It got repaired from a local mobile repairing shop . but now same problem has occured.
Hello it is not a hard task....Please re-visit the mobile repairing shop and tell them to Unlock the phone.This is the only way.But remember before you visit mobile repairing shop check your phone's IMEI by typing *#06# when your phone is in stand by mode (during power on without sim card) and refer that the imei which is written on your phone back side is same or not.In case if the numbers are different tell them to repair the IMEI.Good luck.Thanks for visiting fixya
SOURCE: Phone in offline mode
'whether you want to continue in offline mode y/n'.,
when it displays this messege
press no
and u r done
SOURCE: nokia e65 phone is stuck on offline mode.
hi thanks for using fixya!
On this kind of error, I suggest you should bring your Nokia E65 to a Nokia Care Center in your area to further check the software error.
If you need further assistance, let me know. Please rate me! thanks!
SOURCE: my phone nokia 6680 has been in the offline mode.i want remove it
when you insert sim in your phone after using it offline,it should ask you if you want to continue using your phone in offline mode...select NO..Otherwise your phone cannot detect the sim card..clean sim terminals..if problem persists check and reheat sim filter IC..the crystal one, near the sim terminals itself..if all fails then UPP (CPU) or software problem..
SOURCE: My N95 Nokia phone in offline mode, I cannot call.
try to check your phone profile settings,it maybe set to offline mode, if it is set to offline, select a different phone profile mode from the list of the options.
try also cleaning the contacts of your sim card card and try again. sometimes, dirt or dust can be a reason for your sim not to be recognized by your phone.
if you have done these steps, try your sim in a different phone and check if it can be recognized. try another sim to your phone if the sim can be recognized by your phone. in this way, you will have the idea of which of the two has a failure.
Testimonial: "1.Not taking general or silent or meeting mode through profile. shows x 2.put several sims, sims working in other mobile.3.all phone functions working"
