Question about iRiver T20 MP3 Player
T20 makes me mad
Hell pls help me with my t20 mp3 problem ,it went dead when i put it in my pc nothing happens ,and my technicians said that it is a model that cant be open,i dont know what to do im so comfused,pls help
  • techoN00B Nov 29, 2008
    i got then same problem.i put in the usb connector and it say usd connected and it is charge.but when i release it from the pc and try to open it.it could not be open.why???
  • viktor519 Mar 20, 2009
    AARRGH!I have the same problem!!!!
It is possible to restart the iriver T20 by inserting a needle into the little hole next to the USB slot
Posted on Jul 29, 2008
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Posted on May 23, 2008
I've put mp3 files on, but nothing's playing
Simply the player is dead! If you connected player to the pc with no problem it means NO ERROR messages and the driver for the player is ok, you have copied all the mp3 files in ONE directory to the player and nothing happened there are only two possibilities either the PLAY button is stucked or the mp3 player is dead!
Jan 08, 2014 | Audio Players & Recorders
Just got this t20 plug in grn light press start battery light flashes then nothing. not give password no noise and nothing on the screen
This is considered as DOA (dead on Arrival) you should call the tech support in Atlanta GA to help you resolving the problem. They will provide you information on how to return the product.
Call this number: 1-800-426-7378
hope it helps you!
Sep 08, 2010 | IBM ThinkPad T20 2647 Notebook
IBM T20 screen bad, IBM i1400 screen good-Compatible?
Yes, it's possible, but unless you are a qualified laptop technician, I recommend that you take both computers to a qualified technician, to get the job done properly and safely and correctly.
Dec 19, 2009 | IBM ThinkPad T20 2647 Notebook
T20 low battery and no recharging
this is problem with your hardware.......
Jun 20, 2009 | iRiver T20 MP3 Player
My samsung mp3 player yp-f1 wont power up and when i plug it into the computer nothing happens either just like it went dead it does not power on, the pc recognizes the device you can upload music on it...
My Granddaughter has the same problem, but with intermittent problems.
Turned out she went to the beach and had gotten sand into the dial.
I took an air hose and blew around the dial while turning it. It works well now.
Hope that helps.
May 07, 2009 | Samsung YP-U3 MP3 Player
Pls help!!!
Make sure you have the latest version of Windows Media Player. XP has all the right drivers but the iRiver needs to synchronise with Media Player inorder to transfer music onto the player using the sync function. Get Media Player 10 or higher then plug the iRiver into the computer.
XP should display it as a drive in "My Computer". It may require a firmware upgrade. This can be downloaded from T20 Firmware Upgrade V1.71
No Guarantees....Hope this helps.
May 21, 2008 | iRiver T20 MP3 Player
Was fine now dead
Hello jessisme,
What you describe sounds like either a battery problem or a hardware failure. I would recommend trying to charge the unit following the normal charging procedure listed in the manual.
If the unit will not turn on at all after charging then most likely the battery has failed or the or unit has some other hardware problem that will require service. If this is the case, I'd recommend contacting the manufacturer via their website at http://www.sandisk.com/techsupport for additional support.
Best regards,
Ken
Go Ahead. Use Us.
May 07, 2008 | SanDisk Sansa Clip MP3 Player
Windows xp drivers
Jan 18, 2008 | iRiver T20 MP3 Player
Iriver T20 USB went DEAD
Aug 15, 2007 | iRiver T20 MP3 Player
Not again wont turn on
i had the same situation this happens when you dont turn off your t20 after you disconnet it from your pc IRIVERS T2O PROBLEM IS THAT IT AUTOMATICALY TURNS ON EVERY TIME YOU DISCONNET IT FROM PC AND IF YOU DONT TURN IT OFF AFTER THIS - IT FROZES it wont connect to pc after this happens so you have to wait ussualy (~12 hours) until the battery runs low, so after this has happened wait and then after some time try to press play button (to turn it on) and if the battery is dead - it will show LOW BATTERY sign and then you can connect it to your pc again normaly! hope this will help
Feb 28, 2007 | iRiver T20 MP3 Player
iRiver T20 MP3 Player Logo
368 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
