Question about Canon PIXMA iP1500 InkJet Photo Printer
Changed the black ink and while it's seems like the document is printing, no ink appears on paper.
  • Anonymous Feb 13, 2009
    I changed the black ink cartridge and the printer prints but I get a blank page.
  • paulywarly Feb 21, 2009
    black ink wont print,printer not been used for a year.I changed cartridges cleaned the heads using the printers program, then took out the printer head / cartridge holder rinsed in warm water ,still no joy,only the the colour works.
This was Rob's response to a similar problem which I had. changed the black ink and - d0c4ec0.jpg robmcd27
Rank:guru_s.gif Guru
Rating: 85%, 6 votes
The black ink is not the problem, it's the nozzle. The nozzle for the black ink head is clogged with dried up ink. If it were mine, I would remove the print head and use a q-tip dipped in alcholol to clean the nozzle. Let the alcohol dry and put it back together and run another auto print head cleaning.
You're probably going to have to do it a few times. It's going to depend on how bad the clog is. This will fix you...just be patient. Remember that ink has been dried on several months. Don't forget to rate my help. Thanks for coming to FixYa.com
Rob
Posted on Feb 19, 2009
    Sergeant:
    Champion:
  • 271 Answers
Re check the cartridge.compare the weight of new one to old
Please Don't Forget To Rate "FIXYA" Me For The Help
Posted on Dec 21, 2008
Epson stylus dx6000 only copy in color mode
Any ink in the black cartridge or can you use clean mode to clean it?
Mar 15, 2014 | Office Equipment & Supplies
Got the C5180 from a relative because it didn't work. I tried a new black ink tank, it doesn't print anything in black. Color print looks weak and washed out without black for shadow, and black...
The printed output is fuzzy, blurry, or grainy, or the edges of objects in the images are jagged. Solution Follow these steps until the issue is resolved. Step one: Check your paper
  • Many papers have printing and non-printing sides. Load the paper with the printing side down.
  • Use the correct paper type for the project. For everyday documents, plain paper works well. For documents with dense printing, such as high-contrast graphics or photographs, use HP Advanced paper for the best results.
  • If these steps do not help, try a different paper. Ink might not bleed as easily on heavier paper. Paper that does not accept ink well is also prone to bleeding and smearing. HP designs its inks and papers to work together.
Step two: Check the settings
  1. In the program being used for printing, click File , and then click Print . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the Advanced tab, and then click Advanced Features . The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Step three: Check image resolution Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry. Here are some general guidelines for image file resolutions:
  • 94 pixels per cm (240 pixels per inch) for images to print on smaller format photo paper, such as 10 x 15 cm (4 x 6 inch)
  • 117 pixels per cm (300 pixels per inch) or higher for larger format photo papers
  • Lower resolutions might produce acceptable images when printed on rough-textured paper
Step four: Align the cartridges If the previous steps have not improved the appearance of the printout, align the cartridges. See the user guide for alignment instructions.
Jul 02, 2011 | Office Equipment & Supplies
I replaced my ink cartriges and I'm still have a blurr and fade on documents that I print.
  1. Open your application program.
  2. Select Print from the File menu. A Print window appears.
  3. Make sure EPSON Stylus CX9400Fax Series is selected.
  4. Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
    A printer properties or preferences window appears.
  5. Select the type of document you're printing for the Quality Option setting.
  6. If you want to print borderless photos, click the Borderless checkbox.
  7. Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
  8. Click the Advanced button. The Basic settings change to the Advanced settings.
  9. Make sure the High Speed option is not selected in the Print Options section.
  10. Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
  11. Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
Jan 18, 2010 | Epson Stylus CX9400 Photo Printer
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Nov 12, 2008 | Epson Stylus C66 Inkjet Printer
Black ink only
Print using pigment black ink only (Windows) Instructionsto print using only the pigment black ink tank only. Occasionally youmay need to print using black ink only. Using grayscale alone does notprovide this option and the color inks will still be used. By followingthis procedure you may print using only the pigment black ink tank. Note: Image quality may be sacrificed when printing photographs.
  1. Open the Properties / Preferences window for the printer.
    For Windows Vista
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel', 'Hardware and Sound', and then click on 'Printers'. Note: If you are in 'Classic' view, Click 'Printers' directly from the 'Control Panel'.
    • Clickyour right mouse button on the listing for your printer, and thenselect 'Printing Preferences...' from the menu that appears.
    For Windows XP Home Edition
    • Click/ Select 'Start' from the bottom left of the Windows screen, 'ControlPanel,' 'Printers and Other Hardware,' and 'Printers and Faxes.'
    For Windows XP Professional Edition
    • Click 'Start' from the bottom left of the Windows screen, and 'Printers and Faxes.'
    For Windows 2000/Me/98
    • Click / Select 'Start' from the bottom left of the Windows screen, and 'Settings,' then 'Printers.'
    • Click your right mouse button on the listing for your printer, and then select 'Properties' from the menu that appears.
  2. Click on the Main tab.
  3. Select 'Plain Paper' as the Media Type. If any other paper type is selected, color ink will be used to create black.
    Note: The pigment black ink will only be used when printing on plain paper.
  4. Select the box for 'Grayscale Printing'. If the document to be printed is in black only, then this step may be skipped.
    Note: If either 'Borderless Printing' or 'Duplex Printing' are enabled from the Page Setup tab, grayscale will be created using a combination of the color (dye) inks to prevent smearing.
  5. Click 'OK' to save the changes.
The printer will now only use the pigment black ink tank.
Oct 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Black strips when printing
I'm having the same problem, with the black strip printing on the back of each copy i make... Its very annoying. the circlular lil rubber piece that helps the paper feed out of the machine is wet with black ink. theres about 5 lil rubber things that feed the paper out and ONLY one of those seems to be wet with black ink, so everytime i print, it appears on the opposite side of my document. If someone knows how to fiz this problem, PLEASE PLEASE get in contact with me. My name is Maria M. and you can reach me by e-mail smilz922@aol.com
Thanks
Maria M
May 17, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon Pixma MP 800 printing Issue (heavy black line on opposite side of print page
problem is when the printer does a head clean dumps large amount of black ink on to rollers. Replacement head is almost £100 and not certain to fix fault
Apr 12, 2008 | Canon Pixma MP800 All-In-One InkJet...
I have exactly the same problem with a Canon Pixma MP800, I have cleaned the rollers, changed the ink cartridges and reset the printer. It will print a few pages cleanly then dump black ink on the roller which leaves a heavy black line on the back of the page. It fades away after printing about 10 pages and then a few pages later appears again. The printer is two years old and it looks as if I must buy another. Should I buy another Canon?
Apr 03, 2008 | Office Equipment & Supplies
Canon PIXMA iP1500 InkJet Photo Printer Logo
129 people viewed this question
old marine
old marine
