FixYa.com
Tags:
Arcam AVR-200 5.1 Channels Receiver
How many speakers total can I connect to my... (by 6 users)
By Melissa - usenet poster
How many speakers total can I connect to my receiver?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by Mar_vin, posted on Jan 05, 2008
any as much the have output connection from your receiver. one speaker in positive and negative connection.
Comment by Feelingdumb, posted on Jan 02, 2008
I have a Yamaha HTR-6030 and want to use a second set of speakers in another room for Radio and CD Listening. I've connected the one set of speakers to A output and the second set to the B output. There appears to be no menu selection to control the A output, and I can't get any sound from the speakers on the B outputs at all. I can't find any menu item to turn one A off and B on for example. I find the manual not very helpful.
I have the main (TV) Front speakers connected to the A output pins, yet any adjustments I make appear on the menu as B outputs.
(I'm just using it for CD and Radio now - haven't ventured to the TV yet!)
Comment by carlrob, posted on Dec 21, 2007
I am replacing my 5.1 receiver with a 7.1. Is it OK to connect only 5 speakers?
Comment by Guest, posted on Dec 18, 2007
I have a Sony STRDG 710 6.1 receiver. No matter what I do I cannot get A & B speakers to play simultaneously, even with surround sound functions turned off. This troubleshooting information is not in the manual. What am I doing wrong? Do you have any suggestions?
Scott Gaylor
Wiredbyscott@aol.com
P.S. Last year's model works fine.
Comment by hitman44, posted on Nov 26, 2007
When I hook up the surround speakers AND a set of "B" speakers we can hear the surround rears EVEN WITH only "B" selected?? Does anyone know why?? I'm guessing there is a selection/setting within the amp? But don't have a manual with it. Any help is appreciated.
Best Solution
posted on Aug 08, 2005
Thanks for Trying (70)
Jimmy NY
Jimmy NY - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Any home theater receiver allows you to connect a minimum of five speakers, including a front left and right pair, a center channel speaker, and a surround pair. You can always add a subwoofer if desired. Some advanced receivers allow you to connect an additional one or two "back surround" speaker(s) for use with 6.1-channel sources such as DTS-ES or Dolby Digital EX-encoded DVDs.
For stereo listening, you can connect an "A" pair for the room where the stereo is located, and a "B" pair for another room (as long as your receiver has two sets of main speaker outputs). Hooking up even more pairs of stereo speakers is possible, but it requires an external speaker selector that both provides more speaker outputs and protects the receiver against low impedance loads.
Tip: Many receivers will not let you run the "B" and surround speaker outputs simultaneously.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 09, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
some have suggested attaching 100 .02ohm speakers. makes it fun yo
Solution #3
posted on Jan 07, 2008
Not Rated (0)
briman
Rating: 0%, 0 votes
Re: How many speakers
My 3802 7.1: is running 9 speakers , in the speaker settings i select "A+B" default is "A" , so if your looking for rear surround it works for me . I've always had Denon as my main unit so no comment on other companies .
Tip: If your looking for a new HDMI killer surround reciever "Onkyo" is setting the bar pretty high so watch out onkyousa.com, bring your credit card (lol)
If your looking for an owners manual www.brouchureworld.com this guy has everything you can think of and more .
Happy Listening
Briman340demon
Solution #4
posted on Jan 04, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
recently i bought a avr 2400 denon . it doesnot delivering bass . i have connected infinity alpha 40 tower speakers, how can i select speakers a and b by remote there is no function.suggest me an idea
Solution #5
posted on Jul 31, 2007
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
I own a SA HE200, it has "overload" protection. If you drive it too loud into too low of a speaker impedence, it will display "overload " and switch it's speaker connections off. Turn it off, then it on & it will reset. panasonic recomends 6 ohms, with a speaker mode for less than 6 ohms, a "low impedence mode" it has. I have speakers conneted to all 6 channels, the fronts, huge 4 ohms, center 8 ohms, rear left & right 5 ohms & 4 ohmsper channel connected in paralel = to 3 ohms,and rear center 4 ohms. This receiver connected to all of these speakers works extremely well, with no problems of any kind. It has not been needed to use the low impedence function, and you can turn it up loud enough to cause ear damage without it distorting the sound, long before ever reaching "overload", which I have only had happen 2 times. The statement was a question, so this is experience input not a solution.
This Problem Also Relates To: Kenwood KR-X1000 Motorola DCP-501 5.1 Channels Receiver NAD C425 Am Tuner Tuner Sony 6.1 Channel AV Receiver Sony STR-DB790 6.1 Channels Receiver Sony STR-DE845 5.1 Channels Receiver Aiwa AV-D55
Can you Help with these Receivers problems?
Receivers
what does it meen if
what does it meen if my 1.5... Answer This...
arcam avr300 intermittent...
Hi there, I have a arcam avr300... Answer This...
connecting Packard Bell imedia...
How do I connect and what leads... Answer This...
Power Pack Blown maybe....
My Arcam AVR200 turns on but... Answer This...
dvd recorder hook up
I have a sylvania zc320sl8... Answer This...
Repair Service
Find Receiver Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
