Question about Sega Dreamcast Console
Problems with sega dreamcast
Hello , can you offer some help , i mean would it be possible to ups you, 5 non working segas , please call me 559-592-9448 i believe my 3 boys have broken the controller ports , i believe there called capactor's , thank you for your asistance cris romero
  • 659 Answers
Hey cris yes it would be possible to get all those fixed no problem seems my repair listing keeps on disapearing off here so if you want you can send me a email to hpif@hpif.net and then I will send you all the info on prices ect. thanks and hope to hear from you on
Posted on Dec 29, 2008
Hi, my sega dreamcast console won't spin disc, please help!
try this youtube guide here http://www.youtube.com/watch?v=3rizeLEQyzs&feature=related, during the video the person will talk about a black plastic leave that gets pushed back by the dreamcast lid. if that lever is not being pushed back the drive will not spin. you can try the suggestion in the guide also.
Hope this helps,
Omeil
Oct 23, 2010 | Sega Dreamcast Console
I relly want to buy a sega dream cast repair
Go check Ebay....they have tons of that stuff
Aug 05, 2010 | Sega Dreamcast Console
My control wont work
did you tested another dreamcast control...you had the same problem...so you have to check the protection Fusistor inside your dreamcast conector controller board....it seems like a blue or green normal resistor...marked as F1 on the board..change it with a simple fuse or an smd fusistor...Good Luck!
Nov 23, 2009 | Sega Dreamcast Console
How do i format my sega dreamcast memory card
- Hello There -
  • Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
  • 2 Open up 'My Computer'. You should see it under the list of available drives.
  • 3 Check its contents first to make sure that you have the right drive.
  • 4 In 'My Computer', right-click on the drive and choose 'Format'.
  • 5 Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
  • 6 Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
  • Sep 10, 2009 | Sega Dreamcast Console
    Sega Dreamcast console problem
    First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
    To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
    Hope this helps.
    Feb 28, 2008 | Sega Dreamcast Console
    Dreamcast Loading problem
    you can get disks relayered at game stores.
    there was a long period where this happened to me.
    some games worked for a while, some didnt.
    its the dreamcast.
    you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
    try playing with the console upside down
    it sounds crazy but it worked for me.
    Dec 18, 2007 | Sega Dreamcast Console
    Sega Dreamcast screw
    The Disc drive has a connector on the bottom that has to mate up with the opposite gender connector on the top of the motherboard. you have to press the Drive down first then put the screws in.
    Nov 06, 2007 | Sega Dreamcast Console
    Sega Dreamcast Disk-reading piece
    cripes I think you may have mixed your screws up?
    1 it sounds like you are using a self tapping screw (it has a greater distance between each layer) rather than the tight screws which are for fitting the circuits together.
    2 I believe there are three screw holes for the disc reading part of the dreamcast and you really only need two to keep the disc player in place, so also try another hole.
    3 and one last thing to check you haven't put a screw underneath the board already?
    PROTEO25967
    I need you to explain more about your problem. Explain how your Sega Dreamcast is behaving. I'll be more than glad to help you.
    Oct 26, 2007 | Sega Dreamcast Console
    Sega Dreamcast Console Logo
    73 people viewed this question
    Top Sega Video Game Consoles & Games Experts
    DROPNDEAL
    DROPNDEAL
    Josh Whitehead
    Josh Whitehead
    Reggie brown
    Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
