Question about HP OfficeJet 7310 All-In-One InkJet Printer
Warming Up message does not go away
Warming up message stays on . Then when I try to perform any task a Busy message appears for a moment, then the warming up message comes back on.  Any ideas.
Thank you
  • mtneer cabin Dec 23, 2008
    if trying to make copies warm up sign comes on then screen goes black and power lite begins to blink
  • Anonymous Mar 17, 2009
    When I try to make a copy either through the automatic document feeder or by placing the original on the glass manually, the printer displays "Warming up" after the "copy" button is pressed. The copier never functions. It will stay in this state until the printer is powered down. I have left it that way for a day and the copy was never made.
    Sergeant:
    Champion:
  • 271 Answers
Problem not clear please explain...
Posted on Dec 21, 2008
Server is always busy preventing me from backing up or syncing my phone when in my samsung accoutn
I'd suggest to use specific applications from the Google store, like Application Backup/Restore, SMS backup, etc.
Mar 03, 2014 | Samsung GALAXY S4
Whirlpool gold accubake system keeps displaying the message "Dr Lo". Every 60 seconds it will beep like 10 times and display the message then display "start?" Normal function dont work either I can push...
The Dr lo is for the warming draw. I assume you have a warming drawer. Page 17 of your manual describes how this function works. It also states on page 11 "The Off/Cancel pad stops any function except the WARMING DRAWER, Timer and Control Lock. If you have actually unplugged the stove and plugged it back in it should come on with a PF for power failure. You push the Off/Cancel pad to clear the PF and then you have to push start to do anything else. such as bake, etc. Have you pushed Drawer OFF? That should clear the dr lo message. If this message comes on as soon as you plug the stove in or just after you push the Off/Cancell pad or after you push start or bake try to push Drawer Off. If this does not work then it apppears you have a malfunctioning control panel.
Dec 18, 2013 | Kitchen Ranges
When I try to scan, I get the error message that is is still warming up. This message will not go away. When I press other buttons it says 'busy', then back to 'warming up'. How can I fix this?
Try power cycling both devices.
  • Completely shut down the computer.
  • Turn off the printer.
  • Unplug the power chord at the back of the printer.
  • Turn on the computer.
  • Plug the power cable back in.
  • Turn on the printer.
If your still having issues w/ it. contact your manufacturer.
Good Luck :)
Feb 06, 2011 | Office Equipment & Supplies
When I try to print a copy, display says "warming
A well documented problem. Try following the suggestions posted here
Dec 03, 2010 | HP PSC 750 All-In-One InkJet Printer
Warming up message
1.u can uninstall the cartridges
2.take the power cable out from the back of the printer
3.press and hold "#" & "6" key while the power cable is out
4.while pressing both the keys plug the power cable in and try to connect the printer directly to
wall outlet
5.release both the keys, u will see ur printer will turn on automatically, if it does not press the
power botton and turn it on , then it ask for the language press 11
6.ur printer will start making noise so do not worry abt that and it will ask for the cartridges,
7.install the cartridges
8.when u get ur normal screen of the printer then check the performance
Nov 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
WARMING UP LIGHT STAYS ON!!COPIER WILL NOT WORK??
Hi, it sounds like your firmware is corrupt. Have you tried rebooting the device by switching it off/on. Use the main switch inside the front door.
Failing that, you'll need to reload the firmware, an engineer will easily be able to do this
Regards
Taminol
Apr 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Scanner bulb warming up message!!
Aqeel,
This is the problem with your scanner. If it is under warranty please take it to Hp Service center and they will replace it free for you.
Thanks
Jun 19, 2008 | HP LaserJet 3380 All-In-One Printer
Sunbeam warming blanket
Dear Sir, I called J C PENNEY and they suggested I call back next month or so when the electric blankets come in for winter so they could get the information I need.
I still don 't understand why the blankets did not come up in the product information.
Thanks anyway, Carol
Jun 16, 2008 | Blenders
Warming up
Hi, The warming Up messge usually occures when the scanner bulb is not getting heat up for the correct temprature or the scanne bulb might be defective.. To resolve this issue follow the below instructions.. First connect the printr directly to a wall outlet as some times surge protectors will not provide the required power for the printer then this message can come up. Once the printer is directly connected to the wall outlet try to turn on the printer and check with the issue.. If the issue presists try the instructions in the below webpage.. http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=c00787271&cc=us&lc=en&dlc=en&dlc=en&lang=en This shoule resolve the issue .. Wish u success.. Regards. Barret.
Oct 01, 2007 | HP PSC 2175 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
336 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
