Question about Amana Refrigerators
Freezer not frezing but refigorator is cold
The refrigerator is cold but the freezer will not freeze. I have an Amana with the freezer on the bottom where can I find a model number?
  • 3 more comments
  • lm929 Dec 21, 2008
    I have pulled the back freezer cover off. There is a small amount of ice on the back right corner of the coils the fridge is 8 years old. Any suggestions?
    Is there any way I can add the freon myself money is tite but putting $350.00 into a 9 year old fridge doesn't seem like a good idea. I can get r134A at the local auto parts store and have charged my car AC unit in the past.
    Can I add the freon myself Money is really tite but putting $350 into a 9 year old fridge. I can get the R134a at the local automotive store and I have recharged my cars AC system before. Thanks in advance for any ideas.
    Can i add freon myself?
    yes
    Scholar:
  • 145 Answers
As you said the refrigerator is 9 yrs old,so, it is very likely the gas has leaked and No you cannot do it yourself unless you have trained for it. Please take the help of a qualified technician. My recommendation is that you but a new refrigerator and save the OZONE layer(if your pocket permits).
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 21, 2008
  • 2,427 Answers
Hey to me it sounds as if you need to re - gas the fridge. What happes is that the cold air is pumped in the freezer and a fan then sends it to the chill side. Since its cold , it means its not cold enough thats why is not freezing. try turning the temp control to the lowest setting and see if it helps. If not you will need to have it gased up.
  • Rishi Roshan Ali Dec 21, 2008
    As ginko correctly suggested, its the evaporator or dryer bottle (condenser) that needs changing.. Thats why you see ice forming on the coils. BTH after you change this it will have to be re gased.
    President:
  • Amana Master
  • 2,651 Answers
Just a small amount of ice in the very corner of evaporator, and hte rest of the evaporator is a clean silver. this is an indication of LOW CHARGE, your unit has a leak and or restriction of coolant(134a). this a repair only to be done by a factory trained refrigeration specialist. i would call around to the local repair shops, for a quote of such a repair, where I am this would run you a minimum $350.
  • Ron Coons
    Ron Coons Dec 21, 2008
    as far as model number its on a name plat on inside of refrig loner with all pertinent information, mod#-ser# (at least that s where the factory puts them) you may have removed there will also be a sticker on the very back panel of refrig that the factory uses to read as it goes down the production line (with the same info)
  • Ron Coons
    NO. , your system is sealed unlke your car that has charging ports, refrigeration sealed system repair requires reclaiming refrigerent, evacuating system of pollutant/contaminants, and recharging. As far as a do-it-yourselfer this is one job forthe professional. and your right that s a lot of money for a 9 yr old refrig
  • Amana Master
  • 19,396 Answers
If the freezer is not cooling at all it is probably a faulty thermostat.
If it instead has poor cooling and does not reach temperatures low enough, that is frequently because of a problem with the evaporator system. Check if there is ice on the coils at the back of the fridge. If you find ice the problem wiswith evaporator system, or the condenser.
In this case try doing a complete defrost, and clean the dust from the condenser (unplug power first) using a hoover. The condenser unit is located at the back of the freezer on the lower side, remove dust in there and let the fridge do defrost.
If this does not work call a technician.
    Top Expert:
  • Amana Master
  • 81,423 Answers
The only expert here is Ginko, his advice is correct, the rest, nice try guys!
Amana fridge is not cold
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
Our Amana bottom freezer refrigerator is too cold in the refrigerator portion. It keeps freezing all the fruits and vegetables even though the temperature is set on the warmest setting in both the...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 11, 2011 | Amana ABB1927DE Bottom Freezer...
I have an amana bottom freeze abb2227dew the freezer is working fine but the frige isn't cold?
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
May 11, 2011 | Amana ABB2227DE Bottom Freezer...
Not getting cold fridge or freezer side but at the bottom of the freezer its freezing
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 06, 2010 | Amana Refrigerators
Bottom is freezing properly but, the top refrigerator is not getting cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Oct 03, 2010 | Amana ABB1927DE Bottom Freezer...
Freezer not freezing nor ice maker
Is the refrigerator still working? Is there any cold air in the freezer? If your compressor stopped working it would cause the refrigerator to be warm also. I had a problem with my amana refrigerator where the freezer wasn't getting cold enough and it was due to a condenser fan running intermittently. i replaced the fan and was back in business. i would check to make sure both your fan and your compressor are operating...
Mar 03, 2010 | Amana ABB1927DE Bottom Freezer...
The cold water dispencer freezes in my amana bottom freezer refrigerator
The water line runs through the door and this is where it freezes. It's usually defetive insulation. Other than replace the door you may can tape or other wise fasten more insulation to the inside of the door in the area you think it's freezing in.
Aug 26, 2009 | Amana ABL2222FES Stainless Steel Bottom...
Amana bottom freezer problem
It sounds like the condenser coil might be freezing up. This happened to me on my bottom freezer. The cooling part of your fridge is only in the back of the freezer compartment. The cold air from the freezer blows up through a vent in the back to the fridge and comes out at the top. If the coils do not defrost (which is what happened with mine) the air flow is blocked by the ice and can't get to the fridge compartment. Your freezer will still be cold but your fridge won't. If you pull the plug on it and time things right you can defrost the coils but this will only postpone the problem. Both will work for awhile again until the coils ice up again. You can also pull out the freezer drawere and try to defrost the coil with a blow dryer. You have to disconnect the icemaker and pull out the back panel behind the freezer to get to it though.
May 25, 2009 | Amana ABB1927DE Bottom Freezer...
Refrigerators Logo
22 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
