Question about Refrigerators
Water not working in door of frig
Thanks for your solution. Should a homeowner try finding this switch in the door of the frig or hire a technician?
    Novelist:
  • 161 Answers
It would be best to get an appliance tech.
Posted on Dec 21, 2008
Fridge doors do not close completely
1st ckeck that nothing is sticking out just far enough to pop the door open.if not that, than the gaskets can were out on frig doors , you can order it on line from all appliances, get the model # from inside the frig , be patient installing it , its tricky, but it can be done by Harry homeowner. good luck.
May 04, 2012 | Maytag MSD2756GES Side by Side...
I just connected the ice maker water line to the unit. The Frig has electrical power and ice is making. My problem is that the controls at the front of the Frig is not working. I cannot dispense the ice...
Without a model number here how they usually operate. The DOOR / LIGHT switch disables water and ice in door functions. I.e. it is not supposed to operate with the door open. If the switch is open... i.e the light is not working door open, (Switch has 2 functions Light and Water / ive in door operation) Then the control panel / water / ice in door will all not work either. It is possible for the light to work while the CP / H2o / Ice do not work. Usually if a door switch fails the light stops working also. It is not always the case.
Try holding to door switch plunger depressed and see if your CP works and water in door work. DO NOT try ice in door as you can damage things.
If you respond with a model number and brand; I will see what I can dig up for you use while troubleshooting your unit. Expect to see parts data also.
Thanks for choosing FixYa,
Kelly
Sep 02, 2011 | Refrigerators
Whirlpool side by side frig, model #: ED2JHGXRBO2, serial #: ST2854810. We have had this frig for several years and almost from the get go when you open the right side door, the door gets so far and always...
I own a whirlpool fridge (side by side) model # ed2jhgxrt02. with a problem with the ice maker. the water is not being delivered to the ice makers. it seems that the switch to turn on the water to flow is not making contact. any suggestions?
Jan 04, 2011 | Whirlpool Refrigerators
On humid days water puddles in the bottom of the frig.
Sounds like the door is not closing properly so humid air is coming into the fridge OR door not closing properly and the humid air is condensing around the door so it is leaking the condensation OR
The water from the defrost cycle is not evaporating so it overflows from the evaporator pan above the compressor. You better call a service technician before getting some floor damage (Do not call A&E)
May 02, 2010 | Refrigerators
Maytag French Door MFD2561HEB water dispenser not working
We had the same issues with the water freezing and called a technician out. He added some extra insulation installed around the water lines inside the refrigerator and we also keep our frig at 40 degrees Fahrenheit, slightly above the manufacturers default setting. Hope this helps.
Jul 01, 2009 | Amana AFD2535DES French Door Refrigerator
NO WATER IN FREEZER DOOR - I HAVE THE SAME PROBLEM - SEE MY NOTES
GE has a water dispenser heater retrofit kit that will prevent the freezing. Please don't be angry with me I don't work for GE. Do they not know the part number? Click Here=> WR49X10173
Or here=> WR49X10173 or 1381601 Dispenser Water Tube Heater Kit
Yes GE should be accountable and there products have not become better. Sadly they follow LG in the accountability department. You do have a right to complain to GE and expose the problems and solutions that were offered to you from these so called technicians. A new freezer door cost as much as a new refrigerator! Sounds like the Technicians are not very well informed or certified to work on GE products.
4a7a394.jpg Please rate my solution after I have helped you resolve the problem and communicate with me. I am offering my help to you free. If need you may contact me here on Fixya or my Forum=> Appliance 911 My contact information is located above the Fixya Ad on my blog here=> Sea Breeze Appliance Parts and Technical Services, www.pcappliancerepair.com
Thanks, Sea Breeze
Jun 03, 2009 | GE GSS25SGPSS Side by Side Refrigerator
Water dispenser will not work when lever is pressed. we had an intermittent problem with it before it stopped working altogather.I was going to look at it but was afraid to pop off the trim on the outside...
This could be a bad water valve in the frig. This frig has a double water valves. One for the ice maker and one for the water dispenser. It should be in the lower back. Where the water line goes in. You can check this valve easily. Find the double water valve on the frig. Turn off water supply to frig first. Swap the plastic water lines going from the water valve into the frig. Turn water supply on. Then see if the water dispenser works. Sometimes you will have to operate the water dispenser for a little while to get the air out of the line. If it works now then the problem is in the water valve solenoid and needs to be replaced.
Nov 08, 2008 | Kenmore 53642 / 53644 Side by Side...
WATER DESPENSER IN DOOR WILL NOT WORK
Solenoid should be near bottom rear of frig. check wiring connections on solenoid. Turn off water valve to frig, disconnect hose at solenoid and see if you can blow air thru the tube.
May 28, 2008 | Whirlpool ED2FHEXN Side by Side...
DEEP SCRATCHES ON OUTSIDE OF MY FRIG. WHITE
grey is the primer color applied to the bare metal befor the color coat is applied
try touch up paint
or replace the door
May 08, 2008 | Refrigerators
Freezer cold/Not Cold in Frig KITCHENAID Model KBLC36MHS01
I couldnt find a diagram of this frig.
Some of the evap. fans run thu the defrost thermost ..u could try by-passing thermost and see if fan comes on...  have you checked with volt meter if there was power at the fan motor?
Oct 31, 2007 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
