Question about Jenn-Air JXT8136ADS Kitchen Hood
Vent fan when I turn on the vent fan I get a flashing A along with the speed (3) or (4) or where ever I have it set. so it flashes back and forthe between A and the number iI have it set.
  • Anonymous Feb 07, 2009
    I am also experiencing the flashing A
  • Anonymous Feb 24, 2009
    I also have thwe flashing A
Check manual. Fan has been on 30 hours. Reset counter by holding "-" for ~5 seconds.
Posted on Jan 03, 2010
  • 91 Answers
On going problem...Switch failure problem...replace..
Posted on Nov 04, 2009
Ep9r 500 speed button won't work keeps flashing f
The water level sensor fell into the fan. Unplug the humidifier from the wall, stick your hand in between the fan blade and locate the sensor. It is a small black rectangular piece the size of a nickel but rectangular and 3 nickels thick. It also has a 2 inch stem sticking out of that clicks back and forth when you push it. Stick the sensor back into the sensor whole and the flashing f will go away and the humidifier will come on again.
Feb 22, 2014 | Essick Air Whole House Digital Humidifier...
The LED indicator is flashing/blinking we replaced the lamp and it will not still turn on. someone suggested the cooling fan? Thank you Shawna2735@Gmail.com
If Fan is running when you turn TV on and keeps running then its OK ,Ballast Board is what turns Lamp on, Is Lamp Lighting at all?
Encompass Parts Distribution has Ballast board for $62.00
Be sure to give the whole model # to TV Ending in WXXaa
WAX/XAA or WX/Xaa HLR6167wxxaa or wax/xaa or wx/xaa
1-800-638-3328 You can also go to their website and type in your model # for List of Parts and Free Service Manual.
Sep 28, 2010 | Samsung HL-R6167W 61" HDTV
Fan light flashing on thermador vent hood model HNW36YS
Grease Filter Saturation LED The speed 2 LED in Figure 1 in is marked with an F. This LED will flash to remind you when the grease filter needs to be cleaned after 40 hours use. Follow the instructions for cleaning filters in thisFollow the instructions for cleaning filters in this booklet. Once the grease filters have been cleaned, reset the display by pressing button A for
Sep 05, 2009 | Thermador HNW48YS Stainless Steel Kitchen...
Sony grand Wega 50E20000 power light flashes 3 times
Check the fan is coming up to speed when you first switch on it should be high speed then slow down slightly. If the fan is not cooling the lamp the tv will turn off to protect the lamp
Jul 19, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Vega KDF-E5OA10,picture will not come on, tv goes off.
There is a real good chance that the lamp fan is not turning. If you look with a flashlight in the vent on the left side looking at the rear of the set and have someone turn on the unit, see if it spins. if it doesnt, the protect circuit in the tv will not let the set turn on. Replacing the fan will cure the proplem if it is not turning.
Hope this helps,
Skyassoc
Jun 17, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Dryer lights keep flashing after I've cleaned filter and air cooler
check exit of machine and vent tube if ok possible fan motor not up to speed
Aug 30, 2017 | Dryers
Standby LED flashes red 4 times with pause then 4 times
You either have a bad fan or one of the rotation sensors mounted on one of the fans has failed. Take the back off the set and see it the main fan slightly right of center is rotating. If it is, there are two more fans, one mounted right above the lamp and another on the optical block itself. You will have to pull the optical block to check those.
Oct 25, 2008 | Sony KDF-E42A10 42 in. LCD Television
Jenn-Air JXT8136ADS Kitchen Hood Logo
347 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Sal De
Craig Butler
Craig Butler
Paul Carew
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
