Question about Dryers
Dryer sounds like metal on metal when opertating
  • 3,463 Answers
From what you say, I would say that the front or rear drum bearings are worn, it is going to invvolve a strip down to determine which.
Posted on Dec 21, 2008
My dryer sounds like there are metal balls rolling around inside when clothes are drying
Sounds like the rollers are worn out. If they are fine then see if the dryer has glides on the drum.
Apr 23, 2014 | GE Profile Wizard DPSE592EAWW Electric...
Miele t8322
I would suggest the limit switch sometimes located on the metal vent tube inside the dryer. The metal tube/pipe that exits out either the side or rear is the one I am referring to, has a high limt switch attached with 2 screws, sometimes this causes an open circuit.
Nov 03, 2013 | Ovens
Dryer drum makes a scraping metal sound
bushings at edges front and back are bad front ones are long and flat rear one is a small short plastic sleeve over center shaft. requires ordering parts from manufacturer and almost total disassembly
Dec 29, 2012 | Dryers
I turned the drum of my dryer by hand and I heard a load metalic sounding thud (like something dropped metal to metal) Know my dryer drum does not turn.
It sounds like the spring which tensions the idler pulley has come off the bracket. You'll need to locate it and put it back on.
Jul 26, 2011 | Maytag Centennial 7.0 Cu. Ft. Super...
No heat during opertions
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 28, 2011 | LG D5966 Gas Dryer
ED 56 Dryer Scrapping sound like metal on metal when the drum spins
Most dryers are supported by a bearing at the rear and teflon pads at the front. Sounds like one of the pads is worn out leaving the drum to ride on the metal frame. The bearing can also make that sound if it breaking down. Most dryers have enough play that you can lift the drum and turn it. If the noise stops then the pads are bad. You can usually find them at most dryer wholesale or online appliance part stores.
Apr 12, 2011 | Fisher and Paykel Dryers
Dryer sounds like metal rubbing, drum in a bind. The drum is turning, but making a sound, like metal to metal, especially when it starts up.
You have a bad drum bearing. When it heats up the sound goes away slightly. When the drum bearing goes bad it tilts the drum in the front and it is rubbing on the metal front. Check the seal in the front. You could use lub spray but that is only preventing the inedible-replacement. Good luck.
Jul 10, 2010 | Crosley CDE6000 Electric Dryer
High pitch squeal-metal on metal contact
A lot of dryers have plastic or felt slides on the drum. This is to reduce friction as it rotates. They are probably worn off.
Dec 24, 2009 | Maytag MDE4806 Electric Dryer
GE GAS DRYER DDE7500G
Can you push the drum up and down. If so then the main bearing has gone bad and needs to be replaced. This is the only metal on metal rubbing you will get unless the machine is off balanced. This is caused usually by doing to heavy of loads and wearing out the bearing
May 22, 2009 | GE DPSR610GGWT Dryer
Laundrette dryer producing no heat
Change out the igniter
Diamond Service
Apr 02, 2009 | LG DLE7177 Dryer
Dryers Logo
82 people viewed this question
Top Dryers Experts
