Question about Intel D102GGC2 Motherboard
Slow speed+hard disk
I have p4 intel Murcury 845 with sd ram 256+256 and hard disk 80+40 gb but i want 160+80 gb hard disk. Mother board will sport Give me advise processoer 1.7 thank you
    Sergeant:
    Champion:
  • 271 Answers
Problem not clear enough
Please Don't Forget To Rate "FIXYA" Me For The Help
Posted on Dec 21, 2008
I've zebronic 845 gl mother board, p4 2.4 ghz intel processor, samsung 80 gb hard disk,256mb hynix ram. when i run any program in windows xp sp2 , my system is hangged after few minutes, i press c
First you might need to have service pack 3
XP Service pack 3
http://windows.microsoft.com/en-US/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
a slight overhaul of your computer
second clean your computer of dust using a fine air blower from a compressor specifically around your CPU central processing unit making sure there is no MOISTURE in the airline
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
test or replace all the leads that attach to your hard drive including electrical extensions IDE SATA the ones that attach from your motherboard to hard drive make sure they have secure dust free connections
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty
then click start run type cmd then type chkdsk/r/f which will automatically scan for and attempt to repair bad sectors and fix any corrupt files this will schedule to happen on restart
another way of running the chkdsk utility
click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start should schedule this task when restart
you should not do anything while the chkdsk utility is in progress any input may damage your computer your hard drive then defragment your hard drive
you have to keep a computer very clean & free of dust and give it regular maintenance
also you might download and use this registry cleaner it is 100% totally free to use
http://download.cnet.com/ccleaner/
and you might need to uninstall some unnecessary programs
right click in the bottom toolbar select task manager applications you will see whats running
also in processes see whats ticking over
do have any tune up programs installed on your computer
hope this helps
Apr 26, 2012 | Intel Computers & Internet
I am using intel 845 GVSR mother board with p4 2.4Ghz processor and 256mb of ram.. my problem is whenever am playing any high resolution video or any HD video, the monitor screen became black and after...
If you have only 256 MB of RAM with a P4 system...there is most likely your problem....
I recommend that you increase your ram to at least 1 GB -- 2 GB if you can afford it and your board will support it. You will find that your system will be much faster, more responsive, and will most likely crash a LOT less!
Jan 24, 2010 | Intel Computers & Internet
My 40 GB hard disk got crashed for KOB 810e FST Mother board. can i use new 80G or 160 GB hard disk. does my mother board supports 80 GB or 160GB hard disk. I have 256 MB of RAM. can i upgrade it to...
Yes, any motherboard that supports "larger-than-32GB" disk-drives should support larger disk-drives.
Yes, most motherboards support up to 512MB per stick of RAM.
Jan 02, 2010 | Intel Computers & Internet
My system is hanged after few minutes
Well the issue could either be with the bas sectors on hard disk or faulty RAM or a burned capacitor on the motherboard.
The very first thing I would suggest you is to reinstall windows operating system.If the issue persists then run the system with another RAM and observe the performance.
if the issue persists then it could be with the motherboard or the power supply. Manually check the capacitors on the board for any leaking or faulty capcitors.
Let me know if you need any further assistance
Aug 08, 2009 | Intel Motherboard
RAM SUPPORT FOR D 845 GVSR MOTHER BOARD OF 2004
Greetings
Memory support for your d845gvsr board is as follows:
Memory speed - 333MHZ, 266MHZ and 200MHz.
Memory type - DDR SDRAM
Max Memory - Capacity of up to 2 GB
Memory Slots - 2
Memory module size is 1GB (1024MB) for slot.
Thank you,
Let me know if you need anything else.
Ekse
Mar 02, 2009 | Intel Motherboard
Intel 845 gvsr memory problems
Sounds like the RAM is not compatible. Try another 1 GB chip from same manufacturer & see if that helps.
Dec 20, 2008 | Computers & Internet
Ram Support
You can add that to the motherboard. 80% chance your motherboard will support that memory. It will run at a lower speed if your motherboard can only run at a lower speed than 400Mhz
Sep 18, 2008 | Intel D845HV (735858149143) Motherboard
UPGRADING P 3 PC
THE SE440BX2 MOTHER BOARD CAN SUPPORT P3,P2 PROCESSORS(P3 850 MHZ)....,BUT NOT P4 AND HIGHER VERSIONS...THIS MOTHER BOARD SUPPORTS UPTO 768 MB OF RAM,NOT MORE THAN THIS...
Aug 19, 2008 | Intel Pentium 3 , 450 MHz Pentium III...
250gb sata hard disk to 845 glad mother board
Hello all. I have the same issue. My MB is 845G [P4 2.4 Ghz] and SATA harddisk I need to install is Seagate 250 GB Baracuda with 3.0Gb/s interface, I belive which makes this HD as SATA II. So for this motherboard should I prefer PCI cards which support SATA II over the supports SATA I [these are cheaper].
Thanks so mcuh!!!
May 12, 2008 | Computers & Internet
Intel D102GGC2 Motherboard Logo
70 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
