Where can I find a replacement drive belt?
SOURCE: Need to re-set margins on Royal electric typewriter
Use the green code key with the rm and lm keys.
SOURCE: How to replace ribbon on Royal Apollo 10 elec typewriter???
The cover either pulls up straight or there is a release lever in the front part of the cover that pushes.
SOURCE: need to clean and lubricate
Use a soft brush and maybe some air, but be very careful not to knock any springs loose. Sewing machine oil or TriFlow oil works best. Put a fews drops on your finger, and rub your finger across the type segment slots. Work the typebars a few times. If that doesn't do it, then the segment will need a thorough cleaning.
SOURCE: Need Carrige Belt for Royal Academy Electric Typewriter
I use 30lb. test steel core leader (fishing line)
