Question about Slant Fin GF-240 1.9 Ga Germ-Free Cool Mist Evaporative Humidifier Humidifier
Slant fin GF-220 humidifier won't produce vapor
I cleaned and reiflled it and then it quit producing humidity. The UV buld replacement light glows briefly when I turn it on and then goes out. Does this mean the bulb is shot?
5 Suggested Answers
  • 105 Answers
SOURCE: No instruction manual
FILLING THE WATER TANKS
1. Before filling the water tanks, push the POWER switch to the “OFF” position and
unplug unit. Refer to cleaning instructions.
2. Remove water tanks from base, turn each tank upside down and remove tank cap
by turning counterclockwise. Fill tank with clean cold tap water.
Replace the tank cap by turning clockwise. Tighten firmly.
3. Carefully pick up tank, since it will be heavy when full, and slippery if wet.
4. Place water tanks on base. Make sure tanks are properly placed, otherwise, the
humidifier will not work correctly.
Posted on Feb 11, 2009
  • 114 Answers
SOURCE: I need to know where the filter goes on a
by what i have found for your model it doesn't have a filter persay. it has pads and they go right under the tank.
Posted on Aug 20, 2009
roadtech7
  • 297 Answers
SOURCE: On my Slant Fin GF-200
The refill/reset light comes on after the water level drops, Did you add water?
If so you might need to clean it twice.
Hope this helps, Matt
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Dec 05, 2010
  • 188 Answers
SOURCE: We have a Slant/Fin GF-220 Humidifier and it
Check the drain- make sure it is not plugged due to the calcium in the water. May be plugged.
check for any cracks or misalignment on the plastic water tank.
Posted on Feb 18, 2011
How do I clean it?
If you're asking how to clean the inner workings of the humidifier ... Run a 50/50 solution of White Vinegar and Water through it. Then flush it with Bottled Distilled Water. As a matter of fact, using Bottled Distilled Water all the time, will cut down on having to clean the unit as often. Distilled water has no minerals and will not produce scale, like tap water.
Mar 10, 2011 | Slant Fin Cool Mist GF-220 Humidifier
We have a Slant/Fin GF-220 Humidifier and it started leaking. We thought it was maybe because it wasn't on a level surface but it is leaking no matter where it is. Any ideas? recommendations?
Feb 18, 2011 | Humidifiers
My Slant/Fin GF 350 suddenly will not heat the water and has the "fill/clean" red light on even though it is clean and has a new filter in it. there are no mineral deposits in the well, and no...
the rusted sensors are the cause of your problem - as soon as the sensors do not conduct an electric current through the water (either because there is no water or because they have decayed), the humidifier shuts itself off. You will need to replace the sensors. var viewReq = new Array();function vu(u) {var i=new Image();i.src=u.replace("&","&");viewReq.push(i);} vu("http://googleads.g.doubleclick.net/pagead/adview?ai\x3dB3Oe4m7gKTa-UBNCi6Qbh1uhIjbTQzgH1yJ29FJ2PiKQXABABGAEgADgBUIDH4cQEYMn-vYzYpOARggEXY2EtcHViLTMzODQ5NDYyODUzNTE5NTayAQ13d3cuZml4eWEuY29tugEKMzAweDI1MF9hc8gBCdoBTWh0dHA6Ly93d3cuZml4eWEuY29tL3N1cHBvcnQvdDY2NzU2OTctc2xhbnRfZmluX2dmXzM1MF9zdWRkZW5seV93aWxsX25vdF9oZWF0mAKsG8ACBMgCtZzVEeACAOoCIzYxNTMvZml4LmhvbWVnYXJkZW4vaGVhdGluZ19jb29saW5nqAMB6AO8BugDgQn1AwIAAATgBAE\x26sigh\x3dDErSUArfSlA") body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; }
Nov 03, 2010 | Slant Fin Warm Mist GF-350 Humidifier
Feb 11, 2009 | Slant Fin Cool Mist GF-220 Humidifier
The ceramic coating under the nozzle deteriorating
Check this page out. It also has the owners manual listed. https://www.appliancefactoryparts.com/humidifiers/slant-fin/gf220.html
Nov 05, 2017 | Slant Fin Cool Mist GF-220 Humidifier
Slant fin gf-210 needed part
slant fin sold the humidifier biz to another company.  info at the slant/fin site http://www.slantfin.com/contact.php
Nov 18, 2008 | Slant Fin GF-210W 2 Gallon Humidifier
Need a replacement tank
http://www.humidifierfilters.com/parts4models.php?brand=slant%20fin&model=gf350
You'll be able to order a replacement tank through this link. They are currently out of stock for your tank but the site says they are getting more in. I would write to them and find out how long.
Good Luck.
Apr 20, 2008 | Slant Fin Warm Mist GF-350 Humidifier
Leaking rubber boot
Mine did the same thing at the end of last winter. I did not discover it to be one of the rubber tubes (boots as you say) until I went to use it this past fall. The manuf. said send it back for a replacement (they do not fix these or offer parts) which I did in Nov. and still have not received the replacement. Nice deal for them.
Feb 05, 2008 | Slant Fin Warm Mist GF-350 Humidifier
Clean/refill light
My Slant Fin humidifier has a floating, ring-shaped magnetic level that isn't replaceable. You can't even tell it's magnetic until you cut off the piece that prevents the white plastic float from rising past a certain point. It turns out that there is a ring-shaped magnet in the float.
I found that the Refill light would go off when I held a strong magnet near the float device.
So, I have suspended the magnet with string from the top of the humidifier outside the humidifier.
Caution: This fix disables the safety feature inherent in the low level shut off. I wonder why the manufacturer uses material that corrodes?
Oct 14, 2007 | Slant Fin Warm Mist GF-350 Humidifier
Lost instruction manual
Slant/Fin has sold the humidifier and PC-55 air purifier business to KAZ USA Inc. If you need replacement parts, repairs, or have any questions regarding the products, please contact them at: KAZ, Consumer Relations Dept. 250 Turnpike rd., Southborough, MA 01772 Phone: 800-477-0457 email: info@kaz.com also worth a look is: http://www.achooallergy.com/slantfin-operating-instructions.asp seems to be best forum for humidifier stuff
Feb 14, 2007 | Slant Fin Cool Mist GF-220 Humidifier
Slant Fin GF-240 1.9 Ga Germ-Free Cool Mist Evaporative Humidifier Humidifier Logo
164 people viewed this question
Top Slant Fin Humidifiers Experts
Matt Olenzek
Matt Olenzek
Rich Brown
Marvin
Marvin
Are you a Slant Fin Humidifier Expert? Answer questions, earn points and help others
