then the problem is in the dryer venting. Like a blocked vent pipe or a smashed or restricted vent hose.
A2 - If the vent  doesn't make a difference, then check the blower wheel for excessive lint build up, check that there isn't anything stuck to the air intake baffle inside the drum, (i.e. the screen on the back wall of the dryer when looking into the drum). Check the lint filter chute for blockage. Check that the heating element isn't shorted to ground. Check the exhaust temperature of the dryer. A meat or pocket  thermometer can be used for this. It should cycle between 120 degrees and 170 degrees. Check that the drum seals to make sure the are not worn out.
Mar 03, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Duet front loader dryer
Check the lint trap and the vent. If the vent is clogged or crushed in anyway then replace it with a new dryer vent.
There reasons why a dryer will not dry clothes:
Clogged Lint Trap
Crushed or clogged vent
Last but not your issue, not getting and heat to the unit due to glow ignitor bad or no gas supply or bad gas valve.
So check what I told you and this should fix the problem right away
Feb 09, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Dryer not drying
look at the vent outside and see if it closing or even has a cover this allows cold air inside the dryer and cause it to take longer to dry
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
780 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
