Question about Toshiba Qosmio G15-AV501 Notebook
G15 speaker removal
My speakers seem to have stopped working. Does anyone know how to remove the internal speaker on a Qosmio G15?
I was given a qosmio G15-AV501, but it appears to be overheating about 10 minutes of operation. It will run for a little while, then just shuts down. Between 5 and 15 seconds before it turns itself off I...
No particular problem with your unit. In your case it appears that the fan isn't operational - open the laptop and replace it.
Also check in the BIOS the shutdown temperatures, they might be set way too low.
Sep 08, 2010 | Toshiba Qosmio G15-AV501/R Notebook
Toshiba Qosmio G15-AV501 will not boot
Subscriber/user FMFM85 had posted a solution for another laptop that worked for me. That was Power down, remove battery, remove power, wait five minutes, plug in power and do not install battery, I rebooted to last known good configuration. This method got me further along.from the absolute DEAD state the laptop was in. Now I know that the laptop is really hosed in other ways. I will keep you posted.
Feb 22, 2010 | Toshiba Qosmio G15 Notebook
My laptop wont start its a toshiba g15
have you tried pulling each stick of ram individually?
if there is still no boot then its safe to say that the motherboard or one of the two video cards has failed. its a pretty common on the qosmio g series
Nov 03, 2009 | Toshiba G15-AV501 Qosmio Notebook
Hard drive not showing in bios
It appears that your #2 hard disk has died. To test if it is faulty, remove the #2 drive and connect it to an USB hard drive adapter and plug it into the USB port of a working computer. If the computer see it as an external USB drive and you can see the folders and open the files, then it is OK and the fault is possible the disk controller.
If the hard drive is not recognised then it is faulty and needs to be replaced.
Jun 27, 2009 | Toshiba Qosmio G15-AV501 Notebook
New hard drive for my Toshiba Qosmio G15 R laptop
I believe with Toshiba they normally would give you a recovery disk and then a drivers and utilities disk as well. If you don't have both then I would suggest installing windows xp and then go to this page:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835452&rpn=PQG10U&modelFilter=G15-AV501&selCategory=3&selFamily=804517Click on the downloads button and from there choose your operating system and you can download the drivers from that page.You'll know which drivers you'll need by going into the device manager and seeing what has a yellow question mark next to it.If you need more help with this let me know and I'll help you more.
Jun 08, 2009 | Toshiba Qosmio G15-AV501 Notebook
I have a Toshiba Qosmio G15R and I need drivers
I went to the Intel site and downloaded the Intel® PRO/100 VE Network Connection driver here. It worked great. Now if I could find the right audio/multimedia drivers I'd be happy. Hope this helps.
Dec 26, 2008 | Toshiba G15-AV501 Qosmio Notebook
My daughter put a password for the bios and cant remember it.
Try holding down the "Left Shift Key" when turning on the system
Nov 28, 2008 | Toshiba Qosmio G15-AV501 Notebook
Qosmio g15 recovery disk error
If the discs are clean and pretty much scratch free, then this is most likely a bad hard drive. If you have another PC or laptop, try burning copies of the recovery cds and then use those. If the problem remains, you will need a new hard drive.
Dec 09, 2007 | Toshiba Qosmio G15 Notebook
Nvidia Gfofce FX
I had the same problem, what you need to do is call Pamela Saunders at Toshiba Corporate in Irving, CA and she will get it repaired for you at no cost to you regardless of warranty. This is a bad batch of computers.
The Phone Number is: 800-457-7777 or 949-462-6000
Nov 04, 2007 | Toshiba G15-AV501 Qosmio Notebook
Qosmio g15
Could you explain this problem just a little more?
Aug 09, 2007 | Toshiba Qosmio G15 Notebook
Computers & Internet Logo
83 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
