Question about JVC HR-S9400 S-VHS VCR
VCR goes into standby after powering up and going through its initial checks
When turning on the VCR it will go into standby. When the power is turned on it goes through its routine of checks and then goes back into standby. I took this VCR to a friend of mine who used to repair VCRs and he tells me its the main processor in the VCR that has broken and I need a new one. This processor is apparently a silver square thing (bit bigger than a postage stamp) on the ICB that is apparently held in by some 30 pins and you need a special piece of kit to remove it? Anyway, what I could do with knowing is what this is called, both the actual name and the id number I need to order from JVC. Incidentally, my friend did all the checks on belts, motors and all that good stuff, and they were all working fine. Really appreciate any help as it's a nice VCR and has seen little use, especially since this problem occurred! ;-)
Hi
problem:-
solution :- there is a cluster of IC protection fuses on the main
power board underneath. These fuses look like transistors ie black semicircular body. These components are linked to the
direct drive motor. The component in question is the IC protection fuse named CP801. It is a 2 legged component
classified as an N20. This means it is an 800mA semiconductor fuse. Calculated 20 x 40mA = 800ma.
The problem is this component becomes open circuit (blown fuse).
Suppliers class this as an IC protector fuse ICP-N20.
These components have been used on JVC boards for years.
Possible reasons for fuse blowing could be as loading tape the tension on tape my require a higher load being pulled from the motor, so knocking it over the threshold of the fuse.
Mine blows once every 5 years. I think a common problem.
hope this helps
Ali from Coventry . - England
Posted on Jul 20, 2008
Problem is easy the component cp301 to dd motor has gonr open circuit. replace it. fixed my unit
Posted on Jun 20, 2007
    Genius:
  • 1,074 Answers
That square thing called processor is a IC the number is written on the top of the case just write down the number and order it by the same number.good luck
Posted on Apr 05, 2007
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at askOnkyo@us.onkyo.com, Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
A-SV640 KEEP GOING TO PROTECT MODE
Hi, try powering up the unit with out any speaker connected if it still goes to PROTECT try factory reset if possible.
To reset the AV receiver to its factory defaults, turn it on and, while holding down VCR/DVR, press ON/STANDBY. "Clear" will appear on the display and the AV receiver will enter standby mode.
If this does not fix your problem you should take your unit to service . :)
Dec 12, 2012 | Onkyo Audio Players & Recorders
Should I turn OFF thew recorder after I set it to time record??
No,u can't turn off power the VCR.Than there no power to the VCR,it not on,only on standby power.
Oct 06, 2010 | Toshiba W522 VHS VCR
TV on Standby
There is a Sony S3000 protect blinks table:ebf219b.gif
May 27, 2010 | Sony KDL-32S3000 32 in. LCD Television
TV will not turn on
Hey guys this one is a no brainer when you push power button AND STANDBY LIGHT COMES ON NEXT PUSH THE BUTTON ON THE LEFT NEXT TO POWER BUTTON AND WALLA IT TURNS ON
Nov 11, 2008 | Televison & Video
Unit won't turn on, goes into standby, flashing "auto"
The mechanism is not "shutting" when power is applied. This step is necessary for the unit to operate. Would suggest a complete belt replacement and cleaning....accordianman
Apr 26, 2008 | JVC HR-S9500 S-VHS VCR
The camera function will not work
Hey Uttado,
Check to see if the stanby lever that surrounds the record switch on the back of the camera has inadvertently been put on standby. If this has happened, the VCR will work but not the camera. Move it off of lock to standby and it should crank right up.
Apr 10, 2008 | Canon GL1 Mini DV Digital Camcorder
VCR automatically goes into standby mode
If this unit shuts down after you turn it on, it is going into stanby because the microprocessor is not seeing the proper pulses from the mode switch. this could be due to an out of time mechanism because of a broken gear, bad mode switch, the loading basket is out of time or broken, or the capstain motor or the cylinlinder motor is not sending the PG and FG pulses to the microprocessor. These can also be due to a power supply voltage missing. You can check the voltages with a service manual and make sure they are not low. You will also need to get the mechanism manual and check the timing of the mechanism. Then check the mode switch you can get a manual from here http://www.servicemanuals.net/results.aspx?brand=15&model=HRS&type=SM&pos=281 Good Luck
Mar 21, 2007 | JVC HR-S9900 S-VHS VCR
JVC HR-S9400 S-VHS VCR Logo
265 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
