Wood burning stove does not draft propery - Heating & Cooling
  • jeremy h Dec 21, 2008
    just put it in within the week. It is a used wood stove. we installed it and bought chimney parts. everytime you use it is smokes to beat all.
  • Stephen Evans May 11, 2010
    Is the chimney obstructed, when is the last time you had the chimney cleaned? Steve
  • 69 Answers
If you have a tall chimney like i do, i use a hair dryer or heat gun to preheat the chimney. Since cold air is heavier it will push the smoke into the house until the chimney is warmed up enough.
Posted on Dec 21, 2008
  • 700 Answers
Tyr opening a window and see if that helps. Todaays houses are built to be tight as to no air coming from the outside into the house.
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Where is the damper on the stove? Mine is the 1001 mode. I got a used one.
the damper is a flap in the flue ( chimney) that restricts the up draft from the fire
it's purpose id to restrict the air flow through the fire so that it tends to smolder rather than burn bright
look for a simple pull or handle around the back at the base of the chimney of stove
Nov 13, 2015 | Home
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Can I burn wood in a gas fireplace if the gas is not on?
No, the gas liner is not adequate for solid fuel, it won't draft properly,
Dec 08, 2014 | Home
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
I bought a house with a wood burning stove but I don't know how to operate it
First make sure everything is clean,from the chimney to the stove.insure all metal flues are tight from stove to chimney. Open damper on top of stove(some are in metal pipes). Open your draft vents, usually on clean out door at bottom. Depending on chimney draft you may need to open clean out door to get it started. Load your kindling and get it started. Add bigger wood as it catches. Turn down venting and drafting as the fire roars. Just don't shut draft before vents. You'll get used to balancing draft and vent as you go. I hope this helps
Nov 19, 2014 | Home
Wood stove problems
Appliances that can draw air out of your house, like the clothes dryer, air exchangers, bath and kitchen fans can cause a negative air pressure issue. The combination of a cold chimney flu and barometric pressure can also cause a down draft.
Install a Carbon Monoxide Detector in your house when using any fuel burning appliance. Be informed about the dangers of Carbon Monoxide Poisoning.
Amazon com carbon monoxide detector Electronics
http://carbonmonoxidedetectoralarms.com/
Mar 02, 2014 | Monessen Dutchwest Series Wood Burning...
How is air supply regulated in wood burning stoves?
To regulate air flow, there are damper devices built into the stove, flue and stove pipes. Keeping the air flowing correctly through a wood-burning stove is essential for safe and efficient operation of the stove. Fresh air needs to enter the wood compartment to provide oxygen fuel for the fire; as the fire burns, the smoke must be allowed to rise through the stove pipes, and exit through the chimney.
May 07, 2013 | Home
Wood burning heater when putting wood into stove lots of smoke comes into the house when door is opened.
It ain't drafting right or you have the damper closed. Look for obstructions in the smoke stack.
Wood burning tips
  • Burn only wood. No garbage, plastics, rubber, paint or oil, briquettes, paper, etc. Burning these items releases harmful chemicals into the air.
  • Burn Wise Program from EPA: Emphasizes the importance of burning the right wood.
  • Build small, hot fires instead of large, smoldering ones.
  • Don't "bed the fire down" for the night. Holding a fire overnight is a fire hazard and can create serious indoor and outdoor air pollution problems.
  • Open your damper if the smoke is dark. Dark smoke indicates more pollution is being produced and fuel is being wasted.
  • Keep your stove clean and well-maintained. Follow manufacturer guidelines; replace catalytic stove filters every 1-4 years. Have your chimney checked and cleaned at least once a year.
Use seasoned wood The best fuel for woodstoves is dry, "seasoned" wood. Seasoned wood has a moisture content of about 20% or less. It tends to be dark in color, cracked on the ends, light in weight and has bark that is easily broken or peeled. Here are some tips for preparing seasoned wood:
  • Split the wood to help it dry. Wood will dry out more quickly and burn best if the wood is cut to about 3 1/2 inches to 6 inches in diameter.
  • Cover the split firewood to protect it from the weather and stack it loosely in alternating layers, at least 6 inches off the ground.
  • Time must be given to allow the wood to reach 20% or less moisture required for seasoned wood. This process takes approximately 6-12 months. Think ahead and buy next winter's wood well in advance.
It is recommended an annual chimney cleaning to remove creosote build up and to identify potential problems. Things to consider:
  • The Chimney cap may be plugged by debris.
  • Catalytic combustor and baffles are exposed to very high heat and deteriorate as used. Replace every 1-4 years depending on use.
  • Stovepipe angles and bolts are subject to corrosion.
  • Gaskets on airtight stove doors need replacement every few years. Gaskets and seals are used by the appliance designer to control the location and flow of air into the appliance.
  • Check seams on stoves sealed with furnace cement. Seams may leak and cause you to loose valuable heat and reduce the efficiency of the unit.
  • Replace broken or missing firebricks.
  • Keep the floor of your stove clean of debris and ash.
-from the web
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 02, 2010 | Heating & Cooling
I have a wood burning stove & the lined chimney is blocked. I think totaly, possably caused by a sweep compacting a tar build up. How can I unblock it, there is no draft what so ever. Martin
Dont use the stove.You must have the chimney/smokepipe checked from the roof down.Very messy & dirty job.Martin call in the experts.
Mar 22, 2010 | Heating & Cooling
Heating & Cooling Logo
134 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
