Question about HP Compaq WF1907 Monitor
Hp monitor 1907w. Stand makes monitor bend over. how to straighten?
    Sergeant:
    Champion:
  • 271 Answers
Hit the auto adjust button in the monitor
Please Don't Forget To Rate "FIXYA" Me For The Help
Posted on Dec 21, 2008
How to solve the acer monitor black screen orange stand by light issue
Hello, your VGA Cable, HDMI Whatever cable you use to make your monitor show screens, you must make sure the VGA (only) is securely secured into the socked and screwed in, sometimes the little rods inside may be bend and this can cause this to occur. HDMI cables may not work do to it being broke ect. Same with VGA.
May 01, 2014 | Computers & Internet
Can we remove stand from monitor HP 2010i
Dear yes you can remove stand of HP monitor with the unlock behind the monitor near stand neck.
Thanks
Firoz Ali
Apr 28, 2014 | Computers & Internet
PC is not communicating with the monitor.
Are you using the DVI or VGA cable? You might try the other if both are supported by the computer. With the VGA cable, it's quite easy to bend the pins within the plug. Unplug the cable and look at both ends to see if the pins were bent during insertion. If so, you might be able to straighten the pins with needle-nosed pliers. The carefully plug in the cable again.
Nov 06, 2013 | HP Pavilion p7-1417cb Desktop AMD...
The screen is yellow sometimes it will go back to normal but only for a few seonds what would cause this?
Hi
Properly due to a bad connection to the monitor, theck the cables, or try another cable.
Mar 13, 2011 | HP Computers & Internet
Sir I have a problem. While I'm playing call of duty modern warfare 2 in the middle of the game.... then. the monitor HP 1907w sleep. I do not enable the sleep mode. What is the solution? my video card is...
Are you sure it went to sleep or just went dark
I had exactly that problem and it turned out to be a backlight problem
I had to dismantle the monitor and look for dry solder joints on the cards and now its OK
Oct 08, 2010 | HP w1907 LCD Monitor
Hp 1907w monitor locking up
Go into the monitor menu and choose factory reset....Make sure the resolution is set correctly. (see here.)
You might want to run My Display, or install it if you haven't (See here)
Make sure the latest drivers for your os are installed. See here and here., and this tutorial for updating your video card or graphics adapter.
I've seen some reports in the forums about sleep problems on these, but the cause could easily be the pc. If you can, switch monitors to confirm the fault to be with either the pc or the monitor, and try the monitor on another system...
That's all I can offer you right now, as the HP site seems to be having trouble this evening...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 30, 2009 | HP w1907 LCD Monitor
Hp computor says check cabel
if your connected to the modem or router via a cable, check to make sure there are no kinks or bends in it, if there is straighten it out the best you can, if it's tightly coiled up, loosen it up, let it lay down on it's own naturally and work with it that way, sounds like it's got sharp bends and kinks in it....good luck....shia
May 28, 2009 | HP Pavilion dv6000z Notebook
1907 Monitor Stand
for the hp x1907 we purchased recently there is no release it is just really hard to straighten, it has to be tight because you wouldn't want a wobbly stand
Sep 13, 2008 | HP Compaq WF1907 Monitor
My hp desktop screen is purple and not sure what to do i checked to make sure all the plugs are tight any ideas?
plz check if there is any speaker,ups etc near the monitor,if yes then remove it. plz check the cable in the pc from monitor is there any bend pin, if yes then gently straighten it.if every thing fails then your monitor needs servicing
Aug 12, 2008 | Computers & Internet
HP Compaq WF1907 Monitor Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
