Question about Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III clean light blinking green
I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for 60 seconds to no avail.
  • 13 more comments
  • hardtop55 Dec 22, 2008
    Thank you so much, it worked! hardtop55
  • philmundy Dec 29, 2008
    I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for varying lengt5hs of time but problems persists. I tried the solution posted by "rhinostack" (heat dry normal heat dry normal cancel). It ran the 2 minutes, then opened and closed, but Clean light is still blinking and I am still locked out of the wash cycles.
  • Anonymous Dec 29, 2008
    What part needs to be replaced ??
  • Anonymous Jan 01, 2009
    YOU... Rhinostack.... ARE THE MAN!!!!
  • Anonymous Jan 03, 2009
    I had the same problem and Rhinostack worked.
  • skyray Jan 11, 2009
    Rhino rocks - solved same problem here! My wife doesn't have to hand wash, so she is syched!
  • marlame67 Jan 16, 2009
    WOW!!! I just followed what this brilliant poster said to do...and it worked--YEAH!!!!
  • Anonymous Jan 20, 2009
    Light china light on my kitchen aid washer is blinking and I cannot turn on machine. What is wrong?
  • willis8888 Feb 15, 2009
    My whirlpool quite partner II is stuck because of clean light keeps blinking.
  • gcbbl Mar 13, 2009
    this fixed my blinking light problem. but i think i know what caused the blinking light . my machine now turns on but makes a hum noise when goes to wash cycle . prior my wash motor was noisy , i think it locked up now. anybody know a cheap place to get a washer pump motor for a whirlpool quiet partner I dishwasher
    any advise would be greatly appreciated. thanks
  • strople Mar 14, 2009
    The clean light on my Whirlpool Quiet Partner III was blinking: 7 blinks, pause, 7 more blinks. The sequence of heated dry, normal, heated dry, normal, followed by cancel worked! Thanks for posting this solution. I was looking at a counter full of dishes and an expensive service call.
    Geoff
  • Anonymous Apr 03, 2009
    Thanks you so much!!! The suggestion from RHINOSTACK worked perfectly.
    YEAH!!!
  • Anonymous May 03, 2009
    The sequence worked for mee too, thank you very much.
  • Robert Newberry
    Robert Newberry Oct 21, 2013
    Had clean light continually blinking, did some troubleshooting and found heating element to be bad. Changed the element and light continued to blink, searched the web for some help and found the "heated dry, normal, heated dry, normal sequence to reset dishwasher to work and correct the blinking light. Thanks!!
Press:
heated dry
normal
heated dry
normal
then cancel..... wait until 2 minute cycle is done. open and close the door and make sure it is closed.
Then run another cycle. saw this on another post and it worked for me. They said that if it did not reset then either the latch has a bad connection or the heater for the water is bad.. it must register that the door is closed in order to actually start the heater for the water. I hope this helps you as well as it helped me.
---Rhino---
Posted on Dec 22, 2008
  • 5 more comments
  • adamotstot Nov 24, 2010
    Thank you so much for posting this. Had the same problem and was stressing out because I had no idea what had happened or how to fix it. This did the trick!
  • Lory McCoy Nov 15, 2011
    Awesome information, this 42 yr old grannie saved herself a 115$ service call!!!! Thanks a bunch!
    Loraine
  • Kerri Dec 07, 2011
    Thank you sooo much! This really worked! I am grateful. Thought we were going to have to pay for a service call and repair right before the holidays. Thanks!
  • amandanunez1 Jan 13, 2012
    Oh my!!! Thank you so much you saved my day! I was just searching for new dishwashers! Thank you!
  • melissa_bunn
    melissa_bunn Jul 26, 2012
    Wow that worked received this dishwasher from a friend because she thought it was broke - she bought a new one and this one now works fine. THANK YOU!
  • Teresa Holbrooks
    Teresa Holbrooks Apr 07, 2014
    Fabulous, Thanks.
  • Gene Mrava
    Gene Mrava May 16, 2014
    there is no "Heated Dry" button onmy QP III - only an "Air Dry" button
It really worked. I followed the heat-dry, normal, heat dry, normal sequence and it worked while the service guy left here scratching his head. Excellent resource. Thanks.
Posted on Feb 18, 2009
  • Marissa Wisnewski
    Marissa Wisnewski Nov 11, 2013
    Thank you so much for this post! This just happened to us and wehave tghe same model and we had just purchased this house 3 weeks ago and the last thing we wanted was to purchase a new dishwasher! Thanks again!
The heated dry, normal sequence worked!! Thank you. We probably would ordered an expensive new control panel if we asked the repair services.
Posted on Apr 23, 2009
  • lve2shp Jul 29, 2011
    This worked!!!! I tried the heated dry, normal, heated dry and normal (did not work when I pushed cancel). Thanks so much!
  • Bruce LeVan
    Bruce LeVan May 26, 2014
    I did the heat dry, normal, heat dry, normal, heat dry, normal, cancel, it worked for me thank you for sharing.. :-)
Try the door switch first. This is a very easy fix if it is it. Otherwise you will kick yourself for not trying it sooner if it turns out to be the problem, trust me I know. Push in on the door when it is closed to close it tighter. If you here a click, and then another click when you release the pressure, then the switch could be your problem. Even if you don't hear a click, try this fix first. There is a double switch in the latch and the one for the heating element can be left off when the rest of the machine is on. I had this problem. I bent down the thin metal tab that the door latches onto. Bending it just a little fixed my problem. Don't bend down too much or you will keep the door from shutting properly.
Posted on Jan 19, 2009
Thanks! I just had to pay a technician 35.00 to diagnose what wasn't wrong. He said I needed a control circuit board and It was going to run me over 200.00, parts and labor!
Posted on May 22, 2009
When I did heated dry, normal, heated dry, normal, cancel, it did not work for me. So I did the same sequence without hitting cancel and it reset itself. Try this if the other way fails.
Posted on Apr 19, 2010
  • madallmy Feb 06, 2011
    Genius. Thanks. I tried this way and all the panel lights came on...it resumed 9 mins of wash cycle on its own (dont ask me why it resumes a wash cycle) and at least I hear
    water moving around...first time in two days. After its finished...I would suspect open and close and start a new cycle. Its early, but thanks. I really dislike this machine and look forward to replacing it soon, (not financially tho). :>)
  • Deborah Nov 26, 2012
    madallmy, my dishwasher is less than two years old, but it did this problem with me and of all things after thanksgiving dinner when I had a full load. I normally wash by hand when it is just dinner dishes, but I was so tired from cooking and baking for two days, and i have RA, when really tired I hurt badly when I stand for over five minutes. I did this finally today after turning off the power, unloading, reloading, and I found this, and so far so good, at least I hear water at last! So far it has not started washing fully yet, just in the first of the cycle, but like yours, all of my lights lit up across the panel, then that blinking clean light which has tormented me since thanksgiving finally went off, I did allow it to run the one cycle, it then stopped, it did not do the nine minute wash as yours did. Once it stopped, I replaced my wash pod and set it on normal wash with heated dry, and it has started to do something praise God. And I am so thankful for the help from here!
    New Friend:
Thanks...... worked for me.....
I save $..........
Posted on Dec 24, 2012
Press hi temp wash, air dry, hi temp wash, air dry this should reset the cycle
Posted on Mar 20, 2013
2 Suggested Answers
  • 530 Answers
SOURCE: whirlpool quiet partner III clean light blinking green
you have to hit heated dry and normal and toggle these till all the lights light up. then hit cancel . you are going to have to turn the power of and slide the dishwasher out and look directly behind the dishwasher you will see that a wire off of the heater is more than likly burned of repair the wire you should be fine. replug dishwasher in after wire is repaired. if you do not have a burned wire you have a bad heating element replace the element.
Posted on Apr 14, 2009
I have a kenmore ultra 665 1627. The green front panel light blinks. And we can not run a cycle. Thanks
Ah, the famous (or infamous) Clean-light blinking problem. Watch that blinking light.... Does it blink 7 times, pauses, and repeats? Or does it blink 3 times (or some other number). The most common problem is 7 blinks which means "water not heating error". This could be caused by a bad heating element, a bad thermal cutoff, a bad controller; but the most common problem is that 1 of the 2 switches inside the door latch is not getting engaged fully. This may be caused by something getting spilled (like a soda) into the door latch that is making it stick, or the door strike may be weak and not pressing down on the door latch hard enough. If it's the latch, you would need to take the door apart and remove the latch mechanism (unplug the dishwasher first!), remove the switches, and clean the plastic parts with water, dry it, and then re-assemble. The other thing to check is the door strike, which is supposed to push down the latch. The springiness of this metal part may be weak. You can remove that door strike, bend it down more, and then re-install it. Then you need to reset the controller by running a diagnostic cycle. Do that by pressing the following sequence of keys: Heated Dry - Normal - Heated Dry - Normal; or High Temp - Air Dry - High Temp - Air Dry; or Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or High Temp Wash, Heated Dry, High Temp Wash, Heated Dry). You will know that you have entered the diagnostic cycle when all the lights light up for a few seconds. Let the dishwasher run the diagnostic cycle for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error.
Note: On some of the newer Whirlpool, Kenmore, KitchenAid dishwashers, you start the diagnostic cycle by rapidly pressing the 3 left-most keys in the following sequence: 1 2 3, 1 2 3, 1 2 3.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Jul 27, 2014 | Kenmore Dishwashers
Hi
I have not seen this model in Australia, but normally if you hold down "Start/Stop" button for 3 to 5 seconds, that should clear the cycle.
Otherwise if you have a Clear button press that for 3-5 seconds.
Ash
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Green light is blinking --says clean when you push
Hello & Welcome to FixYa
Flashing green light is reset by pressing two buttons in sequence 3-4 times, to reset your dishwasher press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jun 10, 2011 | Kenmore 16764 Dishwasher
The green light for "clean" is blinking green and
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
Blinking clean light, will drain with cancel button,wont wash
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
May 26, 2010 | Kenmore 13853 Stainless Steel Dishwasher
Apr 14, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cycle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Jan 21, 2009 | Kenmore 24 in. 16293 Built-in Dishwasher
Kenmore ultra wash quiet guard 3 dishwasher problem
call sears, 1-800-4MY-HOME. They have a trouble-shooting department that will get rid of this problem. It is caused by water temperature being wrong at the start of the cycle.... blah, blah, blah. The representative will tell you to push a certain set of buttons in a certain order and that unlocks the dishwasher.
Sorry I don't know the sequence
Jun 08, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Whirlpool GU2400XTP Built-in Dishwasher Logo
14,774 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
