DD Drive is not working - Computers & Internet
  • 53 Answers
If DVD drive try changing the jumper position
Posted on Sep 17, 2009
    Problem Solver:
  • 29 Answers
If there is some track noise replace it immediately........
Posted on Sep 05, 2009
Is my mitsubishi dd 6030 a multi region player
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
Jan 20, 2016 | Mitsubishi DD-6030 DVD Player
I need to fix the direct drive record player on my Electro Brand Retro Cd Am/fm With Turntable 45rpm, 78rpm, Built - In Speakers Model 9263, I dont have the manual and can not find it online.
Are you certain it's a direct drive model, because DD models with 78 speed are not common at all? If it is a DD model then you need to check that power is getting to the motor. There could be a switch that's not turning it on somewhere inside the unit.
May 15, 2015 | Drive Audio Players & Recorders
I have installed ubuntu on my iMac as I couldnt install windows or boot Mac os I have a external drive that has Mac os and recovery partion but I can't boot with it but in ubuntu j can read the disk I...
You could copy the contents from the external drive to the internal one. Boot from an external CD or DVD with the Ubuntu installation image on it. Doing so will allow you to write over the internal drive. Learn the dd command (start with "man dd" from your Ubuntu terminal window. An example might be "dd if=/dev/sdb of=/dev/sda"
"if" is short for "input file", but can represent the whole device (drive), which is what you want. "of" is short for "output file". You can use Ubuntu's Disk Utility to examine all your drives and figure out which one is which.
This is a very powerful command and nothing else I can think of can wipe out a disk you meant to keep any faster or more thoroughly, so be very sure you figure out which (sda sdb, and so on) is input and which is output. The "dd" command produces no output until it's done, just quietly working away on gigabytes as ordered.
Feb 03, 2014 | Computers & Internet
Ps3 hardrive corrupt and fails to recover
Try THIS
What you will need:
  1. Bad PS3 hard drive
  2. New hard drive of equal or larger size
  3. SATA to USB cable or a spare USB enclosure
  4. Copy of 'dd' for the OS of your choice
    • (Linux and OS X users should have it by default, Windows users can get it here)
  5. Time, patience, and a desire to recover your data
The process:
  1. Remove bad drive from the PS3
  2. Connect bad drive to a computer that has enough free space as the size of your drive
  3. Make a backup image using 'dd'
    • WARNING! You should be able to do this without having administrator/root/superuser rights. However, if for some reason you have to do this with admin/root/su rights, PLEASE, quadruple check what you type and make sure you have the correct paths. It is entirely possible to completely ruin a system install if you overwrite your computer's main hard drive and 'dd' will do this without blinking an eye if you tell it to.
    • The command I used was
      • dd bs=10M if=*path_to_your_ps3_hdd* of=*path_to_ps3_save*ps3_save.dd
    • Where *path_to_your_ps3_hdd* is the full path to the bad drive and *path_to_ps3_save* is the full path to where you want the backup image to be stored.
    • For example, I would've used
      • dd bs=10M if=/dev/sdb of=~/OMGPLZWORK/ps3_save.dd
    • As a Linux user "/dev/sdb" was the path to the bad drive when connected via the USB adapter and "~/OMGPLZWORK/" was the path to where I wanted to save the image.
    • Note that you DO NOT want to specify a partition number (/dev/sdb1) as you want to image the whole drive. There probably won't be a partition number, but just in case.
    • If you are a Windows user the command would look something like this
      • dd bs=10M if=\\.\e: of=c:\OMGPLZWORK\ps3_save.dd
    • Note that dd for windows requires "\\.\" before the drive letter.
    • Please read the "dd for windows" website if you are at all confused.
    • And for OS X users it would be something like this
      • dd bs=10M if=/dev/disk2 of=~/OMGPLZWORK/ps3_save.dd
    • As with Linux, you DO NOT want to specify a partition number (/dev/disk2s1) if there is one.
    • Note: '~' is a shortcut to your home directory.
    • Linux and OS X users (and I suppose Windows users too, if you wanted to install gzip, but I won't cover that) can use a variant of that command that will compress the image as it's created
      • dd bs=10M if=*path_to_your_ps3_hdd* ' gzip -9 > *path_to_ps3_save*ps3_save.gz
    • This will not compress the image much, as it will only compress free space on the drive, but it took my 320 gigabyte drive to around 260 gigabytes.
  4. Connect new drive to the same computer
  5. Restore image using 'dd'
    • The command to use is
      • dd bs=10M of=*path_to_your_ps3_hdd* if=*path_to_ps3_save*ps3_save.dd
    • or if you chose to compress the image
      • gunzip -c *path_to_ps3_save*ps3_save.gz ' dd bs=10M of=*path_to_your_ps3_hdd*
  6. Install new drive into the PS3
  7. Boot up the PS3 and let it attempt to restore
Note: If you have the available hardware, there's no reason you couldn't just 'dd' the data from the bad drive directly to the new drive.If you wanted to do that the command would be
  • dd bs=10M if=*path_to_your_bad_ps3_hdd* of=*path_to_your_good_ps3_hdd*
For example
  • dd bs=10M if=/dev/sdb of=/dev/sdc
If you choose to do this, you run the risk of writing the new drive over your bad drive if you have a typo (even if you're not running with admin/root/su rights!), so quadruple check the command and paths before executing.
If all goes well your PS3 should be back up and running with little data loss. However there is NO guarantee that this will work for you. If you're like me, though, it's worth a shot and you never know, it just might work.
Nov 21, 2013 | Sony PlayStation PS3 Slim 120GB Bundle...
Vixen Telescope DD-1 Dual Motor Controller for RA and Declination
Vixen can repair your telescope-- and or the controller--
Contact OPT at this web site -- they are a Vixen dealer and can advise you about what to do--
http://www.optcorp.com/
Apr 10, 2009 | Vixen U.S.A. Great Polaris Telescope Mount...
CD DRIVE
Not having a whole lot of information to review, it might be easier to just replace the CD drive. You can also upgrade the drive to a DVD writer while you are at it.
Mar 06, 2009 | Gateway GT5422E Refurbished AMD Desktop...
IE DATA 702 fdd
Hello
I beleave it uses a HD/DD type of disk
Abbr.
Floppy Disk Type
Capacity
Info
SS/SD or 1S/1D
Single Sided, Single Density
100 K
First generation. Capacity varies
SS/DD or 1S/2D
5-1/4 inch Single Sided, Double Density
180 K
DD/DD or 2D/2D
5-1/4 inch Double Sided, Double Density
360 K
Most common type in the early 1980's
DD/HD or 2D/HD
5-1/4 inch Double Sided, High Density
1.2 Mb
DD
3.5 inch Micro Floppy, Double Density
720 K
Hard plastic case
HD
3.5 inch Micro Floppy, High Density
1.44 Mb or
2.88 Mb
Hard plastic case
May 05, 2008 | Ye Data YD-702D (850416000107) Internal...
Hard disk replacement for lacie ethernet disk mini 250 gb
I managed to fix mine with a little bit of work.
This website has a readme file that specifies the partitions. You must be using Linux.
http://gpl.nas-central.org/LACIE/ethernet_disk_mini_v2_-_ethernet_big_disk/EDmini_v2_partition_images/Readme
1. Plug the drive in a Linux computer, or use a Linux Live disk.
2. Create all the partitions according to the readme file. Use extended partition for the first "container". Linux Swap for the second partition. Use Ext3 format for the remaining.
3. Extract all the SDA6-8 files with bzip.
4. Use "dd" command to write those images to partitions sda6 - sda8 which you just created with this command: dd if=/dev/home/ubuntu/sda6 of=/dev/sda6 bs=512
5. Substitude /home/ubuntu above for the location where you placed the image files.
6. Once all 3 images have been written, the drive should be good to go. Put it back in the edmini, start it up and see if the website comes up. You may have the "format" the drive from the admin utility once its up and going.
Hope this helps.
use the "dd" command in
Mar 08, 2008 | Computers & Internet
Computers & Internet Logo
22 people viewed this question
Alun Cox
David Payne
David Payne
