Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
I have the upright kenmore progressive with direct drive and the filter canister stops bringing in air and picking up when hose is put into vaccum, when you remove hose and use as an attachment it starts again
    Problem Solver:
  • 10 Answers
Check the hose after the brushes. With this problem there is normally a clog in between where you disconnect the hose (to use attachment) and the brushes that clean the carpet.
Posted on Jan 14, 2009
Eureka Maxima 12 amp vaccum cleaner is not picking what can be done to make it pick up?
remove and clean the filter ( tap and brush filter or use a air compressor to blow out filter ) --- also check the vacume hose near the floor attachment for any dirt and debris that may be clogging the line. this should bring your vacume to full operation.
c...
Jan 22, 2011 | Eureka 4700A Maxima Bagless Upright Vacuum
Vacuum has new bag but won't pick up dirt. Cleaned flat filter and it made it worse. Do I need to replace rectangular filter or can I clean it. If so , how? If not, do I need to take it in for repair, ir...
It's clogged somewhere. Disconnect the hoses where you can and check for obstructions. Run a coat hanger down the hose if you need to to clear the obstruction.
Jan 02, 2011 | Kenmore 31913 Progressive Direct Drive...
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive with direct drive model 116.36923502 stopped picking up debris and empted it into the floor and is there something you need to do to switch from floor to using the hose. It does not...
sounds like you have a clog in your hose, full bag, or dirty filters. take the bag door off and feel inside at the bottom for suction or air movement. if you have suction there chances are its a clog in the hose. You can use a coat hanger or something similar to reach into the hose just be careful not to puncture the hose. First just try turning the unit on and stretching the hose as far as you can. try to feel for a clog and try to free it with the hose stretched.
Jan 22, 2010 | Kenmore 31913 Progressive Direct Drive...
The vaccum doesn't pick up dirt, it sprays out
There is probably a second or third filter (besides the canister) that needs to be cleaned.
I doubt that it's rotating the wrong direction.
Apr 25, 2009 | Dirt Devil M084600 Dynamite Bagless...
Kenmore progressive/direct drive-- roller stopped turning
We have the same vacuum & had the same problem. As the vacuum ages & the hose is periodically removed from the nozzle to use with the attachments, the white switch, adjacent to the nozzle connection, wears. If the hose is not fully reinserted or if the attachment notches are inadvertently aligned with the white stitch, the agitator may not work reliably. Assuring the hose is fully inserted, with the locking notches away from the switch has eliminated this problem with our vacuum cleaner.
Jan 24, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
125 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Marvin
Marvin
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
