Question about Canon PowerShot G9 Digital Camera
One day it worked and the next day it didn't wouldn't turn on.
It may be that a few days before I added a wi-fi card as the sd card (eye-fi) but I dont think so. I guess it's back to Canon.
5 Suggested Answers
  • 22 Answers
SOURCE: Canon Poershot sd300 digital elph. It just wont turn on period.
Try this: with the battery installed and battery door open, take a pencil, fine tip screwdriver, or anything long and skinny and push the tip of it into the little nub circled in the picture here. There's a spring inside that little nub... keep the spring depressed and try to turn on the camera. If it works, then either a small piece of plastic broke off the battery door or the nub got broken/pushed in too far for the battery door to trigger it. Try using a dab of hot glue to keep the nub pushed into the down position.
Posted on Apr 10, 2008
old marine
  • 2179 Answers
SOURCE: Canon Power Shot A400 will only work with original Canon SD card
Make sure you are using an SD card and not an SDHC card. The SDHC protocol is newer than your camera, and your camera does not support it. SD cards have capacities up to 2 GB. Your camera should work properly with any SD or MMC card.
Posted on Apr 22, 2009
  • 23 Answers
SOURCE: I have canon rebel t2i,just
check your memory card your using witht he camera. 550d is memory hungry and needs a high speed DSLR grade card such as the sandisk ultra 2 or extreme cards. or lexar professional series. sounds like you may have a faulty card or a card thats designed more for compact cameras and mp3 players
Posted on Feb 26, 2011
  • 102366 Answers
SOURCE: It's a canon powershot sd
You can download software, manuals, and more from the manufacturer's web site at
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd1100_is
You might want to consider NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Posted on Jun 10, 2011
I do not know how to transfer pictures from my Olympus SZ-14 to my ipad.
Because your camera uses SD cards, (SD/SDHC/SDXC and Eye-Fi) you have several options. The easiest and fastest possibility is to use a camera connection kit. On the picture the two on the left. The most left for iPad 1 to 3 (30 pins) the right for all anther iPads. Be aware these won't work on the iPhone or iPod. Then on the right is a WiFi card. Can be bought from Eye-Fi Transcend (Cheaper and much faster) and SanDisk. But more firms are bringing this item.
The Wi-Fi card is slower, because it is using the card as a hotspot. and the the fastest Wi-Fi is always slower than wired. The Transcend card, I also use to put the pictures on my iPhone, using Wi-Fi. he card has even more possibilities, like sending pictures direct to a computer, but you can check this on the sites from Eye-Fi and Transcend.
Both solutions can be the same in price, because when buying a Wi-Fi card, you also have a new memory card (Class 10 in case of the Transcend)
Feb 01, 2014 | Olympus Cameras
Tip
How do I Connect my Non-Wireless Camera to a Wireless Network
<p>Your digital camera can store images via a wireless network uses SD cards for memory storage. Special cards are available from SD Eye-Fi and also under the Lexar brand with Eye-Fi software, rather than just a flash memory, Wi-Fi radio that can connect to a local network and send your photos your computer contains. The SD card requires some special configuration and installation on your computer, but it transfers the files stored by the camera directly to your computer without further intervention. <br /> <p><br /> <p>1. Insert the Eye-Fi card in USB reader that came with it. Connect it to a USB port on your computer. If this is the first time you installed the Eye-Fi, the computer recognizes the new device and install the software and start automatically. If the software was previously installed, it will start automatically. <br /> <p><br /> <p>2. Register a new account or log in with your Eye-Fi account with your email and password. <br /> <p><br /> <p>3. Click the Eye-Fi for a firmware update if the exclamation mark symbol is placed. <br /> <p><br /> <p>4. Select your local network from the Network drop-down list. Enter your password and click "Add a network card." <br /> <p><br /> <p>5. Select "I do not want to set up online photo sharing and now" and click "Next." Some cards do not see this screen. <br /> <p><br /> <p>6. Remove the card when the display "Complete" and insert the card into the camera. <br /> <p><br /> <p>7. Take pictures and look for the wireless transmission on the computer. <br />
on Aug 05, 2011 | Cameras
Very Slow....Light Black Screen when opeing
If it has not corrected itself by turning the phone off and taking the battery out for a couple of minutes then turning it back on you should try a factory data reset. In Idle mode, open the application list and select
Settings - Privacy - Factory data reset - Reset phone
-Erase everything.
May 23, 2012 | Samsung S6102 Galaxy Y Duos - Black...
Installed a new graphic cards for Gateway DX4710-UB801A, it works for a day, but the next day, it wouldn't turn on, the power supply is not running.
Pull the new graphics card out to see if the power supply will start up, if no change, you will need a new power supply module.
May 11, 2012 | Gateway DX4710-UB801A (L-1015700R) PC...
Baud rate setting
There has been much written on the SYNET 07526. After playing with it for two months I have a few observations.
1. It is not a toy...It DOES WORK, but it is also temperamental! It's NOT an IPOD or other tablet and it is somewhat S-L-O-W. But it DOES WORK despite the impatience of some comments on this site or YouTube. And the price was very right - under $100!
2. Best solution is to download the Digital Gadgets OS Image from their website. Update exactly as directed onto a 1-2 GB SD Card in your MAIN computer (actually I bought a card reader/writer to do this - Do Not load the update to a USB drive - the netbook won't recognize it using that port. Extract the "Script" program from the download and send it to the SD Card. Turn off the computer, remove the SD card update. Place the SD card into the netbook while it is off and when you turn the netbook on the program will load automatically. DO NOT TOUCH ANYTHING UNTIL THE ENTIRE "SCRIPT" FILE IS INSTALLED ON THE NETBOOK.
Use the RT 28701 Connection network. It should be defaulted already.
You may also notice "Google" is now the default I.S.P. Try first entering a "subject" into Google Search first( e.g. "cats" or "dogs" - rather than entering an actual website. Some sites with a lot of graphics will be slow or won't load and you'll get a "can't open page" message)3. If you check you will also see the dial up BAUD RATE defaults to 19,200 baud. I kept this setting and it was fine.This is the dial speed, if you go through modems that are encrypted and need authentication. RT 28701 uses wi-fi directly and should connect to local "host" wi-fi sites.
4. Look for "Disabled" encryption and "Open" authentication when configuring the netbook or it may not connect to the wi-fi host without a password.
5. There is a difference between "associating with..." and "connected to..." If you're not "conected" you're just browsing available access points in the area that your wi-fi receiver is scanning. Click on your "preferred" site and hit "connect" when you've got a good signal. If you get bumped off, it's because your netbook configuration is not compatible with the wi-fi host.
6. Try different locations such as near hotels, McD's, Starbucks, etc. where the wi-fi is open to guests and try your netbook there. If you get on the web via Google your netbook is fine.
Mar 27, 2012 | Sylvania G-Netbook
"File contains no image data"
Try a new SD card. SD cards do fail.
The socket inside the camera maybe no good - bad connections.
The camera may have liquid damage - this causes all kinds of weird issues.
I try the cards in my computer reader. If they can be used all day there (I load and unload stuff randomly all day to test and then put the card in a drawer for a few days and check what I loaded later), the fault is likely the camera.
Apr 17, 2010 | Nikon COOLPIX L18 Digital Camera
Installing a SD wi-fi
First remove the SD Card, then remove the drivers for the SD card. do a soft reset. install the driver for the card. go to settings, system, then remove software and check tat the software shows up. Oh by the wy make sure you have the HP SDIO fix install first. ok make sure that bluethoot is off. Install the SD Card. now go to settings, then connections tap on connections. tap the Advanced tab, tap the Network Card. you should see the SD Card listed. tap the Card. the next screen ask if you want to set the IP address or have the server assign the IP. I leave it at the default and let the server assign the IP.
Tap ok 3 time that should close everything. and you should be set. if you have a wi-fi setup you need to tap on start then programs, then tap on "WLAN" this program is what you use to check your signal strenght and check if you are getting a signal from your wi-fi. Once the signal strenght is strong enough you will see that an IP address will be asigned and you will be asked if you want to connect.
I hope this Helps
Oct 17, 2007 | HP iPAQ H2210 Pocket PC
E400 with Sandisk 256mb + Wi-Fi
Sorry, Sandisk 256mb + Wi-Fi SD Card is not compatible with e400. Only Sandisk Wi-Fi SD Card without additional memory is working.
Sep 11, 2005 | Toshiba e400 Pocket PC
E740 BT can be upgrade to Pocket PC 2003 ?
Sorry but I think that you must choose worst scenario. You should buy “SD Wi-Fi Card”.
Sep 08, 2005 | Toshiba e740 Pocket PC
Canon PowerShot G9 Digital Camera Logo
24 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
