Question about Dell Inspiron 1200 14.1 XGA LCD Display-320-4222 (3204222) CD-ROM Drive
Fuzzy display on LCD and External Monitor
When I boot up, the display is full of colored rectangles and lines popping in and out. The text is hardly visible. This happens on both the LCD display and the external monitor display. It did clear occasionally for an active window while remaining fuzzy in other screen views. I can't see text clearly enough to read it.
    Guru:
  • 210 Answers
It sounds like you may have an updated driver that doesn't work with your machine. boot into SAFE mode. on a dell it is hitting the Del button for most of them as it is booting up. then choose safe mode. For other dells it is F1 or F2 you just keep hitting the button while its booting up until you hear it start to beep at you. then look for safe mode. while in safe mode you can then change the driver, but for those specifics you have to go to dells web site. http://www.dell.com/support/home/us/en/19/quicktest?c=us&l=en&~ck=mn
Posted on Dec 03, 2017
5 Suggested Answers
FixinFax
  • 3085 Answers
SOURCE: Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Posted on Jul 04, 2009
Hugh fulton
  • 62 Answers
SOURCE: dell latitude830 completely black screen even on external monitor
Sounds like you need a new video card. Thank goodness you were able to retrieve your data. The new USB flashsticks are great for backups.
Good Luck
Posted on Sep 13, 2009
  • 48 Answers
SOURCE: screen now is pale green and print is fuzzy
Actually, it might not be the inverter. I've seen this sort of color fault simply because of a bad wire on the monitor's connection to the video card(or a slipped wire, in some cases.) Do you know if the monitor is using a VGA-based connection? Obviously, it will not be a 15 pin D-type plug, but it will likely be of a similar architecture, and if any one wire gets damaged or disconnected, it can severely alter the way your display comes through(specifically, coloration. I've seen it simply make a monitor dimmer and more beige, I've seen it turn a display green(like your issue))
The trouble is, with this, is that you're not gonna find a replacement laptop monitor cable at your local radio shack. However, you Might be able to order the part from Dell, if your product is out of warranty, for a small fee(I know that HP will usually sell you the part, as will Hanns-G). Before you do this, test the continuity of all of the wires in the cable, to determine that there is in fact a fault there.
Posted on Apr 23, 2010
  • 42 Answers
SOURCE: Laptop monitor bad color and flickers continuely, but when attached to external monitor, works fine
I'm going to take an educated guess here, because it sounds like the monitor's interface controller is bad. I forgot the name of the thing, but it's a small circuit board that's normally located at the bottom of the panel frame, between the flat ribbon cables and the round hinge cables.
"Inverter Board"
Posted on Mar 19, 2013
No display it is power is on
Hook up to external monitor .. Does the pre boot screen pop up (black and white writing at start ) ? If display runs on external monitor then your screen needs replacing usually or if you see a vague image on laptop screen then inverter or backlight is gone .. if no display on external and no pre boot screen probably the graphics chip on laptop has malfunctioned.
Dec 15, 2014 | Acer AL2021M (Silver) 20" LCD Monitor
Tip
LCD Display Problems with Apple 15" PowerBook G4 Aluminum 1.25 GHz Mac Notebook
During boot-up, Apple logo heavily pixelated. After boot-up, display a riot of colors and vertical lines with nothing readable. External monitor works well
I'll appreciate any input.
~ JO
on Feb 08, 2008 | Apple PowerBook G4 Mac Notebook
Unclear lettering & numerics
1: Resolving Laptop LCD Lines,
Fuzzy, Color, or Blurry Issues
Verify that the BIOS and Video drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website"
Test the LCD in the System Setup (BIOS).
To enter the computer BIOS Setup Screen perform the following steps:
At the first text on the screen or when the Dell logo appears, tap <F2> until the message Entering Setup appears.
Note:
Some older Dell computers use an alternate key sequence instead of to enter System Setup. These key sequences include:
<Ctrl>+<Alt>+<Enter>
<Delete>
<Fn>+<F1> (laptop computers only)
<Fn>+<Esc> (laptop computers only)
If you observe the same issue on the setup screen, it is not an issue with the Operating System, it is a hardware issue, Contact Technical Support/font>.
Run the Laptop Built-In Self-Test (BIST).
To run the Built-In Self-Test perform the following:
Turn the computer off.
Press and hold the D key while pressing the power button. This will start the BIST.
The screen will display multiple flashing colors. Look for lines, distortion, or any other video issues you have observed.
The laptop will restart when the test is finished.
Click the following link to see an English-only video of this test How to Run LCD BIST Video .
If the LCD BIST passes, proceed to Step 4, otherwise Contact Technical Support.
For information on Beep Codes/Error Codes refer to Dell Knowledge Base article, Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers
Connect to an external monitor (if available), for the different types of external monitor ports that may be available on your computer refer to (Figure 1).
Display Port
Display Port is a new digital standard for connecting monitors to computers and has the capability to provide a scalable digital display interface with optional audio and high-definition content protection (HDCP) capability. Display Ports usually resemble USB Ports with one side angled.
A Display Port cable should be used if Display Port connectors are available on both the computer and the monitor.
DVI
Digital Video Interface (DVI) is the digital standard for connecting monitors to computers. DVI connections are usually color-coded with white plastic and labels.
DVI cables provide a higher quality signal than VGA cables. A DVI cable should be used if DVI connectors are available on both the computer and the monitor.
VGA
Video Graphics Array (VGA) is the analog standard for connecting monitors to computers. VGA connections are commonly color-coded with blue plastic and labels.
A VGA cable should be used if DVI connectors are not available on either the monitor or the computer.
Once it's connected, press and hold down the FN and press F8, this should display the screen on the external monitor.
When the external monitor does not work or you did not have one to test with, Contact Technical Support.
When the external monitor does work it may be an issue with the Operating System. Verify that all the drivers are the latest available from Support.Dell.Com Website, for more information refer to Dell Knowledge Base article, "How to Use the Drivers and Downloads Website". When that does not fix the issue the Operating System may need to be reinstalled, for more information refer to Dell Knowledge Base article, "How To Restore or Reinstall Microsoft Windows on a Dell Computer".
Check for visible damage to the LCD. To identify any damage not visible to the ***** eye, ensure you run LCD BIST on the system (refer to Step 3).
If the LCD has damages which is not covered by any applicable statutory warranty, limited hardware warranty and/or Dell-branded service, including Complete Care / Accidental Damage service, there may be a cost incurred by you for the replacement of parts.
Oct 04, 2012 | Dell Computers & Internet
Fuzzy display
It could be that the crystals in the LCD are frozen, which has been known to happen in Defective Models. I recommend a New LCD. If it still works on a external monitor it is not a Video Card. Also, if you want to try a cheaper alternative, try just replacing the device under the LCD, which controls Color and Brightness. Google it, the name varies with people, so i cannot name it.
Dec 22, 2009 | Acer Aspire 9300 Notebook
My laptop is on and plugged to the monitor, but the monitor says no signal
You have to switch your laptop to a different display mode. Usually it's done by pressing Fn key and F8 - look for a description near this key showing rectangle / rounded rectangle, or text "CRT / LCD".
Usually there are 3 modes:
LCD (internal laptop display) only
LCD + CRT - the picture shows on both displays
CRT - the picture shows only on the external display, allowing you to set a different screen resolution, equivalent to the external monitor's optimum resolution.
Oct 29, 2009 | Acer AL1916W 19" LCD Monitor
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
Monitor issues Acer 5610-4621
sounds like a bad video card honestly. I doubt the monitor was bad.
May 29, 2009 | Acer Aspire 5610-4648 Notebook
Nothing happening
When you start up the laptop, tap the F2 or F10 key like a piano in four four time and see if you do not get a bios setup screen, sometimes called a System Setup Screen. If you do post back to me as soon as you can and await my instructions, but basically you want to page through the setup screens until you find a setting for the external display default. Change this back to the laptop panel. It is probably set to an external display monitor or LCD panel.
On your keyboard are special keys you are probably familiar with. These are used in conjunction with the Fn key. To activate an external monitor and turn off your LCD display, you would press the Fn key + the F key that has an icon on it in the same color as the Fn keytop. The icon for the external monitor looks something like this |O| with the circle here being replaced by a rectangle. Often this is just replaced with two rectangles, one filled with shade one not. The F Key is almost always the F5 key.
To test this, start your computer, then press the Pause key. Then press the Fn key plus F5 or which ever key it was that you found with an icon as I attempted to desribe.
My guess this is what has happened, the alternate external display is activated and this needs to be changed. Sometimes you have to go into the System setup pages and tell the laptop you are on the Panel display by default and not the external monitor, otherwise you will have to press the Fn key sequence every time you boot.
Let me know how you make out.
Regards,
Worldvet
Aug 04, 2008 | Compaq Presario M2000 Notebook
Vertical lines, colors not sharp, graphics fuzzy
could be the vga car4d problem, try to hook up with another pc if the problem remains then unfortunately the monitor is dying.
Jan 06, 2008 | Envision EN-7100e 17" Flat Panel LCD...
Dell C400 will not boot using LCD screen when cold
I have seen this problem before, after booting to the external monitor go into the display settings and try setting the resolution to 1024 X 768 and the color settng to 16 bit or preferably 32 bit. If you can do this, then shut down the laptop remove the external monitor and try booting on the LCD display. BPCS
Nov 17, 2007 | Dell Latitude C400 Notebook
Computers & Internet Logo
180 people viewed this question
Clive
Clive
Alun Cox
