Question about Amana Heating & Cooling
Not heating its not igniting inducer comes on then the fan but not igniting
  • Ken Bledsoe May 11, 2010
    Sounding like hot surface is bad. Can you see inside your furnace area and see if the hot surface is glowing cherry red hot?
    Problem Solver:
  • 3 Answers
Thanks for every thing its already fix. I jumped the limit switch then hook it back on
Posted on Dec 23, 2008
When the heat comes on, the vent pipe fan comes on, but why do the burners only ignite with the front panel off?
I would look at the draft inducer diaphragm that senses the draft being faulty , check tubing from draft fan to diaphragm having a leak or crack in the line.
Feb 14, 2016 | Heating & Cooling
No heat from furnace, Goodman GMPN080-4 Rev A. Cycle is solid red status light, then 3 flashes indicating open pressure switch because the inducer fan does not come on.
Jimbo, it sounds like you are aware of the operational sequence to suggest using a voltmeter to check the actual wires going TO the combustion air fan...if there is no voltage from the board, the board is bad. Just make sure one of the high temp limits are not open... one may be in the blower compartment on some and one will be near the top of the vestibule and a roll out switch should be near the burners. They should all be wired in series.
Always check the manual reset safty switches as the first step in troubleshooting.
Nov 21, 2015 | Goodman Heating & Cooling
Gas dryer won't light. Ignitor glows red and I can smell the gas, but no ignition. New coils didn't fix problem. Any ideas what to try next? Hamper full and wallet empty- please help!
Is your inducer fan coming on first? I know on a gas heat pump yu will hear the fan/inducer turn on for a few seconds, then the igniter will lite, then yu will hear it fire up, this is a safety feature sequence, no gas movement thru system, no ignition, also check the exhaust pipes for holes or cracks
Apr 19, 2015 | Dryers
How do I wire a induce fan motor
Induced fan motors on older units are wired through the high limit safety on the stack - in series. When the furnace calls for heat, the induced fan motor comes on and after a time the furnace will light.
Older units have a temp switch in the stack that rotates to bring on the burners and blower motor. . When there is a call for heat, the induced draft fan motor comes on and then the burners will light.
After the heat exchanger is warmed up the limit switch will bring the blower motor on. That's basically how it works - there are two circuits - one for the induced draft motor and the burners and the other for the blower and high limit.
New units have a plug on the board you just plug in.
A
Oct 04, 2014 | Heating & Cooling
I have a goodman modle gms80703ana and at first the inducer fan would kick on in it's normal cycle then the furnace would shut off do to a pressure switch. Now the inducer fan only come on perodicaly...
First unplug your furnace to reset it then plug it back in with thermostat set to heat high enough to make the heat come on. As soon as the inducer motor came on you JUMP the 2 wires that go to pressure switch. Your igniter should come on and gas valve should open for heat. If the flame stay on the blower should come on after a few minutes. If it get to this point your problem could be pressure switch itself or inducer clogged.
Jan 30, 2014 | Goodman GMS807034ANA Heater
Carrier troubleshooting
Klixon switches bad. The main blower won't come on until there is enough heat built up in the exchanger. If the induced air fan won't come on look for the control relay . Make sure the thermostat is switching to heat correctly too.
Jan 24, 2014 | Office Equipment & Supplies
My York furnace sometimes doesn't completely ignite
A noisy inducer probably is headed for replacement.
The igniter can produce a healthy glow and still be defective. Mine had to be replaced with a new, improved one.
The thermocouple could be defective even though it seems to open the gas valve when it should.
The heat sensor in the bonnet could be defective. That controls main blower operation.
The heat exchanger could be cracked.
Jan 10, 2014 | Heating & Cooling
When the thermostat calls for heat sometimes the gas pack works fine and sometimes it doesnt work at all . the inducer motor comes on but the burners dont ignite . what could be the problem ?
Could be the igniter or the thermocouple. The blower has to start first and it does but it will run on endlessly without further action unless the igniter heats the thermocouple to open the gas valve and fire the burner.
Dec 15, 2013 | Carrier 3 Ton 13 Seer Commercial Gas Pack...
No spark on unit
Need more info! Is it a Gas heat unit that is package or split unit? Is it force draft induced? Is there any sounds or audible noise that it is trying to call for heat and ignite? Does the inducer fan spin-up prior to calling for pilot. Is it a pilot light or a Hot surface ingition? Is it a direct spark ignition system?
Oct 07, 2010 | Heating & Cooling
Janitrol/Goodman GMP075-3 Draft Inducer Fan Won't come on
most forced draft fans are powered by 120 volts . close to the fan is usually a plug that unsnaps. create a call for heat after turning off to clear safetys and see if your getting 120 to fan on initial call for heat. if you are then fan draft motor is bad, usually sold as an entire assembly replace exact as it came out. sequence of operation is..... stat calls for heat via common and white wire to furnace , 24 volts. ......board sences call and sends 120 volts to forced draft ........ motor runs and creates pressure on proofing switch,....... switch closes 24 to board and tells it draft fan is on......... board then energizes ignitor,....... after ignitior glows gas valve is opened and burner lights ........ either ignitor or seperate sensor rod tells board the burner lit........ and a few minutes later the fan comes on and hot air is blown out. if a step is missed or doesn't proof the furnace either trys up to three times to light or locks out. turning off power usually resets safetys and it will resume attempts to lite normally.
Oct 25, 2008 | Heating & Cooling
Heating & Cooling Logo
95 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
