HP 4380 printer. I changed ink cartrige and now printer says there is a carriage jam. There is no jam, but cartrige holder will not return to normal position.
Can you confirm that the lid for the ink cartridge carriage is properly closed (if it has one)?
Does it appear that the cartridge may not be inserted all the way in place? It should click into place.
Please also check the the cartridge's (usually yellow) tape has been removed before insertion.
Posted on Dec 29, 2009
Hp 8180 says carriage jam but there is nothing in there and makes a loud grinding sound..
Look at the thin plastic strip when you open the printer. It may have an ink smudge on it. Use a cloth dampened with water and GENTLY wipe both sided of that strip, moving the cartridge holder across and wiping the entire strip. Then try again. That strip has little lines on it which signal the electronics where the carriage is. If any ink gets on it, the carriage can't count the lines and a jam will occur.
Jan 14, 2011 | HP Photosmart C8180 All-in-One InkJet...
Canon printer ip4700 can't replace ink cartriges holder does not stop at the right place
force carriage to one side fully with power off, this might reset carriage sensor and get it to go back where it needs to be to change ink.
Oct 19, 2010 | Canon iP4700 InkJet Photo Printer
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
Where is the ink cartrige in Canon MP240 located in printer?thank you
Lift the scanner up, then you will see the carriage holder moving to left side. After that you will notice the cartridges are inserted with the carriage holder.
Jun 10, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Clear carriage jam
The carriage assembly is what the ink cartridges moves on. The silver bar that runs through the cartridge holder must be oiled. Put two or three drops of thin oil oun iether sides of the cartridge holder. This should clear the "carriage error"
Good Luck
Apr 15, 2010 | HP PSC 2210 All-In-One InkJet Printer
Carriage jam after putting in new print cartrige
Make sure that the printer cartridge has been placed in the holder correctly. If it isn't you might find it fouls the carriage as it tries to move.
Jan 12, 2010 | HP PSC 2410 All-In-One InkJet Printer
I am receiving an error message on my HP Officejet 6110 printer screen that prevents the printer from functioning. The message is "Open door. Clear carriage jam and then press enter." I've tried opening...
yes, that is a carriage jam and not paper, the grinding is from the clean station that gets blocked with dried ink and cant move. you need to open the printer and clean the ink off of the clean station so it can clean properly and not cause a carriage jam.
Jun 29, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Carriage jam
ouch! take the ink cartrige out and put it back in.
May 15, 2008 | HP Photosmart D7360 All-In-One InkJet...
"Clear carriage jam" persistent error...
I got the error message about clearing the carriage and no matter how many times I turned it off, unpluged, turned in on again, checked for paper jams, etc, the printer could not get reset. But after much trial en error, the following procedure did the trick: Unplug the power cord and open the door. To the right side, you'll see the ink tray. Carefully pull it to the center and unistall the ink cartriges. Close the door, plug in the power cord and turn the printer on. It should ask you to install the left ink cartrige first. Do it and close the door again. Then it'll ask you to install the right cartrige. Do it as well and turn the printer off again. Turn it back on, let it initialized, and your printer should be ready to work again. I hope this work for you as it did for me. Good luck.
Feb 08, 2006 | HP OfficeJet 6110 All-In-One InkJet...
k24674
jasbo
jasbo
Marvin
Marvin
