Question about Midland 74-109 Weather Radio
Siren goes off occasionally for no reason
The siren goes off...will a varying warble as if there was insufficient power..about twice a week - usually in the middle of the night. Since I have a second weather radio that does NOT go off, and I checked it when the Midland went off, I am sure there were no alerts, weather or Amber, that triggered it. I replaced the nine volt backup battery to no avail.
Any suggestions? The radio works fine otherwise.
5 Suggested Answers
  • 4 Answers
SOURCE: Midland WR 100B Weather Radio
Try setting the S.A.M.E. code setting from Multiple or Single to ANY.
Posted on May 31, 2008
  • 164 Answers
SOURCE: DROPPED MIDLAND WEATHER RADIO - NOT WORKING NOW
I will be honest with you, I haven't had any problems with this, but I will give you my opinion on what you should do. You can try to call tech support, but I do not think they are going to replace your radio because under their one year warranty, it says that they will repair or replace, at its option without charge, your radio if it fails due to a defect in material or workmanship within One Year following the initial consumer purchase. In other words, they are probably going to feel like this was your fault and your sole responsibility for the radio not working, not the radio itself. I will give you two possible solutions that you can try, but the only solution maybe to just get a new one. My first solution is to actually open the radio by unscrewing the bottom screws (the other two bottom screws are under the black grip-pads), and checking the circuit board and other contractions inside the radio to make sure everything is still intact. I've never tried this with the weather radio, but I did try it with a digital tire gauge I had bought. The tire gauge was not coming on when it was supposed to. I opened it up and played with some of the parts in it. I'm still not finished fixing it, but I did see that it was working better than it was before. Try playing with the parts in the radio and then put the radio back together and turn it on. If this does not work, than it's likely something that cannot be replaced and you will have to get another one. They have them at Wal-Mart for $29.99. I don't know if you are running your radio just on batteries or not, but if you are, maybe you should change the batteries. I hope this works out for you and remember, this is just a suggestion.
Posted on Sep 25, 2010
  • 5724 Answers
SOURCE: Hi! I've been under 4 different tornado warnings
Do you hear a broadcast when you hit the Weather/Snooze button? Is the transmitter that you have programmed broadcasting? NWS does have downtime at the various transmitters and these will be listed at weather.gov. (Click on the map for your region and look at the links in the News of the Day section.) If the signal is being broadcast, try changing where you have the radio placed until you hear the broadcast come through clearly. With one weather radio, I found that I had a better chance of getting the NWS alerts from a different tower than the one listed for my county. My location is closer to this other transmitter. See http://www.weather.gov/nwr/Maps/ for where the transmitters are located in various states. Click on your state for your local map. Check the map for adjacent states if you are near a state border.
Do you have an external antenna? Check that it is properly connected. If not, consider adding one positioned to get a better signal for the nearest transmitter to your location. (With an external antenna, we can get one of several transmitters on that weather radio. This means that we can easily switch when the best transmitter is down, as well.) See www.midlandradio.com to see the antenna that they recommend - which should be placed in a window. This is the 18-259W VHF Through-glass antenna.
Has your radio been picking up the weekly and monthly tests before this? These only give a text message not an alert tone with this Weather Radio. The alert will reset within 6 hours.
Did you set the alarm to Display alerts? This is the silent alarm mode - Tone or Voice would give an audible alert. Check this by pressing Menu then use the Up arrow until you see Alt Type. Press Select and use the Up arrow and then scroll through the options. Press Select to set your choice and then press Menu to exit the menu. Check the volume setting if you have the alarm set for tone or voice.
I hope one of these items help. Otherwise, contact Midland for support. They charge $45 to fix out of warranty weather radios plus a $7.50 shipping and handling charge for any repair. The S&H charge is not required in all states. http://www.midlandradio.com/Resource_/OwnerManual/122/WR-100B.pdf is the direct link to the manual and has the Service details. The direct link to the pdf may not work; you can find this via Google or at the Midland site.
(btw, my household had one weather radio that continuously would lose the ability to hear the test alerts even when placed in a spot that usually got the best reception for the unit. Since that one also did not respond to S.A.M.E. codes properly, we replaced it and put it in our workshop where the intermittent signal loss wouldn't always be critical. Without an external antenna, positioning the radio for best signal took walking around the house many times. Even with the external antenna, it took a while to find the best placement for the antenna.)
Posted on Oct 27, 2010
  • 164 Answers
SOURCE: Just bought a Midland 100B
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to help solve this concern. You just purchased a Midland WR-100B All-Hazards Weather Radio. You have all the information programmed correctly in it and you are still not receiving any alerts. First of all, log on to this website and check to make sure that the transmitter tower in your area is still working (this means your county does not have a DEGRADED remark in its row).
http://www.nws.noaa.gov/nwr/indexnw.htm
When you get to the website, select your state and you will see a list of all the counties in your state. Find your county and locate the REMARKS column. If your county has a remark stating "OUT OF SERVICE" or "DEGRADED", it means the tower transmitting broadcasts for your state is not working due to technical problems or recent severe weather conditions. If your county doesn't have one of these remarks beside it, then the reason why you are not receiving any alerts on your radio is because the National Weather Service has special criteria that a storm has to meet in order for them to alert NOAA Weather Radio owners "In the middle of the night or while doing daily activities". To translate that for you, they don't want to disturb anyone by sending alerts for storms that are not "life threatening" or going to cause severe damage. Click on the links below to find out more information about when alerts are broadcast.
http://www.weather.gov/os/eas_codes.shtml
http://www.weather.gov/nwr/nwrwarn.htm
NWR always runs Required Weekly Testing every Wednesday starting from 10:00 AM to 12:00 PM. If you are able to, check the radio then. If you see the amber light shine, then you are receiving a test. http://www.weather.gov/nwr/nwrtest.htm is the place to find more information about NWR testing. I hope this will give you a better understanding of when the National Weather Service sends alerts to the viewing area. Thank you for choosing FixYa to as your one-stop solution spot for questions, concerns, problems and requests. Stay safe this Severe Weather Season and have a good morning, afternoon, evening or night; whatever time of day you are viewing this solution post.
Posted on May 26, 2011
How to turn the volume up on a dsc powerseries 433mhz home alarm
If you are referring to the siren or keypad tones or anything you can't. If the siren isn't loud enough then it may be a lack of power issue or you may need an additional one. 1 siren is usually adequate for most houses.
May 01, 2018 | DSC Home Security
Is the a 12v power adaptor for the Yale easy fit siren EF-BX unit that can be fitted to the siren instead of the batteries ???
Because your system is designed to operate off of batteries only, coming up with an external power supply to work around the original design becomes an issue. In order to do what you want to do you would have to have a rechargeable battery maintained by an appropriate charger that would run the system from the charger/supply, charge the backup battery and switchover to the battery in the event of a power failure. These do exist and one manufacturer is Altronix but there are several, you just have to visit a DIY alarm website and get recommendations bearing in mind the battery voltage your system is designed for and the amp hour rating necessary to keep the system running the duration of the power outage and beyond. Keep in mind the reason for your alarm system is security and compromising that with homemade non-UL retrofits might not be the way to go, your choice.
Dec 06, 2014 | Cars & Trucks
Honda civic engine siren nosie
The main reason can be serpentine belt tensioner. Few more components that make siren noise are
1. When an alternator fails
2. If vacuum leak is there, then also vehicle may create siren noise. But in that case check engine light may come up.
The very first step you would be taking is to check the serpentine belt.
Jun 26, 2013 | 1995 Honda Civic
Alarm is armed but when door is opened no siren
Is there power to the siren? Are the lights flashing? Can you choose to have the siren on or off? If the lights flash and there is no power to the siren it may be the controller. If you have power to the siren then make sure you have good ground at the siren even if you have to run a ground wire from it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/edward_020b3320326d263d
May 18, 2012 | Cars & Trucks
Schematics for cjb100pd
Red is your positive, black is negative, both brown wires are to the speaker, and the yellow and green wire are for any emergency strobe lights you may want to hook up to it. P.S. if you wire up the brown wires and siren doesn't work make sure volume is turned up and try it again if it doesn't work then switch the brown wires around. Both toggle switches on the far right is to only turn the lights on. not the siren. Make sure the siren nob is turned all the way left thats off. The rest of the are just siren modes. The toggle switch all the way to the left. Push down horn comes on release it then horn goes off. Push up siren comes on for like 7-10 seconds and the goes off. Horn and your microphone always override any siren that may be on.
Mar 12, 2012 | Cars & Trucks
I have a Ge Simon Xt Alarm and i want to hook up a external siren(part 13-950)I received a 4.7 resister with the siren and 50 ft of wire.How do you attach the resister between the red and black wire?Do...
Wire nuts are ok if the siren is indoors. Gel filled connectors are better if you are mounting the siren outside because they keep the connection from corroding. The resistor needs to go between the two wires you are hooking up. The color of the wires you will are are generally red and black. If your siren has a yellow wire, you can use it instead of the red to get constant siren instead of the "whoop, whoop, whoop" sound that sirens usually make. Putting the resistor at the siren will make sure that it is supervised. That means that if someone cuts the wire going to the siren, it will alert you at the panel. If you put the resistor at the panel, nothing will happen if the wire is cut.
May 19, 2011 | GE Security Simon 3 Wireless Home Security...
Have a 748 siren, lost the wiring instructions and need to know what they were. There are 5 wires on the unit. Thanks
The wires are as follows:
Black: Negative (-)12VDC
Red: Warble (+) 12VDC
Yellow: Steady (+) 12VDC
White Lead: Tamper Circuit
Hope this helps.
Apr 20, 2011 | Honeywell 748 - Ademco 119db Siren
Theft alarm sounds w/o provocation
This sometimes can also be related to the internal batteries in the alarm ECU or alarm siren module going bad. If your handy the internal batteries can be replaced without buying a new replacement unit. Otherwise, the entire module must be replaced ($$$). Lastly, you can have a Saab indy or dealer disarm the theft alarm on the vehicle. You retain your keyless operation, but the alarm is not active. This is done in the programming and adjustment menus in the TWICE unit with the Saab Tech 2 computer.
Justin Duthie
Strictly Saab
Melbourne, FL
Aug 24, 2008 | 1999 Saab 9-5
Midland 74-109 Weather Radio Logo
52 people viewed this question
Top Midland Audio Players & Recorders Experts
Van Allen II
Van Allen II
xxxxxx xxx
Are you a Midland Audio Player and Recorder Expert? Answer questions, earn points and help others
