Question about Audiovox AVD300T Car DVD Player
NO AUDIO PURCHASED USED VAN W/AUDIOVOX AVD300T. VIDEO PLAYS GREAT, NO AUDIO. DOES THE AUDIO COME FROM THE ACTUAL UNIT OR THE CAR RADIO? DON'T KNOW IF THIS IS A WIRING ISSUE OR JUST NEED TO FIND A SWITCH. PLEASE ADVISE.
Tune radio on 88.7 fm an will transmite the dvd audio.
Posted on Sep 14, 2008
Rear Entertainment Systems plays sound on right side only
Using the wiring colors check the head unit output with a test speaker.
Apr 13, 2017 | Audiovox Car Audio & Video
We have a Audiovox VCR player that we ordered from Ebay for our RV but did not receive cables and we cannot find cables for it that works with the TV. Why is it different?
Mine has normal RCA jacks for Audio/Video & cable TV ports in & out. I do not understand your problem unless it is the Console wiring. Look into console (original set was for Toyota Van). Unit easily removed & cable can be snaked directly to units.. I took my console apart for components which use less space using direct power lead in with fuse & radio shack plug & a short cable TV jumper for signal from VCR to TV
Aug 24, 2011 | Audiovox AVP-7000 Video Cassette Player -...
I bought a van that had a audiovox video cassette player. The picture shows but there is no sound. The red audio rca cable's prong had been broken off so i spliced a new rca end on it. I figured this...
I had the same issue on a used '93 Chevy Mark III conversion van that I just purchased. You didn't state any specs of your van. However in my van, I found that the JVC CD player's factory preset settings needed to be changed from "CHANGER" to "LINE IN". The audio output is through my car stereo speakers. Hope this helps, Jim
Jul 20, 2011 | Audiovox AVP-7000 Video Cassette Player -...
Hi all bought a second hand van and need radio code
The only CLARION code available for free (using a serial number ) from anywhere on the Internet is if your radio also  has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + +  on a label somewhere on the metal casing.
If not then it will only be available from  your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM)
Mar 06, 2010 | Car Audio & Video
Can a univeral remote control be used with this device
yes as long as it has code search funtion, all RCA remotes can do this
Dec 29, 2009 | Audiovox AVD300T Car DVD Player
Phase linear uv8020
you probably have constant power running the radio. do you have constant and ignition wires from the radio hooked up or did you twist the yellow and red wires together? if this installation was done correctly than you the unit should power off when you turn the ignition off.
Mar 29, 2009 | Audiovox UV8020
Playing video audio through car stereo Toyota Matrix
You're probably gonna need a wired FM modulator. That part will take an audio output and run it into your antenna plug on your radio. It will use a FM channel, but it's wired directly to your stereo. So no static as found with wireless FM transmitters.
Jan 20, 2009 | Audiovox AVD300T Car DVD Player
Audiovox adv 300 dvd player with stuck disk
let the technicians get it our for you, to prevent damage on your player.
Jan 21, 2008 | Audiovox AVD300T Car DVD Player
PLAYER SAYS NO DISC
Try cleaning the lens first
Mar 20, 2007 | Audiovox AVD300T Car DVD Player
SAYS NO DISC
Try playing commercial DVD instead of DVD+R or DVD-R.
Mar 06, 2007 | Audiovox AVD300T Car DVD Player
Audiovox AVD300T Car DVD Player Logo
294 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Marvin
Marvin
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
