Question about Astar LTV-3201 32 in. LCD Television
Dvd setup can you tell me what channel and setting the tv has to be set to to use the dvd player
    Problem Solver:
  • 10 Answers
Most DVD players connect to the TV by AV (three wires), component (five wires), or HDMI (one wire) connections, none of which are tuned. That is, there are no channels on the inputs. Connect your DVD to the TV by whichever connection you choose. Then with your remote, select the input on your TV that corresponds to where you connected to on the back of the TV.
Posted on Dec 21, 2008
Channel setup
It sounds like the tv isn't finding any channels and that is why it keeps trying to repeat the search. In the cable/antenna input selection in tone setup menu, make sure you have it set up for the correct signal type. If this doesn't work, you may have a bad TV and should take it back to the store before the warranty is up.
Nov 29, 2013 | Sansui 19 in. LCD TV
Unable to set TV channels on dvd recorder since connected to Sky box
Actually you don't have to get other devices, Just cables, take the sky box output and connect to AV input of DVR
Feb 18, 2008 | Televison & Video
I'm trying to set up and connect it to my tv and the tv channels just won't load.
Are you on Cable? Coax cable from wall to dvd player INPUT? Follow the setup menu to program channels.
Feb 25, 2011 | LG RHT397H DVD Recorder
The description for setting up the LG RC897T VCR/DVD recorder says to "tune the TV to the recorder output channel (3 or 4) and set the recorder channel selector to the cable output channel" - so where do...
it means that your tv has to be on channel 3 or 4 to use device. once your tv is on one of those channels, you should be able to program your dvd/vcr to record and check to see if there is a menu button on your controller. if it is a newer tv, try setting menu on component1, aux 1 or anything but tv..if there is a menu button on controller for dvd/vcr player select that once you see the home screen on tv...
Oct 17, 2010 | LG RC897T DVD Recorder/VCR Combo
Auxillary channel for dvd
You need to determine what output options your DVD player has. Take a look at the rear of the player. It will certainly have RCA jacks for video and audio outputs (yellow for video, red and white for right and left channel audio). It may also have RCA jacks for component video (marked Y, Pb and Pr). Finally, it may have a threaded connector marked "out to TV" or "antenna out" or something similar. This is called RF output.
Most players today don't offer RF output because nearly every TV has direct AV inputs available. If your DVD player has RF output, connect the output connector to the TVs antenna input. You need a coaxial cable with F-connectors on the ends. One may have been supplied with the player. RF output is on channel 3 or 4, set by a switch on the back of the player or by its on-screen setup. Just set the TV to that channel to watch a DVD.
If your player doesn't have RF output, you connect it to the TV using the AV jacks. You need cables with RCA plugs to to connect the video and audio from the player to the TV. Then you switch the TV to its video input to watch the DVD.
This is where you might run into problems. Many TVs need the original remote control to switch inputs. (Some older RCA sets used channels 90, 91 and 92 to switch to their video inputs so any remote would work, but these sets were made before 125-channel tuning became standard. If your set is one of those models, those are the auxiliary channels you heard about.) If you can't switch the set to video input with front panel buttons and you don't have the right remote, you're not completely out of luck.
If you can't use your set's AV inputs or it just doesn't have any, you need an RF converter. These cost around $15. They take the audio and video from the DVD player and convert it to channel 3 or 4. Then you hook that output to your TV as described above.
May 17, 2009 | RCA Universal Remote Control
Bought a proscanlcd hdtv 32lb30Q unable to get cable signal
Hi and welcome to FixYa,
Initially, pls confirm if below is how it is wired using a coaxial cable and not 3cable RCA to RCA:
  • Charter Digital Cable > DVD/VCR > TV
If yes and your concern is snowy or no signal on the TV screen, might it be that you have to power OFF the DVD/VCR when selecting channels on the TV itself (including when channel setup is being done).
Alternately, you can tune the TV to channel 3 and let the DVD/VCR do the channel selections.
Pls post back results. Good luck and thank you for using FixYa.
Jan 26, 2009 | Televison & Video
How to set time and date
Turn on. Goto channel 3 or 4. Press DVD/VCR button until display says VCR. Press TV/VCR button until the display says VCR. Press SETUP button. Select SYSTEM SETUP. Select CLOCK SET. Edit time and date. Press SETUP button.
Jan 07, 2008 | Toshiba SD-V394 DVD Player/VCR
Connect ILO DVDR05 to a digital set top box tuner
Just run your outputs from your cable to the ILO inputs, then your ilo ouputs to the tv inputs. Use Cable remote to control channels, use ILO source button on remote to access the correct input setting on ILO. AND YES< you have to do this EVERY TIME you turn the ILO on to watch tv.. I have mine hooked up this way to record from my convertor box and My husband hates it.(when he just wants to watch tv.)
Nov 29, 2007 | iLO DVDR05 DVD Recorder
Sony TB model # KV-27S10 won't go back to original settings
Hook the cable tv signal directly from the wall to the tv,
then activate auto-memory. The tv should stop going thru the
channels once it finishes memory procedure.
Oct 22, 2007 | Televison & Video
Programming channels
Press Menu, press up and down arrows to choose the Input Select option then press side arrows to set the channel. Tuner will automatically cycle through all available channels in your area. After the Auto channel search is complete make sure the Channel source is set appropriately (TV or CATV) by pressing up and down arrows and chossing the correct source by pressing the side arrows using the channel setup menu. Press Menu to return to the TV screen. Use CH/TRK arrows or CHANNEL arrows on the front panel to cycle the DVD+VCR through the channels in memory.
Sep 02, 2007 | Sanyo DVW-5000 DVD Player/VCR
Astar LTV-3201 32 in. LCD Television Logo
95 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
