Question about RCA RTD258 System
The main unit wont turn on at all the light arond the power button will not light up. the sub woofer light is on showing me that power is on but main console will turn on.
My daughters unit had a simular problem. I tooke the cover off the unit and removed discs from the inside. Apperently, she had a homemade disk that the unit did not like and it shut down the whole unit. Once the disks were removed, the unit worked fine. Be sure to check the main fuse first.
Posted on May 30, 2009
  • Kirtley Cooke
    Kirtley Cooke Dec 16, 2015
    I had a similar problem, not caused by a bad disc. I removed the 4 screws for the top cover of the DVD stack and plugged the unit back in. It came back to life. Kirt
    Sergeant:
    Champion:
  • 271 Answers
Check the main fuses..else there is something burned inside. or a lose conection
Please Don't Forget To Rate "FIXYA" Me For The Help
Posted on Dec 21, 2008
Why Onkyo HTS-9400THX: Front both and subwoofer not working.?
Try differnt speakers, if they do not produce sound, amp channels may be blown and then you need to take it to a shop.
Aug 01, 2014 | Audio Players & Recorders
I have a MTS surround sound system and when i put the volume up the woofer turns off. whats wrong with it? and how can i fix that
Seems you are over driving the unit and causing it to overheat and the protective circuits are kicking in. U need a more powerful system to play at the volumes you want.
Aug 26, 2017 | Audio Players & Recorders
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
MX6050D Subwoofer Issues
Hello, welcome to Fixya!
Fault is either from the main system or the sub-woofer itself.
You need to test both unit in order to detect which of the two is giving the fault, so that you can concentrate on the faulty unit.
Test the woofer with a AA battery or any other battery. Put your ears close to the woofer and observe if you will hear any sound. If the woofer makes sound, then it means the woofer is working, but if it doesn't make sound, then it means the woofer is defective. Or you can disconnect one of the working speakers and connect the woofer to that part. If there is no sound, then obviously, the woofer is defective.
If the woofer seem to be working, then the unit needs to be tested also.
Connect one of the working speakers to the sub-woofer's section of the main unit. If the speaker doesn't bring out sound, check the system's menu settings, check the volume and make sure the sub-woofer volume is raised to the highest level and not on mute. ( Note that most Theater systems has separate volumes for each speakers). If the volume is raised to the highest level and there is still not sound from the woofer part, then it means the woofer channel has burnt. It could be a fuse or a defective channel. At this point, I think you need help from a repairman.
I hope the above is clear.
Regards.
Nov 17, 2011 | Audio Players & Recorders
HI i have Panasonic SB-WA330 sub woofer & speakers(no main unite) can i use this sub woofer & speakers with any other DVD player.thanx.
Not unless it's a similar Panasonic main unite. There's that pesky special connector "A" (so common on all-in-one products) to deal with.
The picture here http://www.forodvd.com/tema/97518-duda-usar-nuevo-ampli-con-altavoces-antiguos/ shows it requiring an SA-HT810 or SA-ST1 source.
Even beyond that speed bump, most stand-alone DVD players have no facilities for on-the-fly adjustment of volume. That is one reason why they make main units.
Sep 02, 2011 | Audio Players & Recorders
Flashing code s/w chk
It is just that main unit is looking for the "Wireless sub-woofer" and shows this message when it can't find the sub.
wireless connection between main unit and sub should be reset.
Mar 11, 2010 | Samsung HT-X810T Theater System
YAMAHA AV receiver RX-V861 I have the message 'Vol-fix' appearing on Zone 2 and no sound. This was working fine until then
Setting the RX-V861 remote control to operate Zone 2:
  1. Using a ballpoint pen or similar object and press the [CODE SET] button RX-V861 remote control. The[TRANSMIT INDICATOR]on the remote should flash twice.
  2. Using the [NUMERICAL KEY PAD] on the remote and key in 9992, the [TRANSMIT INDICATOR] should flash.
Assigning the receivers internal amp for Zone 2:
  1. Set the remote control selector to [AMP]. (Located to the right of the volume buttons on the Remote.).
  2. Press the [SET MENU]button on the remote control.
  3. Arrow down to Manual Setup and press the Enter button on the remote control.
  4. Arrow to the [SOUND MENU] option and press the [ENTER] button on the remote control.
  5. Arrow to Speaker Set and press the [ENTER] button on the remote control.
  6. Arrow to the EXTRA SP ASSIGN and select ZONE2
  7. Press the [RETURN] button on the remote control to exit out and return to the Manual Setup.
NOTES: There is an option for setting the Maximum Volume and Initial Volume in the Zone Set menu.
  • Max Volume: This is an optional feature but isrecommended to prevent the accidental change in volume levels thatcould damage the speakers and receiver.
  • Initial Volume: This is also a great feature that would seamlessly start the volume level for the second or third zone at the desired level.
We do not recommend using any Speaker Selector boxes to enable more than the recommended number of speakers per terminal.
Controlling Zone 2 using the RX-V861 remote control:
  1. If the Main Zone on the receiver is on, press the [POWER BUTTON]down and while holding that button down press the [PHONO]/[**] button on the remote. The [TRANSMIT INDICATOR] will light up.
  2. You will not be able to use the following buttons on the remote: (Pressing any other button will cause the remote to exit Zone 2 mode. [POWER], [STANDBY], [VOLUME], [MUTE] and the [INPUT SELECTOR] buttons [DVD], [CD], etc.)
There are the instructions as written straight from yamaha. If you need any further assistance please let me know.
Thank you,
Lee
Dec 13, 2009 | Audio Players & Recorders
Amps and sub-woofer not working
Enter into the Audio Setup mode(press and hold volume button for at least 1 second). Next, repeatedly push the volume button until the display shows "2 ZONE". Make sure this feature is turned off. Hold the volume button again for at least 1 second to leave Audio Setup mode.
Now you need to make sure the Subwoofer Output is turned on. Do this by holding down(AM position) on the control knob(toggle stick) for at least 1 second. Each time the button is pressed, the Subwoofer Output is turned ON/OFF. the display should show "SW ON".
Next, you can go into Audio Control mode(press but do not hold volume button). Keep pressing on the volume knob until "Sub-WLevel" is displayed. Here you can adjust the amount of gain for the Subwoofer ranging from -15 to +15.
I hope this fixes your problem with it.
Cheers
Dec 31, 2007 | Kenwood Excelon KDC-X789 CD Player
Panasonic SC-HT920
One option is to set the cross over to the sub so it knows when to send the low frequency to the sub and not the front speakers. 120 is a good setting. This can be done either via a know on the sub woofer or the setup screen of the main unit.
good luck
smeags
Sep 07, 2007 | Panasonic SC-HT920 System
RCA RTD258 System Logo
363 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
