Question about Denon AVR-900 Receiver
Trouble shooting a Denon Reciever
Hi there, I have a denon avr 900 that has worked great for 7 years until the other day there was a pop and everything was out except the "standby" light. Unhooked all the speakers. I opened it up and found a burnt fuse near the power input board. A 6.3 Amp 250 V slow burn fuse. Because I'd never opened the case up before I blew air to clear the dust. Got a replacement fuse and when I plugged the unit in the other fuse went. I replaced it and plugged it in and got a pop sound and smoke near the center of the unit. Checked for any burnt elements, none that I could see. And fuses are fine. Seems fine but now all I get is the "protect" sign on the display. Did I blow the amp? Is it worth fixing? Can I fix it? or is it repair time and money? The unit had been on for a while before but not at a very loud volume. Help! Thanks T. Eastman
  • Tim Eastman Apr 24, 2007
    Thanks so much.
  • Anonymous Nov 06, 2008
    i have same problem but fuses are all good. display out exept the standby light, and no sound when i try to play
  • 3 Answers
I had the EXACT same problem... Tried everything that you did with no prevail. I finally took it to a local electrician who discovered that it was the power output set-up/capacitors that had blown... and back to the question of if its worth fixing, I'll have to agree and say it isn't worth repairing. The parts needed to fix this problem generally run about $75. I was able to salvage the parts from another receiver and it requires a total of 10 new parts.
Posted on Nov 17, 2009
I just picked up a non working AVR 900, there are a total of 4 fuses inside the unit: 2 on the protect board, 6.3A and 8A, and 2 in the middle near the front. I was told by Denon the following might reset the microprocessor. 1) unplug unit 2) press and hold tuner and video select on front panel 3) plug in while holding buttons Unit display should flash until you let go of buttons. Unit stays on you should be ok/ goes back to red- service They also said: There are 3 types of protection that will commonly occur with our receivers. This is designed to protect the unit from permanent damage. 1) Thermal Protect = When the unit overheats this will occur, usually if there is not enough air space above and around the unit. There cannot be anything directly on top of the unit and there must be at least 4 inches of airspace above the unit. 2) Overload Protect = Most commonly occurs when a strand or more of copper speaker wire is not securely connected to the speaker terminal and is touching the chassis of the receiver. If the volume is turned higher than 85% this may also occur. If you need to turn the volume higher than this point to get the level you want, you need a more powerful amp. 3) DC Protect = When an amplifier fails this will occur. This will protect dc current from damaging the speakers. When this happens the unit will need to be serviced. I had a bad 6.3A fuse ? I replaced it and tried to reset. The microprocessor would not reset. I had the exact same results you had. The chip on the back side of the front IC board was smoking. Before I attempted the reset I asked Denon if it was worth sending in for repair. The answer was "NO" BC
Posted on Apr 24, 2007
Visio e370vl says "not support when iplug in my Denon avr-2310ci
dont use your reciever to switch video inputs to your tv, plug player directly into tv, use coax or optical input from player to reciever for audio
Mar 23, 2013 | Denon Audio Players & Recorders
Denon AVR 591
This is where a circuit diagram would come in handy, displays are tricky to trouble shoot, and this a job for a pro.
Apr 02, 2012 | Denon Audio Players & Recorders
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
Denon AVR 1706 reciever
it a control switch and power supply that needs to be replaced they have blown.
get in contact with me so I can help you financially...I can buy your unit for parts.
It will cost more than the unit
radricktip@gmail.com
Sep 27, 2008 | Denon AVR-1706 Receiver
Denon AVR 1705-no audio on TV
I have had the same problem and was told that it is a "board" inside. Essentially it has lost the surround sound ability and can only play things in Direct/Stereo. Mine is just over 2 years and I originally thought my kids had hit a button on the thing causing the issue...ended up paying $100 to trouble shoot it and confirm that it is internal and more expensive to fix than replace. Can't say that I will be buying a Denon again.
Jul 09, 2008 | Denon AVR-1705 Receiver
My denon reciever display wont't work
I read something the other day in the user manual about re-setting the microprocessors if the display doesn't display properly. Turn the amp off.  Hold down the input mode & analog buttons while turning power on. The whole display should flash on & off at 1 sec intervals, then release the two buttons. This resets the microprocessors & supposedly fixes display problems.
Jun 23, 2008 | Denon AVR-2805 Receiver
Clicking sounds
i had this condition on another denon a/v receiver it started clicking got worse as time went on progressed to snaping sound more so when switching modes ie dvd to tv etc then l/frt speaker would cut out found by gently tapping l/side of the chassis it would pop & snap sent it out to denon & they replaced the dsp unit no problem since hope this helps Alan
May 22, 2007 | Denon AVR-4306 Receiver
Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Jan 10, 2007 | Denon AVR-1706 Receiver
No radio
The front end is bad on this reicever. Your going to need special equipment to trouble shoot this problem, as Its all RF. It is most likly not worth repairing as a shop will most likly charge you more then its worth
Sep 16, 2006 | Denon AVR-1100 Receiver
813 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
