Cars & Trucks Logo
A
Anonymous Posted on Aug 26, 2012
Need wiring diadram for delco 28043565. 2007 GMC 1500 Sierra radio CD player
Randy
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 12, 2014
Randy
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
518
Points
Need wiring diagram for delco 28043565 2007 truck radio
  • Randy
    Randy Jan 12, 2014
WIRING FOR 16164325 DELCO RADIO
That is not a radio. That is a control head. The 7 wires carry data to the radio brain which on this trucks is a silver box located directly above the gas pedal. These trucks also had an optional cassette player/ cassette and eq unit that was mounted in the center of the dash that also connected to the radio brain as well.
Please help me install a kenwood cd player in a 1995 GMC sierra truck the plug is cut off and i dont know the wires
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
1helpful
I need an Illustrated Parts Break down for a 1989 GMC Sierra 1500. 350 w/ PS/PB loaded. Steering column Removal Repair or Replace
Hi.
Below you get all the parts breakdown for GMC Sierra 1500, including steering column assembly:
1500 SIERRA
Here diagrams for all 1989 GMC trucks.
If you need to take apart the steering column you will also need wiring. below the color codes and wiring tips:
GMC SIERRA 1988-2005 VEHICLE WIRING
Regards.
Ginko
2answers
I have a 2003 GMC Sierra 1500 and it has a factory CD/Radio Bose system. The radio works fine but can't get the CD player to work, it won't eject or load a CD. I recently had an ignition fusible link prob...
you might have to take it to the dealership to have the radio reprogramed. it should only cost 40 bucks. these radios are very tempermental and have a mind of their own sometimes. My profesional recomendation would be to have an aftermarket cd player in. they are much nicer and have way better quality than the factory radio's
13helpful
2answers
Factory radio wiring color codes
Here ya go. enjoy!
2002 GMC Sierra C1500 Car Radio Wire Color Codes
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Amplifier Location: Under the center console.
10helpful
Stereo wiring diagram
1999 GMC Sierra Truck Radio Wiring Guide
12helpful
Trying to install an aftermarket stereo 1994 GMC 1500
You have to unplug the old radio. The radio isn't the part in the dash. That is just the control to the radio. The radio is actually under the dash above the accelerator pedal. It should have the power wires, speaker wires and antenna wire going to it.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
