Question about Panasonic PVQ-M2509 Combo
Panasonic OMNIVISION VCR Combo 1999 PVQ-M2509
After all these years we now have horizontal white lines at the top 1/3 of the tv. But it seems to start in the afternoon then around 10pm stops. Then it stopped for a week but now it's back. Would used a splitter and the other tv didn't have any problem. So our cable repair guy said it's the tv going. But why does it stop and start? We changed outlets, different plugs, opened the back cleaned it..same. Do we finally make the move to a LCD? Or is it fixable? The picture it still perfect color!!! Is there horizontal adjustment knobs? Any advice? Artist13 (I've always liked Panasonic)
    Genius:
  • 1,074 Answers
The tv has a intermitent problem in the power supply.or related circuit have a tech repair on your set it is repairable it could be some lose soldering due to your explanation good luck
Posted on Apr 05, 2007
SOURCE:
Panasonic omnivision TV VCR combo connected to cable box unable to change channels with either remote . When up or down channel buttons are pressed it goes to "line" when channel numbers are pressed it...
cable box needs connected to the antenna in on the vcr..the setup is ..cable box..vcr combo ..tv ..unless your tv has multiple inputs like ours..most of the new ones require a digital signal..it may reqiure a converter box..
Jan 11, 2014 | Televison & Video
Panasonic omnivision horizontal
If you have a white line on screen---middle that runs left to right it is a vertical circuit problem.
This can be a easy repair: The set uses a chip---usually 7-13 pins in a straight line package-----a lot of these sets the solder from heat breaks loose and all that is needed is to resolder the pins on that chip.
A hint: usually a good solid rap on the top or side will in this case try to make the picture open up.
You need to be able to get to the part and solder.
use the make a comment button if you have questions or need more help.
May 16, 2012 | Panasonic PVQ-M2509 Combo
I am looking for the direct tv remote code for tv model PVQ-M2509 Panasonic Omnivision VHS como.
Hello
Four digit universal remote code for Panasonic TV-VCR combo are:-
0374 0381
Three digit universal remote code for Panasonic are:-
003/ 054/ 055/ 062/ 070/ 148/ 149/ 170/ 171
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Nov 25, 2010 | Panasonic PVQ-M2509 Combo
We inherited this tv and dont have remote yet but trying to connect dvd player to it - how do i find out what channel to put it on for it to "see" the dvd?
We had this problem - plus we do not have the TV connected to cable or an antennae, nor do we have a remote. You can get to the menu options by pushing "stop/eject"" and "rewind" at the same time. Then go to the "TV" sub-menu to change the type of input.
Mar 29, 2010 | Panasonic PVQ-M2509 Combo
Hello, i can't set up a universal remote to this tv
Try website 1-800-Remotes Factory original.To buy an exact remote.
Mar 08, 2010 | Panasonic PVQ-M2509 Combo
Our Tv which is a Panasonic, omnivision tv/vcr combo, is not letting us change channels. It asks for an autoscan of channels but after thats done it asks for it again because we dont have a cable box. We...
Unplugged should not have been an issue.Try this to get to AUX Down Channel select passed 2 shoud be your aux input.If nothing is plugged into the A/V input you will just get a Blue Screen.Also be aware that since the switch to Digital Over the Air Broadcasting there are no more channels, you need to hook up a converter box if your TV does not have a digital tuner,Good Luck.
Sep 19, 2009 | Panasonic PVQ-M2509 Combo
I have a Panasonic Omnivision with no remote. I am trying to get to the main menu on the TV. Please help!!
Manually turn the TV on with front panel Power button. Then, with no cassette inserted, hold Play and Rewind buttons on front of the TV for 5 seconds or more. The TV should shut off. Turn it back on and go through the setup procedure
Jun 08, 2009 | Panasonic PVQ-M2509 Combo
VHS Sound - No Picture
try cleaning the vcr with a video tape cleaner
or maby the yellow video output need replacing the cord i mean
Sep 13, 2008 | Panasonic PVQ-M2509 Combo
Panasonic Logo Constantly Across Screen
With the Power On, hold down the Play/Repeat On button for 5 seconds. This will toggle the 'feature' on and off.
Nov 06, 2007 | Panasonic PVQ-M2509 Combo
Panasonic omnivision tv/vcr combo
just press Stop/Eject Rew/<< buttons (Action) to get setup menu
Oct 10, 2007 | Panasonic PVQ-M2509 Combo
Panasonic PVQ-M2509 Combo Logo
892 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
