Question about Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt
Hard starting and when warms up rpm's drop
I have a husqvarna 125bt back pack blower. it is hard to start and once the engine warms up the rpm's drop. any help is appreciated.
thanks
  • fkreager Dec 21, 2008
    it is very hard to start and once it starts it blows like normal but once it warms up the rpms drop and it will not blow as hard as it did when it was cold
  • Stephen Evans May 11, 2010
    what state are you located
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
Remove the muffler and inspect the piston, rings and cylinder for vertical scoring. If so You may need a top end rebuild.
Posted on Apr 10, 2009
Husqvarna 125bt backpack leaf blower starts fine but once shut off will not restart for hours.
it might be the coil my chain saw did that put new coil on and that fix it.// had another chain saw do that it was full of dirt cleaned it out and that fixed it.
Aug 19, 2014 | Husqvarna Garden
Broken pull rope on 125BT Backpack Blower
Most small engine shops and big box stores like home depot sell generic replacement starter rope. If you want the exact part from Husqvarna, there are 2 engine variations for the 125BT. The rope for the AC57 enigne is part# 531009567, the rope for the AC55 engine is part#531009653.
Jan 04, 2011 | Husqvarna Forest & Garden 125bt Backpack...
My Husqvarna 125BT leaf blower will not make full power anymore. The past few weeks I noticed a strange sound best described as as a rattle similar to a loose baffle. Starts and runs fine but only makes...
Try pulling the muffler off and checking for blockage in the exhaust port, expecially the small hole above the main exhaust port. This is the same thing that my 125bt was doing this season and after cleaning out the carb with no improvement, I found some carbon build up in the exhaust port. The small hole above the port was completely blocked. After cleaning up all of the carbon buildup, it ran back to full power again.
Oct 30, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
I have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
If you need further help, reach me via phone at https://www.6ya.com/expert/gerardo_79638d1eac6a0a1f
May 15, 2010 | Husqvarna Forest & Garden 125bt Backpack...
Husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Oct 21, 2009 | Husqvarna Forest & Garden 125bt Backpack...
I put gas without oil in the Husquavarna back pack blower. Is it ruined?
Can you turn the engine over?
Did it stop by it's self or did you stop it?
If it still runs.....mix oil in the gas at a 50 to 1 ratio and run it.
If it does not run or turn over it is most likely ruined.......but
take the spark plug out and put a little 2 stroke oil in the cylinder and try to turn it over.....if you get the engine turning.......put the spark plug back in and try to start it.
Sep 07, 2009 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Leafblower
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. check the primer bulb for pin holes and seating/sealed properly. if that doesn't work have the carb repaired at a service center or replaced.
Oct 18, 2008 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Husqvarna Backpack Blower 25cc, 140 Mph, Model# 125bt Logo
609 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Jay Finke
Jay Finke
lnbn1975
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
