Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 no longer "sees" its cd/dvd drive- anywhere.
My Acer 5100 (1 1/2 years old - Vista Home Premium) no longer lists/recognizes my cd/dvd rom drive (no, it's not in my device manager or bios). Reinstalling won't work because there's no listing to click on. I've removed and checked the drive, etc. Nothing.
The thing whirs and tries to read when I insert a disc, but it can't read, and the burn software claims "no device" present. Acer tech support suggested I try restoring the computer to "box condition," but, if I do, I'll lose all my installed software, and, without a cd/dvd drive to reinstall, I'll really be in trouble.
If I must replace the drive, I don't want an ACER disk drive -- for obvious reasons. Is there a compatible internal drive I can use?
  • 2eagle Dec 21, 2008
    Thanks, but, as I've said, the drive is no longer listed in my Bios -- or anywhere else. I did try a bootable disk again. The drive spins, whirs a while, then gives up.
    Master:
  • 461 Answers
You can check the BIOS to see if the drive is recognized and even attempt to boot from the drive using a bootable CD to verify it is functional (if using the Windows disc - just verify it reads - DO NOT REINSTALL)
If the drive works use the following to get the drive back in Windows:
Always backup your registry before editing and use care to find exact key!
Start Registry Editor (Start, Run and type in regedit then click)
Find "UpperFilters" and "LowerFilters" (and "UpperFilters.bak" "LowerFilters.bak", if they exist) value under the following key in the registry, and delete it:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Quit Registry Editor.
Reboot.
NOTE: You might need to reinstall any CD recording apps you have, if they start to not work completely, after doing this.
Posted on Dec 21, 2008
  • Curtis Richner Dec 21, 2008
    Sounds like a failed drive, if not recognized at the BIOS level. I don't know that Acer actually manufactures drives. If you remove the drive you should be able find to the brand and model number label. Search for a compatible replacement by your laptop model.
I have acer aspire 4520.I have upgraded to windows xp sp2. The empowering technology does not work.It says " the specified file is not found".I cannot find the empowering technology software...
Acer Aspire 4520 Notebook Technical Specifications:
Operating System Genuine Windows Vista Home Premium Processor AMD Athlon™ 64 X2 Dual-Core Processor TK-57 (512KB L2 cache, 1.9GHz) Chipset NVIDIA nForce 610M Memory 1GB (1GB installed in one of two memory slots) DDR2 667 SDRAM User upgradeable up to 4GB (one 2GB memory card in each slot)* subject to availability of 2GB cards
*If upgrading after initial purchase, one or more of the memory cards provided with the system may have to be replaced with optional larger memory cards in order to achieve the maximum capacity.
Storage 120GB* hard disk drive Integrated variable-speed Super-Multi drive (DVD+R, DVD-R, DVD-RAM):
-Read - 24X CD-ROM, 24X CD-R, 24X CD-RW, 8X DVD-ROM, 8X DVD-R, 8X DVD+R, 6X DVD-ROM DL (double-layer), 6X DVD-R DL (double-layer), 6X DVD+R DL (double-layer), 6X DVD-RW, 6X DVD+RW, 5X DVD-RAM
-Write - 24X CD-R, 10X CD-RW, 8X DVD-R, 8X DVD+R, 4X DVD-R DL (double-layer), 4X DVD+R DL (double-layer), 6X DVD-RW, 8X DVD+RW, 5X DVD-RAM
5-in-1 card reader for optional MultiMediaCard™, Secure Digital card, Memory Stick, Memory Stick PRO™ or xD-Picture Card™
Surely to load XP is a DownGrade. As this notebook is dual core, I would run Vista 64 or better still Windows 7 64.
If you wish to persist with an old system, you require SP3 for XP.That may be available from a software store but is no longer supported by Windows.
Try http://www.notebook-driver.com/laptops-information/acer-aspire-4520-notebook-technical-specifications/ for drivers that you will require to have support from Acer.
Hope that clarifies your situation.
Dec 09, 2010 | Acer Aspire 4520-5582 Notebook
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
My DVD drive is no longer recognized
could be a cable has come loose or the reginal settings have been changed
Mar 02, 2009 | Acer Aspire 5100 Notebook
CD/DVD drive and external harddrives via USB not acessable
I once had a problem like this. It turn out that i just forgot to plug of my external drive. because of the lack of power of the device, it wasnt functioning properly. Try to see if you have two USB plugs, or one Usb plugs with a power cable.  Re check if both of the plugs are indeed connected properly.
Feb 01, 2009 | Acer Aspire 5100 Notebook
Acer 5100 cd/dvd drive no longer appears as a device - anywhere
try a disk cleaner it might be dirty inside and they are very sensative
Dec 21, 2008 | Acer Aspire 5100 Notebook
CANNOT FIND CD/DVD DRIVE ON ACER ASPIRE 5100
Is the hardware listed in the BIOS? When the computer first starts up hit a key to get in the BIOS (Esc, F2 or F10 are most likely). If it's not listed in the BIOS then it's likely a hardware problem. Try checking the connections to make sure it's plugged in and getting power.
If it is listed in the BIOS, it's likely a problem within Windows. Check Acer's website for known issues with the cd-rom.
Nov 25, 2008 | Acer Aspire 5100 Notebook
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
CD/DVD drive not working
Go to Control Panel, Administrative Tools, Services and make sure the "Shell hardware detection" is enabled and set to automatic.
Here's a FIX from Microsoft although you did not mention any errors.
Worth a try though if the first suggestion doesn't work.
May 03, 2008 | Acer Aspire 5100 Notebook
Dvd drive
go to systems tools and check if it is connected corretly if not sounds like your drive is shot to me linda
Apr 21, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
175 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
