Question about Electrical Supplies
NO SPARK AT SPARK PLUG
I HAVE A HONDA EC1500 MODEL GENERATOR I HAVE JUST BOUGHT IT AND I CANT FIND ANY INFO ON THIS MODEL? THERE IS NO SPARK AT THE SPARK PLUG IS THERE ANY WAY TO TEST THE COIL TO SEE IF IT IS WORKING ?
  • John McKinney May 11, 2010
    here is a website that may help you. let me know if you need any more help. thanks. I would need the brand of the engine and all of the numbers off of it to assist you the best.
    Habit-Forming:
  • 80 Answers
YOU CAN MAKE A SPARK TESTER BY TAKING A SCREW DRIVER AND PUTTING INTO THE WIRE AND BY BEARLY TOUCHING THE BLOCK TO SEE IF A SPARK COMES BETWEEN THE BLOCK YOU WILL SEE A SPARK IF THE COIL IS GOOD
Posted on Apr 05, 2009
2005 Honda FMX 650 spark plug removal
Hi, Anonymous for this scenario you will need your service, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
SPARK PLUG REMOVAL TOOL SOCKET FITS HONDA FMX650 2005 2008 eBay
XR650L Spark Plug Removal 4Strokes com
http://freepdf.co/crwico-2b/honda-fmx-650-service-manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Jan 10, 2014 | 2005 Honda FMX 650
Honda generator starts, runs, then stalls and backfires
Honda makes quite good gasoline motors. I doubt it is a valve timing issue but it might be a burned valve or a valve adjustment issue. What does after a while mean? A couple of minutes or 4 hours? Is it running for just a short while and then stops or it runs well for a long time and then stops?
Aug 01, 2012 | Honda Generator Eb4000x Eb5000x Eb6500x...
Honda e2000i generator no spark
if there is no spark in the plug as you are saying for that matter check the current coil and the inverter section for the loss of current if you have already changed the sparkplug if not do change
Jun 30, 2012 | Honda 3000 Watt Portable Generator
1996 Honda RVF 400 NC35 spark plug location
Hi, Wily_mogano for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
1996 Honda RVF400 NC35 spark plug location Google Search
RVF400RR NC35 Model Info
http://www.alliancefordsteagathe.com/honda_rvf400_service_manual_download.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda RVF750R RVF Owner Manual
Apr 06, 2011 | 1996 Honda RVF 400 NC35
I have a very old honda generator 2.8 KVA max rated 3.5 KVA maximum output 12VDC @8.3 amps overhead valves electric start trying to find a model # and I am not getting voltage at spark plug ? (with new...
hi
insure the wires from the magneto are not cracked or shaved as this would discharge to earth and the ht lead from the magneto to the plug is not perished as this would create leakage to earth
Sep 20, 2017 | Honda 3000 Watt Portable Generator
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Sep 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Model pm0542000 01 coleman generator needs spark plug
This particular generator can come with Briggs & Stratton engine (spark plugs recomended will be then Champion RC12YC).
This model can come as well with Honda engine or with Subaru engine.
These variation depend on country of manufacture.
As I do not know where are you located, I give you this which is known to me, if you have Honda or Subaru engine, my best bet will be follow this advice:
1. stop engine
2. undo spark plug and note what alhanumerics are on porcelain bit, eventually grab the sparkplug and go to closest fuel station/car spares/hardware/camping store and they will be able to tell you what sparkplug and even sell you one.
Hope this will solve your problem :-)
Aug 16, 2010 | Coleman Powermate Premium Plus 6250W...
Honda GX 160 under 30 hrs from new, is running poorly
try removing the float bowl on the carburator and cleaning, sounds like needle valve is partially stopped up
Aug 02, 2010 | Honda Horizontal OHV Engine for Non Pumps ...
Bad and obsoulete ignition system
Please provide model number of engine and generator and I will try to locate a good used coil.
Feb 04, 2009 | Honda Electrical Supplies
Electrical Supplies Logo
361 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
