Question about Karcher 2500 PSI Pressure Washer
I have a snowblower that will only start if I remove sparkplug
I have a snowblower (older model) that will only start and run if I remove the sparkplug and add a small amount of gasoline into the chamber. Once I have added the gasoline, I reinstall the plug and it starts on the first pull. It runs great until I stop it. Then I have to repeat the same proceedure.
  • stevecgillin Mar 23, 2009
    Having same problem on moto-mower snowblower. will try the additive also. thanks.
  • 359 Answers
Posted on Dec 23, 2008
C950-52474-6 snowblower starts but don't stay ignited
Many small engine problems such as you described are fuel related. In today's world, most of our gasolines are blended with ethanol and thus gasoline shelf life has been reduced to 4-6 months. It is important that after each season's use you be certain to run the snowblower until all gasoline in the tank and carburetor have been used - effectively running the snowblower out of gas. If you did't do that last season the "old" gasoline in the carburetor has began to gum up and will not let the carburetor mix fuel and air properly. The solution will be to remove, disassemble and clean the carburetor. It is likely the gas tank will also need to be drained, removed, and cleaned. If you are unable to do this you will need to take to a qualified small engine mechanic in your area.
Lastly and, very importantly, make certain when you are ready to use your repaired snowblower that you use FRESH gasoline. And, remember the first part of this discussion at the end of the season.
Nov 04, 2013 | Tecumseh Snowblower Snow Blower Starter...
My 1996 chevy blazer won't start. we changed the the fuel pump, fuel pump filter checked the relay and she turns over once we put gas in the carb. body. help please
Have you ever put in the gasoline tank any injector cleaner yet because the cleaner will unclog the injectors so full amounts of gasoline can get into the piston chambers the right amounts so try putting injector cleaner into your gas tank. When you put this into the gas tank to remember that it takes time for the cleaner to get to the injectors so you might have to keep trying to start the vehicle many times for the cleaner to unclog the injectors. This will not hurt your vehicle at all so go try this.
Jun 11, 2011 | 1996 Chevrolet Blazer
I just purchased an Ariens 921022 Deluxe 28 snowblower. It was recommended that the oil should be changed after running it a short time. I can't find how much oil to put it. I do not want to over fill it.
Hi, my suggestion to you is to check the oil level with the dipstick to find out what the level is. Start it up and let it run for awhile to warm the oil so it is easier to remove. Once you have the oil out, put it in an empty oil container to give you the right amount of oil to replace. They usually take a bit more than 3/4 of a quart or liter. When you feel there is enough oil, check the level on dipstick and add in small amounts until at right level. Hope this is helpful. Best regards and good luck.
Feb 04, 2011 | Garden
I have a Husqvarna snowblower, model 9027ST, that is 5 years old. I can not get it to start. It has not been used in awhile. Any suggestions? Thank you
When gas engines haven't been started in a while, the gas tends to gunk up. This is due to Ethanol being added to today's gas.
You will need to drain the carb bowl and clean it. Drain the fuel tank and refill the fuel tank with, fresh, Premium gas (no Ethanol additives) and add Sta-bil to the fuel tank - add the recommended amount to the fuel tank. Run a full tank through the system. When refilling the tank again, use SeaFoam additive. This can be obtained from Wal-Mart or your local parts house. Follow the directions on the can and add the recommended amount to your fuel tank. Start the engine and let it run for approximately 5 minutes and then shut it off. Your Snowblower will be easier to start the next time you use it. Always use Sta-bil if your engine is going to sit for any length of time.
If you find this information useful, please vote on this post.
Jan 11, 2011 | Husqvarna SM 450 R Motorcycles
I am trying to start my engine on my 1985 4runner it turns over but doesnt catch on.. what should I do..
'85's mostly had 4 cylinder engines, 22R, 22RE and 22REI. Remove a sparkplug wire and stick a sparkplug into the end. Hold the sparkplug, preferably with a well insulated glove, against a good metal part (exhaust manifiold will do, no paint or rust) nearby being carefull to stay clear of the fan. Now have someone turn the key and when the engine turns, see if a spark is jumping across the sparkplug your are holding...snap, what you should see and hear. If not, your ignition is not creating spark. Remove the center wire of the distributor and try to put the sparkplug on the end of that wire and repeat the previous test. If you get spark that means the distributor cap is not transferring the spark thru it to the wires that go down to your sparkplugs. Remove and replace the distributor cap and the rotor inside paying special attention to mark the wires and where they plug into the cap. The rotor only goes on one way, same with the cap. If you dont get spark coming to the center wire of the distributoe cap your ignitin module may be bad, a good time to have a shop run a test on it. Before heading to the shop, be sure to check your fuses. Maybe you should do that first as it is the simplest. If you have spark at the sparkplug and still no starting, a small amount of gasoline poured into the intake ( please dont pour a cup of gas into it! Just a spoonfull or so). With the sparkplug wires inplace, crank the motor. If it kicks and then goes back to cranking with no results, your fuel isnt getting to the intake. Could be a fuel pump (common) or a plugged fuel filter. The filter is easy, replace it. To test for fuel pressure you will need to locate the fuel line coming to the intake, carburated or injected, the inlet can be loosened and have someone turn the key on and you should see some fuel leaking around the fitting you only loosened. DO NO REMOVE IT-JUST LOOSEN. If you have fuel pressure your problem needs a mechanic. If no fuel pressure it's time to check the fuel pump thru the access panel under the backseat. BE SURE TO TIGHTEN THE INLET FUEL FITTING AT THIS POINT. Good luck.
Apr 09, 2010 | 1985 Toyota 4Runner
Ford 2001 v6 escape Engine locked up, rotated engine manualy back a half turn try starter and locked up again . Rotated back a full turn and engine started but is running on 3 cylinders, Could this be a...
engine lock could be the result of unburned gasoline inside chamber can't compress liquid.remove all sparkplugs try to crank the engine severaltimes.disc
onnect hitension wires so no high voltage is might as well check the compression on each cyl.form here you can as well conclude if it is a timing problem
Jan 15, 2010 | 2001 Ford Escape
I need a manual for a snowblower craftsman 10/30 it doesn't start,i changed the sparkplug and it doesn't chage anything,i change the oil last year,does it need to be changed this year to
Most common problem with snowblowers is clogged carb. Remove spark plug and put a tea spoon full of gas in the plug hole and try to start. If it starts for a sec that is your problem. To get a manual go to you will need the model number to find the correct manual. Model number should start with 917.XXXXXXX.
Dec 11, 2009 | Craftsman Garden
It hasn't been used for one year and wont start
You've likely got bad gas, that is the gas has thickened and has caused the carb and fuel components to become glazed or shellaced. In order to get it running again, you need to completely clean out the fuel components.
Drain the old gas out of the tank and leave cap off for a day to evaporate any residue. Get a can of carb and injector cleaner and spray the tank with it to loosen any crud in it. Also remove the filter cover and really spray the intake port of the carb to the point that the fluid is running out.
Now drain the tank and look to see if there is any buildup that didn't get flushed out (use a flashlight!!!)
Remove the spark plug and spray the cleaner into the combustion chamber for several seconds, getting a good amount of cleaner in there. Put the plug back in, but DO NOT connect the sparkplug wire!!! Now pull the starter cord slowly to flush the cleaner out the carb and out of the combustion chamber. Do this until you have gotten most of the cleaner out. Make sure the sparkplug is clean and properly gapped (see owners manual for specs) or just buy a new spark plug.
You can now put everythig back together and put a small amount of the proper gas and oil mix into the gas tank and follow starting procedure, (choke, throttle on full, kill switch to "run" position, etc.) and start the saw. If this doesn't work, you might have to find a small engine repair shop to service the saw, but frankly, I've been able to get 99% of small engines to work after a good, complete cleaning and a new plug.
Hope you find this Very Helpful - Best regards!
Aug 16, 2009 | Ryobi Garden
Car run with water
i assume you are asking how the water add on kit works? basically a reverse osmosis system converting water from h20 to hho 2 parts hydrogen to 1 part oxygen. this is the theory. and a little water will cool the cylinders down and fuel will also cling to it. I dont know if it really works or not. I have seen some older cars rig up a water bottle that sucks a very small amount and car runs better for a while but this is due to the water breaking up carbon in combustion chamber
Feb 10, 2009 | Pontiac Sunbird Cars & Trucks
4 cycle snowblower wont start
clean the carb's insides. It's probably gooped up with gummy gas. I like B-12 Chem Tool. Its a spray cleaner from Auto Zone about $4. Others kinds are ok but this is good stuff.
Dec 24, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
139 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
