Question about KitchenAid KAWS700L Top Load Washer
Kitchenaid model#KAWS700JQ4 top load
We posted our problem with washer filling and empting, not spinning or agitating, and was advised to replace drive coupling assembly, we have done this, and the old one was boken, the problem now is it fills and does nothing more. it would fill and empty and go through cycles before but since we replaced part it will only fill. Please Help
3 Suggested Answers
SOURCE: Kitchenaid Washer Model #KAWS700JQ4
Washer has a motor coupler linking motor to transmission. If this motor coupler is broken or has rounded out where it engages the motor and/or transmission gear it will only fill and drain. You can view this coupler by leaning washer back against the wall & looking underneath with a flashlight. There may be a sound dampener panel on the bottom that you have to remove to see it. It is two pieces of white plastic with a rubber grommet in the middle.
Posted on Dec 16, 2008
SOURCE: kitchenaid top load washer wont agitate or spin
Perfect answer from Flyingtarzan.  I just fixed this problem myself and sure enough I had a broken drive coupling.  About 30mins to repair.
Posted on Apr 30, 2009
Washer wont agitate or spin
Depending on the brand of washing machine, the agitator may be a single piece unit or a two piece dual action agitator. If the single piece agitator or the lower portion of a dual agitator does not oscillate back and forth during the wash cycle, or if the agitator can be turned on the transmission shaft, then the spline may be damaged and the agitator may need to be replaced. Most agitators are held in place with a bolt that threads into the top of the transmission shaft and is located below the softener dispenser or top cover. Some models use a small set screw in the barrel of the agitator just above the base to secure the agitator to the shaft, while some will use a rubber o-ring to provide a tight fit. When the retaining device is removed you should be able to lift the agitator from the shaft.
Aug 03, 2017 | KitchenAid Washing Machines
KitchenAIde KAWS677EQ0 washer will fill, agitate but not pump out. Its like the timer just stops
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Whirlpool LSR9434PT Top Load Washer
My kenmore 800 washer is off cycle for example when i start a load of clothes it starts agitating before filling, and doesn't always spin all the water out of the clothes
I have the exact same problem with my Kenmore 800 top loader, Model # 110.29822800. It is only 1.5 years old. Any suggestions?
Jan 19, 2011 | Kenmore 22422 Top Load Washer
Kichenaid kawe570bal0 agitator clunks
there is a gear, pop the top cap off the agitor, the gear is in there, near the top might need to be replaced, sears has most parts for most machines
Oct 03, 2009 | KitchenAid KAWS850L Top Load Washer
Frigidaire washer spins but won't agitate
when you try to spin the Agitator dose it spin freely both ways if so the DOG EARs are stripped and need replacing Take cap off top off agitator to access the bolt holding the n in place and the Agitator off
Oct 22, 2017 | Frigidaire Washing Machines
My Kitchenaid washer stops on the rinse cycle...
Do you have an age of the machine and model number? Is there a "spin only" cycle? On older machines, there was a center knob you could slowly rotate, one click at a time, to advance it through its cycle. Can you do that? If the unit is agitating, I don't believe the belt is your issue. Age and model please.
Jul 31, 2017 | KitchenAid KAWS750L Top Load Washer
KitchenAid washer Model#KAWS700jqsr fills but won't agitate
if it's making a loud buzzing noise while its suppose to be agitating or spinning its the motor coupling
Dec 20, 2008 | KitchenAid KAWS700L Top Load Washer
Dec 15, 2008 | KitchenAid KAWS700L Top Load Washer
Kitchenaid top load washer wont agitate or spin
you have a direct drive washer with a coupling broke.Here is a good article on it http://repair2000.com/coupling.html
Dec 11, 2008 | KitchenAid KAWS700L Top Load Washer
KitchenAid KAWS700L Top Load Washer Logo
176 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Eric Taylor
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
