Question about Samsung RS2630SH Side by Side Refrigerator
Disconnecting our fridge
We are moving house and the water supply runs under a tiled floor. How can we disconnect this?
DO YOU HAVE A CRAW SPACE? UNDER YOUR HOUSE
Posted on Apr 05, 2007
My AEG Santo freezer is leakin water on the floor every few days. There is also a build up of ice inside the bottom of the freezer, even though we very recently defrosted the freezer. This fridge/freezer...
try pulling out the fridge very slowly, any signs of hard resistance than stop. there should be a main water shut off back there. if still uncomfortable with this you can always shut the main water off to the house before trying. hope this helps.
Feb 22, 2013 | AEG Santo 7085 KG Side by Side...
Where does the rubber membrane go when tiling a bathroom floor
tiles on wooden floors will always move and crack the grout/tiling cement
therefore the rubber membrane goes down first with out nails and then everything is laid on top
that way when the wooden floor moves , there is a water proof membrane to prevent the water from rotting the wood over time
Jun 14, 2017 | Home
Refrigerator leaking water
need info. disconnect from electricity supply look for a water collector in bottom rear of fridge if full of water drain out make sure drain hose into fridge is clear : if it continuies door sesl needs looked at as taking in to much warm air
Dec 19, 2012 | Refrigerators
Water leaking
better call a big strong guy to move it then water line to ice maker possibly burst
Dec 10, 2017 | Amana Refrigerators
Hi, I have an a GE Profile Model TPX24PPDCC fridge that came with the home I purchased in 2006. I believe the fridge is much older. I've been having problems with the water dispenser where water will...
Yes there is a way to disconnect the water line. Pull the Fridge out from the wall. The electrical power chord should be on the back side as well as the 1/4" water line. You need to locate a valve and shut off the supply water. Then you can disconnect the line with wrenches. It is located near the bottom.
Apr 01, 2017 | GE Refrigerators
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
Water dispenses very slowly on Fridge
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The coil of tubing is normal so you can move the fridge out from the wall without damaging anything.
Your water line could be frozen in the door. You can disconnect the line at the bottom before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does, leave the door open till it thaws.
If it doesn't come out there disconnect it at the water inlet valve and see if it comes out there. The valve could be bad.
A strainer before the inlet valve can also get stopped up restricting flow.
Jan 14, 2010 | Refrigerators
Could a fridge continue leaking even after water supply to house was shut off? My kitchen is flooded and I cannot determine if the fridge is the culprit. I do have an icemaker. Respond quickly please
The most the fridge will contribute is the quart or so of water contained in the lines. If the water has been turned off to the house and the valve to the refrigerator is closed, then that is about all the water that should come out of it.
If the water supply to the house is off, then open the valves to the tub or sink on lowest floor to relieve the pressure, then start looking for the water source.
If in a cold climate, look under the sink if it is on an outside wall
Dec 27, 2009 | Jenn-Air Refrigerators
Water supply very slow to the ice maker.
Is the water slow coming out of the water dispenser? Your fridge should have the same water pressure as any sink in your house. Most of the time low water supply is from thw water valve in your basement or under the sink or wherever your is hooked up. Most people use piercing valves and they always plug up
Sep 11, 2009 | Whirlpool ED5VHGXM Side by Side...
Samsung RS2630SH Side by Side Refrigerator Logo
54 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
